Nicopress Swaging Tool - Availability
Old January 24th 05, 02:11 PM
Bruce A. Frank
I once did the same thing with a pair of bolt cutters. It worked and the
go/no-go gauge said it was correct, but it created a slight half moon
shape on the sleeve. I also took a cheap bolt cutter and brazed parts of
one of the bolt together cheapo tools to the jaws...also worked correctly,
but it looked strange. When I bought the cheapo tool crimping tool from
Home Depot I finally had an acceptable tool...after some minor adjustment.
It is likely the Lowe's tool is exactly the same as the one from Home
Depot.
abripl wrote:
I made one out of a pair of chain cutters with a little bit of welding
and grinding
to get the correct opening size.
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
Old January 26th 05, 05:17 PM
John Kimmel
The Home Depot tool looks slightly less cheap than the Lowes tool. It's
red, the Lowes is green. In both stores I had to search for the tool
myself, calling ahead with the part number and asking salesmen in the
store didn't help. In both cases a flashlight would have helped in the
search. I found them far from the tool cribs, in the area where they
sell cable, tucked into an obscure cubby hole on a bottom shelf.
Your results may vary.
Depot.
and grinding
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Nicopress Swaging Tool - Availability Gary T. Ciampa Home Built 42 February 11th 05 05:49 PM
Nicopress Swaging Tool - Availability - Retraction of Recommendation! Gary T. Ciampa Home Built 0 February 6th 05 12:00 AM
Papco #600 -- Roto-Master Flaring Tool Michael Burton Aviation Marketplace 0 October 27th 03 05:35 PM
FS: Papco #600 Flaring Tool Michael Burton Home Built 0 October 27th 03 05:26 PM
Machine Tool Co. Bankruptcy Sends Ripple Through JSF Program huuto Military Aviation 3 July 29th 03 05:59 AM
