PowerFLARM bug loading FLARMnet DB file into Butterfly
Old September 28th 20, 03:00 PM posted to rec.aviation.soaring
Dave Nadler
Default PowerFLARM bug loading FLARMnet DB file into Butterfly
Hi All - FLARM have confirmed they have a PowerFLARM bug
loading FLARMnet DB file into Butterfly traffic display.
The bug is processing a Butterfly DB (BFN) file with a long filename.
Rename the BFN to something with only 8.3 file name (ie 12345678.BFN) and PowerFLARM will correctly load the BFN into Butterfly.
This bug will be fixed in PowerFLARM version 7.02 (or possibly 7.03).
Separately, it has been reported that latest Butterfly software (4.0 DRN)
sometimes displays HexID and sometimes displays ID from FLARMnet.
If someone can get me a video of that behavior...
Thanks for the help,
Best Regards, Dave
Old January 5th 21, 02:46 PM posted to rec.aviation.soaring
Dave Nadler
Best Regards, Dave
PS: FLARM have confirmed the FLARMnet load bug is fixed in version 7.02
(though not mentioned in the release notes).
Old January 5th 21, 02:51 PM posted to rec.aviation.soaring
Dave Nadler
Default Butterfly sometimes displays hex ID instead of ID from FLARMnet
...it has been reported that latest Butterfly software (4.0 DRN)
Best Regards, Dave
I have found an old bug in the Butterfly software that *may* explain
this behavior. Because of other changes, it may happen more frequently
than old Butterfly versions.
I still need some help, ideally someone who can get video of the old
behavior and then try a fix...
Thanks in advance for any help,
Best Regards, Dave
Powerflarm Butterfly rectangular display [email protected] Soaring 4 September 2nd 15 01:55 AM
FS: Butterfly PowerFlarm 57mm panel display $130 shipped Tango Eight Soaring 1 April 28th 15 10:11 PM
Update your complete PowerFlarm system. Core, Butterfly Display andFlarmNet Database. [email protected] Soaring 5 March 19th 15 06:10 AM
PowerFlarm Butterfly Display not changing range [email protected] Soaring 2 May 1st 14 04:54 PM
Want to talk with Butterfly vario + PowerFlarm people [email protected] Soaring 13 July 8th 13 04:52 PM
