#51
B747 Loses All 4 Generators Due To Clogged Sink In 1st Class Galley
Gig 601XL Builder wrote in
: Bertie the Bunyip wrote: Gig 601XL Builder wrote in : Bertie the Bunyip wrote: Yipes! Braver man than me. A friend is just finishing a Sonerai. It has a mag and electronic ignition. Bertie like. Bertie The Corvair conversion uses single plug per cylinder and dual and separate ignition system. Originally it was two points based ignitions now it is one electronic and one points. If you're interested look at http://www.flycorvair.com/ Ah, OK, I've seen your site a few times. I helped a friend build a corvair powered Piet a looong time ago. He eventaully did finish it BTW. He had a bunch of Corvairs for a while. his daily drive was a beat up old 1961 Monza. It did go! We found an abandoned blower engined one and pulled the engine out of it, planning to put it on the airplane, bu tit would up on the Monza. I remember the bearings for the blower cost more than all the other parts for the rebuild combined. I even raced it once. He was under age and I wasnt when we showed up ( timed event) so I got to drive. It was quick though it was still a four carb engine then! Weird oversteer... AFAIK he flew the Piet with a two carb setup and it went well, but I never got to see it flying.. nice little engine. I would have thought it was too heavy for your airplane though? Bertie As far as weight goes it is just about the same installed weight as an O-200 (which is what the factory built LSA 601XL uses)and that six cylinder runs like an electric motor compared to a Lyc or Cont. 4 cylinder. Well it would! I thought the 601 was a rotax/jabiru type of machine. William Wynne has come up with some modifications since the Piets used the engine that have reduced weight somewhat. For one at least some of the Peits kept the factory colling fan. It's not there in the 601XL install. Mmm, I remember seeing them at OSH like that. I think my friend was going for cub type eyebrows. |
#52
B747 Loses All 4 Generators Due To Clogged Sink In 1st ClassGalley
I thought the 601 was a rotax/jabiru type of machine. The Rotax, Jabiru and O-200 were all FWF options that the factory directly supported. They now list the William Wynne Corvair conversion on their website and have had his plane at their booth at the last two OSH and SnF shows. In fact a guy recently had the DAR inspect his Corvair powered 601XL for an E-LSA certificate and was given only a 5 hour phase I test period because he felt that it was one of the engines that the factory suggested. |
#53
: Bertie the Bunyip wrote: I thought the 601 was a rotax/jabiru type of machine. The Rotax, Jabiru and O-200 were all FWF options that the factory directly supported. They now list the William Wynne Corvair conversion on their website and have had his plane at their booth at the last two OSH and SnF shows. In fact a guy recently had the DAR inspect his Corvair powered 601XL for an E-LSA certificate and was given only a 5 hour phase I test period because he felt that it was one of the engines that the factory suggested. Wow! 5 hours for a car engine? That's amazing! Bertie |
#54
Gig 601XL Builder wrote in : Bertie the Bunyip wrote: I thought the 601 was a rotax/jabiru type of machine. The Rotax, Jabiru and O-200 were all FWF options that the factory directly supported. They now list the William Wynne Corvair conversion on their website and have had his plane at their booth at the last two OSH and SnF shows. In fact a guy recently had the DAR inspect his Corvair powered 601XL for an E-LSA certificate and was given only a 5 hour phase I test period because he felt that it was one of the engines that the factory suggested. Wow! 5 hours for a car engine? That's amazing! I thought it was a little low myself. |
#55
: Bertie the Bunyip wrote: Gig 601XL Builder wrote in : Bertie the Bunyip wrote: I thought the 601 was a rotax/jabiru type of machine. The Rotax, Jabiru and O-200 were all FWF options that the factory directly supported. They now list the William Wynne Corvair conversion on their website and have had his plane at their booth at the last two OSH and SnF shows. In fact a guy recently had the DAR inspect his Corvair powered 601XL for an E-LSA certificate and was given only a 5 hour phase I test period because he felt that it was one of the engines that the factory suggested. Wow! 5 hours for a car engine? That's amazing! I thought it was a little low myself. That's 5 extra on top of th e25 hour fly of, or just five hours for an engine type change? Bertie |
#56
E-LSA rules B747 Loses All 4 Generators Due To Clogged Sink In1st Class Galley
Gig 601XL Builder wrote in : Bertie the Bunyip wrote: Gig 601XL Builder wrote in : Bertie the Bunyip wrote: I thought the 601 was a rotax/jabiru type of machine. The Rotax, Jabiru and O-200 were all FWF options that the factory directly supported. They now list the William Wynne Corvair conversion on their website and have had his plane at their booth at the last two OSH and SnF shows. In fact a guy recently had the DAR inspect his Corvair powered 601XL for an E-LSA certificate and was given only a 5 hour phase I test period because he felt that it was one of the engines that the factory suggested. Wow! 5 hours for a car engine? That's amazing! I thought it was a little low myself. That's 5 extra on top of th e25 hour fly of, or just five hours for an engine type change? Bertie 5 Hours total new airplane, new engine. It is a temporary glitch in the E-LSA rules. Under the rules as they will stand after Jan. 31 of this month an E-LSA can only be a kit built version of a "certified" S-LSA with no significant changes. The 51% rule doesn't apply. In order to get the heavy ULs under the new rules there has been a temporary period where those craft could be grandfathered in under the E-LSA rules even though they don't necessarily meet the E-LSA rules for matching a certified LSA. |
#57
E-LSA rules B747 Loses All 4 Generators Due To Clogged Sink In 1st Class Galley
: Bertie the Bunyip wrote: Gig 601XL Builder wrote in : Bertie the Bunyip wrote: Gig 601XL Builder wrote in : Bertie the Bunyip wrote: I thought the 601 was a rotax/jabiru type of machine. The Rotax, Jabiru and O-200 were all FWF options that the factory directly supported. They now list the William Wynne Corvair conversion on their website and have had his plane at their booth at the last two OSH and SnF shows. In fact a guy recently had the DAR inspect his Corvair powered 601XL for an E-LSA certificate and was given only a 5 hour phase I test period because he felt that it was one of the engines that the factory suggested. Wow! 5 hours for a car engine? That's amazing! I thought it was a little low myself. That's 5 extra on top of th e25 hour fly of, or just five hours for an engine type change? Bertie 5 Hours total new airplane, new engine. Yipes! It is a temporary glitch in the E-LSA rules. Under the rules as they will stand after Jan. 31 of this month an E-LSA can only be a kit built version of a "certified" S-LSA with no significant changes. The 51% rule doesn't apply. In order to get the heavy ULs under the new rules there has been a temporary period where those craft could be grandfathered in under the E-LSA rules even though they don't necessarily meet the E-LSA rules for matching a certified LSA. mmm, OK. That'd make your airplane a bit more valuable, I would think. I've seen a lot of KRs and Sonerais with Corvairs, that cant be such a good idea, eh? They prolly either need a fuse extension or a buttload of lead to make the fly at all. Bertie |
#58
E-LSA rules B747 Loses All 4 Generators Due To Clogged SinkIn 1st Class Galley
mmm, OK. That'd make your airplane a bit more valuable, I would think. If you mean more valuable as a E-LSA sure. If I could get it finished before the end of this month. Which ain't gonna happen. I've seen a lot of KRs and Sonerais with Corvairs, that cant be such a good idea, eh? They prolly either need a fuse extension or a buttload of lead to make the fly at all. Bertie I've flown in one KR2 (here it is http://home.hiwaay.net/~langford/) and seen several others with Corvairs and they are quick. I'm talking 180MPH. I didn't notice any lead and though the one I was in was wider than normal. |
#59
: Bertie the Bunyip wrote: mmm, OK. That'd make your airplane a bit more valuable, I would think. If you mean more valuable as a E-LSA sure. If I could get it finished before the end of this month. Which ain't gonna happen. I've seen a lot of KRs and Sonerais with Corvairs, that cant be such a good idea, eh? They prolly either need a fuse extension or a buttload of lead to make the fly at all. Bertie I've flown in one KR2 (here it is http://home.hiwaay.net/~langford/) and seen several others with Corvairs and they are quick. I'm talking 180MPH. I didn't notice any lead and though the one I was in was wider than normal. He must have made t it at least a bit longer to compensate for the significantly heavier engine, though. Bertie |
Similar Threads | ||||
B747 Loses All 4 Generators Due To Clogged Sink In 1st Class Galley | Larry Dighera | Piloting | 0 | January 10th 08 09:31 PM |
STS-116 Galley area s116e05886.jpg (1/2) | Byron Myers[_2_] | Aviation Photos | 0 | December 23rd 06 06:00 PM |
Removing oil galley plug | Jim Burns | Owning | 43 | November 13th 06 09:42 PM |
vortex generators. | Stew Hicks | Home Built | 2 | July 17th 06 12:56 AM |
Vortex Generators Source | Pietpilot | Home Built | 0 | August 14th 04 10:35 PM |
