KNS-80 display has gone haywire...
Hello,
Our KNS-80 today wasn't 100%. Infact, for most of the day it was U/S. Here is some background... today was cold...-15C (5F). I turned on the heat in the hangar about 90 minutes before the flight so that the cabin would get warm. Once i started the plane and turned on the avionics master, i noticed that the KNS-80 didn't work right. All the lights behind the numbers were on and flickering... random garbage was just coming on the display and changing about 5 times a second. I left the unit on hoping that perhaps it would "heat up" and that was the problem. After a long taxi the display finally stopped flickering for about 10 minutes. I noticed during that time though that the NAV flag would go in and out even though we were within 10 miles of the VOR. Then all of a sudden, after about 5 minutes in the air, the KNS-80 went back to flickering. The unit seems seated properly -- it hasn't been removed at all. Any thoughts? -Dico |
Dico wrote: Hello, Our KNS-80 today wasn't 100%. Infact, for most of the day it was U/S. Any thoughts? -Dico Condensation? |
I really hope thats al it is.
Taking it out today and we'll see. -dr Dave S wrote: Dico wrote: Hello, Our KNS-80 today wasn't 100%. Infact, for most of the day it was U/S. Any thoughts? -Dico Condensation? |
On Tue, 23 Jan 2007 04:55:19 GMT, Dave S
wrote: Dico wrote: Hello, Our KNS-80 today wasn't 100%. Infact, for most of the day it was U/S. Any thoughts? -Dico Condensation? That would be my thought as well. OTOH those things are getting old! The one in the Deb works pretty good, most of the time. It does not like to set in a cold hangar for a few weeks either. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Jan 22, 1:31 pm, "Dico" wrote: Hello, Our KNS-80 today wasn't 100%. Infact, for most of the day it was U/S. Once i started the plane and turned on the avionics master, i noticed that the KNS-80 didn't work right. All the lights behind the numbers were on and flickering... random garbage was just coming on the display and changing about 5 times a second. Any thoughts? -Dico Hi, My stack has a KNS-80 and the rest of the silver crown radios from circa 1980. My KNS-80 stopped working a couple of years ago, so I had it serviced at my local avionics shop (Freedom Avionics at BJC). In my case, they had to replace the processor, and cost was about $300. In addition to the KNS-80, the plane also has a KN-53 VOR receiver. Last year I had trouble with intermittent display. I tried sliding the radio from the rack and cleaning the connector and reseating, which helped for one flight. I took it in to the shop, and it was a display problem. Apparently this is pretty common with this vintage of Silver Crown radios. It can be opened up, and the connector to the display itself removed, cleaned and tightened. I think this is what the shop did, as they only had labor on the repair invoice (no parts). It was about $200. Good luck and safe flying, Brian |
Dico wrote:
Hello, Our KNS-80 today wasn't 100%. Infact, for most of the day it was U/S. Here is some background... today was cold...-15C (5F). I turned on the heat in the hangar about 90 minutes before the flight so that the cabin would get warm. Once i started the plane and turned on the avionics master, i noticed that the KNS-80 didn't work right. All the lights behind the numbers were on and flickering... random garbage was just coming on the display and changing about 5 times a second. I left the unit on hoping that perhaps it would "heat up" and that was the problem. After a long taxi the display finally stopped flickering for about 10 minutes. I noticed during that time though that the NAV flag would go in and out even though we were within 10 miles of the VOR. Then all of a sudden, after about 5 minutes in the air, the KNS-80 went back to flickering. The unit seems seated properly -- it hasn't been removed at all. Any thoughts? -Dico There are integrated circuits inside the unit seated in sockets. In my KNS-80 similar symptoms were due to bad contact in sockets, so just re-socketing all the socketed IC's helped, and it has worked several years since. -- Tauno Voipio (PA28RT-201T, OH-PYM) tauno voipio (at) iki fi |
Another poster mentioned socketed chips being a problem. Try re-
seating them, and also the connectors between circuit boards. King came up with numerous modifications to deal with problems encountered in the field, and I believe "Mod 10" dealt with contact problems. Your KNS-80 should have a modification record plate on the rear - check to see which ones have been done. Perhaps someone alse out there can furnish a list. If your efforts are not successful, consider picking up a replacement KNS-80 on eBay - it may be cheaper than repairing yours. Quite a few serviceable radios are turning up as people upgrade to whiz-bang color screen boxes. Look for a yellow tagged unit and Mods through at least 10. David Johnson |
Similar Threads | ||||
A-6 Redar Display? | Mike Kanze | Naval Aviation | 0 | September 28th 04 01:34 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
