Making a Canopy
On Tuesday, January 21, 2014 3:21:41 PM UTC-5, Guy B wrote:
I have a glider, a canopy frame, and a new plastic canopy, and now my problem is making them all come together into a functioning unit. I've searched this site, and found a bit of info, but still really need some detailed instruction on fastening the plastic to the frame. I know the frame has to be fitted to the glider first, and the plastic cut, fitted, and glued to the frame, while in place on the glider. I understand that screws aren't necessary, and may in fact cause trouble. I think I need a fine tooth circular saw, and grinder, some way of clamping, a specific adhesive and info on how to use it. I can't do any of this, but will be working with an experienced aircraft engineer, who is willing to give it a try. Any help from this community would be appreciated. Or pointers to some place or person who can assist. Thanks, Guy Kestrel 19 CF-FGR PLEASE PLEASE PLEASE get help from a professional, or send it to a professional. this is a detail oriented process and they can go horribly wrong. a canopy is too expensive to risk it. you have to think about fitting it properly, not having glue overflow, not accidentally gluing the frame to the glider, painting it so that it doesn't look awful et. cetera... the list of potential problems goes on an on. |
Making a Canopy
On Wednesday, January 22, 2014 1:14:01 PM UTC-5, Andrew Brayer wrote:
On Tuesday, January 21, 2014 3:21:41 PM UTC-5, Guy B wrote: I have a glider, a canopy frame, and a new plastic canopy, and now my problem is making them all come together into a functioning unit. I've searched this site, and found a bit of info, but still really need some detailed instruction on fastening the plastic to the frame. I know the frame has to be fitted to the glider first, and the plastic cut, fitted, and glued to the frame, while in place on the glider. I understand that screws aren't necessary, and may in fact cause trouble. I think I need a fine tooth circular saw, and grinder, some way of clamping, a specific adhesive and info on how to use it. I can't do any of this, but will be working with an experienced aircraft engineer, who is willing to give it a try. Any help from this community would be appreciated. Or pointers to some place or person who can assist. Thanks, Guy Kestrel 19 CF-FGR PLEASE PLEASE PLEASE get help from a professional, or send it to a professional. this is a detail oriented process and they can go horribly wrong. a canopy is too expensive to risk it. you have to think about fitting it properly, not having glue overflow, not accidentally gluing the frame to the glider, painting it so that it doesn't look awful et. cetera... the list of potential problems goes on an on. My friend JJ used to call stuff like this "do it yourself brain surgery". UH |
Making a Canopy
Please make a video; we are all looking forward to
seeing the demolition on YouTube... |
Making a Canopy
On Wednesday, January 22, 2014 1:00:27 PM UTC-8, Dave Nadler wrote:
Please make a video; we are all looking forward to seeing the demolition on YouTube... Just be glad you're not doing a Libelle or something where you can't lay the canopy blank over the cockpit to mark something close to the net shape. The biggest problem with canopy work is the high cost of failure. The advice to work with warm materials, use an abrasive cut-off wheel and have the frame locked down on the fuselage when mounting the plastic is critical. Beyond that it's just a myriad of details. Hope all goes well, Craig |
Making a Canopy
What a great response! I was away for a while and just signed on again. The words of wisdom and caution are greatly appreciated. I'll show all comments to the aircraft engineer that thinks he might be able to do it. I expect we'll be looking for that special someone who has some good experience. Thanks again. Guy Living in Alberta and Nevada |
Making a Canopy
On Sunday, January 26, 2014 1:49:10 PM UTC-8, Guy B wrote:
What a great response! I was away for a while and just signed on again. The words of wisdom and caution are greatly appreciated. I'll show all comments to the aircraft engineer that thinks he might be able to do it. I expect we'll be looking for that special someone who has some good experience. Thanks again. Guy Living in Alberta and Nevada Guy, I see you live in Nevada some of the time. If you fly Minden, I would be glad to cover the do's and don'ts of cutting, drilling, gluing and painting a replacement canopy. Look for a bat looking sailplane with JJ on the fin and introduce yourself. JJ |
Similar Threads | ||||
Making the best of MiG-21 | adriann atenborrough | Military Aviation | 1 | July 16th 10 08:11 AM |
making a comeback | Capt. Geoffrey Thorpe | Piloting | 3 | June 30th 10 02:11 AM |
making money | william[_2_] | Home Built | 2 | July 19th 07 11:53 PM |
On making it difficult for everyone else | Frank Whiteley | Soaring | 35 | May 8th 07 05:52 PM |
Making your own canopy | c hinds | Home Built | 6 | November 22nd 04 09:10 AM |
