Differences in O-540 models
Old August 3rd 08, 10:45 PM posted to rec.aviation.owning,rec.aviation.piloting
Charles Talleyrand
Default Differences in O-540 models
I read that the O-540-A1A5 weighs 396 pounds, but that a IO-540-A1A5
weighs 437 pounds. Can the difference between a carb and fuel
injection really be 39 pounds?
Also, as I wrote an IO-540-A1A5 weighs 437 pounds. But an IO-540-c4b5
weighs 402 pounds, but produces 50 horsepower less. What did they
change about the engine that costs 50 horsepower but saves 35 pounds?
-Very Curious
-Charles Talleyrand
Old August 3rd 08, 10:55 PM posted to rec.aviation.owning,rec.aviation.piloting
Steven P. McNicoll[_2_]
Or 41 pounds?
Old August 3rd 08, 11:34 PM posted to rec.aviation.owning,rec.aviation.piloting
Mike[_22_]
"Charles Talleyrand" wrote in message
I'm not familiar with the exact models in question, but some installations
require things like starter adapters, which add weight. Some engines are
also derated based on the application. The IO-540-AB1A5 used in the new
182s is a 230 BHP engine because it's limited to 2400 RPM. Other 540s put
out as much as 315 BHP.
Old August 4th 08, 01:19 AM posted to rec.aviation.owning,rec.aviation.piloting
Charles Talleyrand
I actually knew all that. But why would the engine weigh more?
Lowering the RPM does not add weight.
Old August 4th 08, 02:04 AM posted to rec.aviation.owning,rec.aviation.piloting
Mike[_22_]
installations
put
As I said, some applications require extra parts like a starter adapter.
That alone weighs 40 lbs or so if I were to guess. I'm not sure if Lycoming
engines need a starter adapter, but it could be some other accessory or
necessary part needed or desired in one application but not another.
DG Differences... noel.wade Soaring 39 April 22nd 08 06:42 AM
Rep vs. Dem Differences Jim Weir Piloting 212 September 8th 04 04:02 PM
ASW 20, ASW 20B, ASW 20C DIFFERENCES Ventus B Soaring 8 July 18th 04 10:28 AM
Differences between Garmin 295 and 196? carlos Owning 17 January 29th 04 08:55 PM
Differences in models of Foster500 loran Ray Andraka Owning 1 September 3rd 03 10:47 PM
