Avionics ?
Old August 23rd 03, 01:24 AM
Hankal
Default Avionics ?
VOR frequency 108.6 on flip flop.
On one of my KX 155 I tried to put in 108.6. It would not show as such.
It was something like 109.0 then when I flipped it to the left is showed as
108.6.
Strange and very confusing since I was setting up for the VOR approach.
Avionics shop is closed for the weekend.
Any ideas or solutions??
Hank N 1441p
Old August 23rd 03, 01:47 AM
Teacherjh
108.6.
Might a few bars be out? The lower left bar missing from an 8 looks like a 9,
and if the middle bar is missing from the 6 is is "something like" a 0. What
happens when you put 188.8 (or as close as you can get to lighting up all the
elements)?
Does it get better when it warms up?
Jose
Old August 23rd 03, 07:20 PM
Hankal
108.6.
Went to the plane this morning and the radio worked fine. Maybe it just did not
want me doing the approach.GRRR frustration.
Hank N 1441P
Old August 24th 03, 02:50 AM
Ron Rosenfeld
On 23 Aug 2003 22:45:51 GMT, Stan Gosnell wrote:
(Hankal) wrote in
show as such. It was something like 109.0 then when I
flipped it to the left is showed as 108.6.
VOR approach. Avionics shop is closed for the weekend.
Hank N 1441p
You probably have a segment of the LED burned out. Watch as you
change it, & when you go one click past 107, you're at 108. The
only solution is to change the control head. That's going to be
an expensive LED.
I don't know what model KX155 you have Stan. There are a few different
one's out there. But on mine, the usual cause for the problem the OP
reported is dirty contacts. And the cleaning of them usually takes just a
few minutes. In addition, although I've not had to do it, the numbers can
be replaced separately from the control head.
Old August 25th 03, 06:06 PM
Hankal
be replaced separately from the control head. I called my avionics shop and
they said the same thing. Will fly there tomorrow morning to have them look at
it.
Would hate to have the comm or glideslope crap out on me on a long xc.
Hank N1441P
Vendor recomendation: Stark Avionics Ron Home Built 2 December 8th 04 05:25 PM
Avionics -- superflags Michalk Home Built 5 December 6th 04 06:20 AM
Real World test bed for avionics - Megawatts at Delano MikeremlaP Home Built 0 June 2nd 04 04:24 AM
hardware to mount avionics trays Matthew M. Jurotich Home Built 1 November 17th 03 10:56 PM
Avionics Swap Group Jim Weir Home Built 3 July 7th 03 02:27 PM
