Solenoid valve
Old October 2nd 17, 02:22 PM posted to rec.aviation.soaring
Default Solenoid valve
My Pegasus tail ballast bag sprung a leak last year. In the process of replacing it, I decided to also change the 12v electric solenoid valve as it was pretty corroded after years of use. The old valve had a 5/16 (.3125") orifice which drained the one gallon bag reasonably quickly. Unfortunately, the only solenoid valves I have been able to find have a much smaller orifice, resulting in a much longer drain time. I think the old valve was a Honeywell unit, but the part number is corroded and unreadable. McMaster and other online searches have not been successful. Any suggestions for a source for a small 12v solenoid valve with a larger flow capacity?
And yes, I realize this was an aftermarket solution and is not supported by Centrair. I have a good A&P and can get the approvals required.
Old October 2nd 17, 07:54 PM posted to rec.aviation.soaring
SF
ASCO is pretty much the industry standard solenoid valve
http://www.asco.com/en-us/Pages/solenoid-valves.aspx
Burkert is another source
https://www.burkert-usa.com/en/products/solenoid-valves
Old October 2nd 17, 09:01 PM posted to rec.aviation.soaring
I have restricted the tail tank flow to match the time it took to drain the wing tanks....that way, I could dump half a load and retain the desired CG........a slow selinoid valve may be more in line with what is needed.
Just a thought,
JJ
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 1 March 30th 11 02:30 PM
Solenoid valve for creating a tail ballast dump system...Lak17a Sean Fidler Soaring 3 March 28th 11 08:51 PM
Ball Valve,Needle Valve,Snubber,Gauge Cock Sale on good price valvetom Piloting 0 November 28th 06 02:32 AM
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price valvetom Piloting 0 November 28th 06 02:25 AM
Stuck starter solenoid? Paul Lee Home Built 4 April 16th 04 02:58 PM
