Solar Powered Hour Meter
I am thinking about importing some little meters as I think they would be
very valuable to the aviation community as a whole. I am trying to gain a little insight, before I make a large purchase of these meters, whether you guys and gals see a benefit and would be interested in purchasing one for around around $80. They are solar powered UV hour meters, that count the hours it is exposed to UV radiation. They are very thin, about as thin as a uniform patch, and about 3" square. They can be glued , epoxied, or even velcroed to the wing or dash. The meter has an area around it of thick, flexible plastic, like Naugahyde. This facilitates stitching to surface of paraglider wings, which they were originally designed for. I think they would be beneficial to the GA community as well. It has a solar panel at the top and an LCD screen below the panel. When it is exposed to sunlight, it starts counting the minutes to hours. When the plane is hangared or covered, the meter is off, no batteries to change ever. These meters are the smallest UV meters on the market, currently, only offered overseas. At $80, they would be the cheapest UV detectors with the added benefit of an hour meter! Please let me know if you all think it's worth it. Thank you for your time! Also: How about a Universal Low Fuel Warning System! ...with bright flashing LED to alert you when your fuel reaches a predetermined level. I put these kits together for the powered paragliding community but every vehicle without a fuel gauge could certainly use one of these. www.winggear.com |
General aviation fabric is more susceptible to moisture, and goes bad
on the bottom of the fuselage first. There's regular tests of fabric strength in any case, so the additional information about UV exposure isn't likely to be of any use. -- On the internet, nobody knows you're a jerk. |
Similar Threads | ||||
SoLong Solar-Electric UAV 48 hour flight | Larry Dighera | Piloting | 6 | September 25th 16 08:01 PM |
Air Pressure Switch for Hour Meter | NEW-USER | Home Built | 4 | January 22nd 07 01:20 AM |
Solar Electric Powered Aircraft | Larry Dighera | Piloting | 33 | November 6th 05 08:37 PM |
Solar Electric Powered Aircraft | Larry Dighera | Soaring | 31 | November 6th 05 08:37 PM |
Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Soaring | 7 | March 14th 05 07:36 AM |
