Flying under Class B
Old September 29th 04, 10:04 PM
PaulaJay1
Default Flying under Class B
What is the minimum legal distance (altitude) to fly VFR under a Class B
"wedding cake"? CLE has a 1900 ft floor at the north side by Lake Erie and I
have flown at 1800 to go around CLE. I was not talking to CLE so I don't know
if they objected. Today I was coming around CLE decending IFR. When in VMS I
cancelled IFR and remained on squak for advisories. The controller wanted me
at 3000 when under a 4000 ft designated altitude. Was he just being safe for
his own good or is 1000 ft suggested as the minimum buffer? I know, I should
have ask him but the frequency was pretty busy.
Chuck
Old September 29th 04, 10:28 PM
G.R. Patterson III
"wedding cake"?
Whatever the floor is.
You could fly it at 1900. Hit a bump and go to 1901, however, you're illegal, but the
controller won't know it. The typical mode-C transponder reports altitude in 100'
increments and changes readings at about the 50' level; that is, at 1949', your
transponder should report 1900' and at 1950' it should report 2000'.
Dunno about you, but my encoder isn't that accurate. Still, it won't be precise
enough to get me busted at 1' over the floor.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old September 30th 04, 12:33 PM
Patrick Mayer
Hi,
illegal, but the
Isn't the stated altitude included in class B? So, nitpicking, you'd have to
fly at 1899 to be legal, unless there's this "+" sign on the chart...
Happy flying,
Patrick
Old October 1st 04, 02:28 PM
Malcolm Teas
"G.R. Patterson III" wrote in message ...
"wedding cake"?
Yup, legal distance is the floor. But my method to handle it is to
fly 200 feet below the floor if I can do that safely. Since the
transponders report in 100 foot intervals, and there may be error in
either the transponder or the ATC side of the reporting system, this
keeps me out of ATC's concern for busting the Bravo. (I got this from
an instructor of mine.) This also allows for errors (mine or others)
in flying level, or setting the altimeter too.
That being said, I'll scrap the floor with my tail if I have to for
safety & ground clearance, or ask for Bravo clearance (but never get
it near here). If ATC calls traffic and gives me an altitude or
heading to take, I'll take it and debate the issue later if necessary.
I'm out of Leesburg VA under the Wash DC ADIZ, so under Bravo space
I'm ALWAYS talking to ATC. The rules are a little different here, but
I do appreciate the effective result of flight following it gives me.
I do wish they'd call out type as well as traffic though. Watching
for a C172 is a little different from watching for a business jet or
turbo prop. I kept looking for the other "Cessna" going into Leesburg
last weekend and not finding him till I figured out that he was much
much faster, with a wider approach and pattern than the C172M I was
flying.
-Malcolm Teas
Old September 29th 04, 10:32 PM
Dude
If you are VFR, you can be within 1 foot of that space, and be legal. AFAIK.
However, if you are using radar services, they will often fly you at an
altitude for their own reasons, whatever they may be (always good reasons,
but varying in importance). I have had controllers argue with me over this,
so I know it varies around the country. The rules and regs are the same, but
geography, weather, and habit have pretty large influences on how they are
applied.
You can call them and get an answer why they do that in your area if you
really want to know. Used to be you could go tour the facility and sit with
a controller to learn, but they supposedly stopped doing that. I haven't
sat with a controller in a dozen years, so I suspect things have changed
alot and would like to do it again.
Legally, you could have told them you wanted another altitude, since you
were VFR, like 3500, but legally, he could cancel you since you canceled IFR
as well. So the rules are one thing, and how they are applied can vary.
Mostly, I go along because I figure it makes a big difference to them, and
a little one to me. Whenever I have asked for a different altitude (due to
obscuration or turbulence, or heat), I usually hear "cleared VFR under 4000
feet" - or whatever applies.
Once though, I got a nice request/advice to stay where assigned due to
traffic. I was happy to bump along at 1500 rather than try to stay cooler
and smoother if it meant avoiding an unwanted meeting with a regional jet
"PaulaJay1" wrote in message
and I
know
VMS I
me
for
should
Chuck
Old September 29th 04, 10:51 PM
Steven P. McNicoll
"Dude" wrote in message
this,
but
applied.
It doesn't vary at all. If you're outside of the Class B airspace ATC has
no authority to assign altitudes to VFR aircraft.
Old September 30th 04, 01:17 AM
Dave S
this,
but
applied.
Nor any obligation to continue radar services to said VFR aircraft.
Dave
Old September 30th 04, 02:04 AM
Steven P. McNicoll
"Dave S" wrote in message
link.net...
has no authority to assign altitudes to VFR aircraft.
Actually, there is.
FAA Order 7110.65P Air Traffic Control
Chapter 2. General Control
Section 1. General
2-1-1. ATC SERVICE
The primary purpose of the ATC system is to prevent a collision
between aircraft operating in the system and to organize and expedite the
flow of traffic. In addition to its primary function, the ATC system has the
capability to provide (with certain limitations) additional services. The
ability to provide additional services is limited by many factors, such as
the volume of traffic, frequency congestion, quality of radar, controller
workload, higher priority duties, and the pure physical inability to scan
and detect those situations that fall in this category. It is recognized
that these services cannot be provided in cases in which the provision of
services is precluded by the above factors. Consistent with the
aforementioned conditions, controllers shall provide additional service
procedures to the extent permitted by higher priority duties and other
circumstances. The provision of additional services is not optional on the
part of the controller, but rather is required when the work situation
permits. Provide air traffic control service in accordance with the
procedures and minima in this order except when:
a. A deviation is necessary to conform with ICAO Documents, National
Rules of the Air, or special agreements where the U.S. provides air traffic
control service in airspace outside the U.S. and its possessions or:
NOTE-
Pilots are required to abide by CFRs or other applicable regulations
regardless of the application of any procedure or minima in this order.
b. Other procedures/minima are prescribed in a letter of agreement,
FAA directive, or a military document, or:
NOTE-
These procedures may include altitude reservations, air refueling,
fighter interceptor operations, law enforcement, etc.
REFERENCE-
FAAO 7110.65, Procedural Letters of Agreement, Para 1-1-8.
c. A deviation is necessary to assist an aircraft when an emergency
has been declared.
REFERENCE-
FAAO 7110.65, Safety Alert, Para 2-1-6.
FAAO 7110.65, Emergencies, Chapter 10.
FAAO 7110.65, Merging Target Procedures, Para 5-1-8.
Old October 1st 04, 02:31 PM
Dave S
The controller has the authority to arbitrarily decide he does not have
the ability to provide VFR services due to workload constraints.
Dave
link.net...
Actually, there is.
Section 1. General
2-1-1. ATC SERVICE
NOTE-
NOTE-
REFERENCE-
has been declared.
REFERENCE-
Old October 1st 04, 05:20 PM
Dude
"Steven P. McNicoll" wrote in message
ink.net...
reasons,
this,
but
are
applied.
Steve,
We can argue rules all day long, but the way things are done can make the
results of whats done inside the rules seem strangely dissimilar in the
cockpit.
Whether they have authority or not at all, doesn't matter one wit. They do
it, and you can respond with compliance or not (since they do not have
authority, you can choose to disregard).
I have given you a real life, and common, example of what happens in my
area. If you choose to not believe me, that is fine. Lots of people fly
down the coast of Florida outside of the class B. Am I the only one who
ever gets an assignment?
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 26th 04 11:24 PM
Progress on Flying Car Steve Dufour General Aviation 5 December 19th 03 03:48 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
