"The doomsday plane
Old September 15th 07, 03:13 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default "The doomsday plane
Mxsmanic wrote in
Dan writes:
EMP is much less likely to affect a system that is not powered up.
Why? EMP can vaporize conductors whether they are energized or not.
So what, fjukktard
you have no idea how an airplane works, do you?
Bertie
  #32
Mxsmanic wrote in
Dave S writes:
Google EMP, or look it up in the WIKI, and understand what it does to
non-protected electrical systems and generating systems then re-visit
your answer. Back ups are no good if they all drop offline from the
original EMP.
A sufficiently large EMP will fry anything.
Stand too close to a source, did you?
Bertie
  #33
Old September 15th 07, 03:57 AM posted to rec.aviation.piloting
Morgans[_2_]
We should be so lucky! :-(
Jim in NC
  #34
Old September 15th 07, 05:38 AM posted to rec.aviation.military,rec.aviation.piloting
John Keeney
On Sep 14, 8:47 pm, Mxsmanic wrote:
writes:
Seems pretty clear that it was an E4 called on alert by NORAD. What
is so surprising about that?
It's surprising that the DoD doesn't admit it. What's the harm in doing so,
especially when it is so obviously that aircraft?
General principles, never verify *ANYTHING* having to do with that
plane.
It does strike as a bit odd though, I would have thought SOP would
keep it a outside of the blast zone of a DC nuke attack. George ride
it back to DC instead of the VC-24 perhaps?
  #35
Old September 15th 07, 12:47 PM posted to rec.aviation.military,rec.aviation.piloting
Mxsmanic
John Keeney writes:
If the terrorists had had nukes, they wouldn't have bothered with flying
planes into buildings, so it was a safe bet that they didn't have them.
  #36
Old September 15th 07, 03:07 PM posted to rec.aviation.military,rec.aviation.piloting
Leadfoot[_2_]
"John Keeney" wrote in message
writes:
so,
plane.
The Boeing 747 VC-25 is basically an E-4B converted for presidential travel.
It has the same EMP protection as the E-4B however the communications are
as robust as an E-4B
  #37
Old September 15th 07, 03:15 PM posted to rec.aviation.military,rec.aviation.piloting
mike Z
On Sep 13, 11:01 pm, Dave S wrote:
Leadfoot wrote:
Actually the 747 has numerous back-up power systems. When there is a
problem with electrical generation a load shedding system kicks in. The
first electrical buss to be shedded is the passenger cabins.
original EMP.
Already taken care of.
Picture of an E-4B being tested in an EMP generator (test facility).
http://en.wikipedia.org/wiki/Image:E...st_EMP_sim.jpg
  #38
Old September 15th 07, 04:59 PM posted to rec.aviation.military,rec.aviation.piloting
Leadfoot[_2_]
"Leadfoot" wrote in message
writes:
so,
plane.
travel. It has the same EMP protection as the E-4B however the
communications are as robust as an E-4B
Correction
communications are NOT as robust as an E-4B
  #39
Old September 15th 07, 10:13 PM posted to rec.aviation.military,rec.aviation.piloting
Mxsmanic
mike Z writes:
Interesting. I see what looks like fuel being loaded into the aircraft. I
wonder if they tried testing the EMP while the fuel was being taken on.
  #40
Old September 15th 07, 10:45 PM posted to rec.aviation.military,rec.aviation.piloting
In rec.aviation.piloting Mxsmanic wrote:
mike Z writes:
747s aren't fueled by carrying 5 gal cans up the stairs.
If they were fueling, there would be a big ass truck next to the plane.
Jim Pennino
Remove .spam.sux to reply.
Saw President Bush's plane (response to "Saw J.T.'s Plane") Ricky Piloting 60 September 1st 07 09:25 PM
Jay's "Plane Crash Video Ubersite" Peter Duniho Piloting 18 August 14th 06 05:45 AM
Have you created anything "home-made" for your plane? (or a low cost alternative?) Andy Piloting 69 April 29th 06 03:25 PM
Have you created anything "home-made" for your plane? (or a low cost alternative?) Andy Owning 61 April 29th 06 03:25 PM
