Accuracy of GPS in Garmin 430/530
Is there any way to have the Garmin 430/530 put its current display accuracy
on the primary display as an ongoing statistic, based on the number of satellites in view? How, in general, do the Garmin units notify you of situations where GPS accuracy has been compromised to a level that makes it unsafe to use the Garmin for a GPS approach? I got an interesting lesson in GPS recently while traveling with a handheld GPS as the passenger in a plane. The GPS showed us landing about two miles east of the airport. I figured out only later that the position of the antenna was such that many satellites were blocked, so the accuracy of the GPS signal was greatly diminished. The particular software I was using didn't display its current accuracy on the primary display. Based on that event, I realize I cannot just trust a GPS display without first understanding the current accuracy of the signal. What would be really nice is if the primary display would show vertical and horizontal accuracy as two separate numbers, based on some high confidence interval (99.99+%). Knowing that the current display reading is accurate to 10 ft vertical and 15 ft horizontal, for example, might make you a lot more comfortable in following a GPS approach than a display where the 99.99% confidence interval is 2000 ft vertical/horizontal (i.e., GPS reliability is completely compromised by virtue of blocked satellites, bad GPS antenna, etc). -- Will |
Will wrote:
Is there any way to have the Garmin 430/530 put its current display accuracy on the primary display as an ongoing statistic, based on the number of satellites in view? How, in general, do the Garmin units notify you of situations where GPS accuracy has been compromised to a level that makes it unsafe to use the Garmin for a GPS approach? I got an interesting lesson in GPS recently while traveling with a handheld GPS as the passenger in a plane. The GPS showed us landing about two miles east of the airport. I figured out only later that the position of the antenna was such that many satellites were blocked, so the accuracy of the GPS signal was greatly diminished. The particular software I was using didn't display its current accuracy on the primary display. Based on that event, I realize I cannot just trust a GPS display without first understanding the current accuracy of the signal. What would be really nice is if the primary display would show vertical and horizontal accuracy as two separate numbers, based on some high confidence interval (99.99+%). Knowing that the current display reading is accurate to 10 ft vertical and 15 ft horizontal, for example, might make you a lot more comfortable in following a GPS approach than a display where the 99.99% confidence interval is 2000 ft vertical/horizontal (i.e., GPS reliability is completely compromised by virtue of blocked satellites, bad GPS antenna, etc). Do some geocaching in pine forests. You'll see the effect of the trees. They just cut off the signal and no updates happen for awhile. You keep on the indicated heading and then all of a sudden the gps catch a few bits and the arrow flips to a completely new direction! The gps jocks I've talk to state things like "gps is within 10 meters 95% of the time". I presume that means the gps has a signal. When it's not getting a signal, I don't think there is much you can say. |
In a previous article, "Will" said:
Is there any way to have the Garmin 430/530 put its current display accuracy on the primary display as an ongoing statistic, based on the number of satellites in view? How, in general, do the Garmin units notify you of situations where GPS accuracy has been compromised to a level that makes it unsafe to use the Garmin for a GPS approach? Google up the term "RAIM warning". All approach certified GPSes have to warn you if the accuracy is degraded. -- Paul Tomblin http://xcski.com/blogs/pt/ "You are a human being, capable of emotions and rational thought. A computer is only capable of floating point math and crude malice." http://www.hamsterrepublic.com/james/technomancy/ |
... Google up the term "RAIM warning". All approach certified GPSes have to warn you if the accuracy is degraded. I assumed as much, which is why I wanted to know how that condition is displayed on the Garmin 430/530. It may just be personal preference, but I see a lot of value in user interfaces that make the data quality a primary display attribute at all times. That way I not only know I have a GPS signal, but I can quickly assess the quality of the signal. I see value in making this more than just a binary state ("good enough for the FAA" GPS signal quality / "not good enough for the FAA" GPS signal quality). Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. -- Will |
Will wrote:
Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. It does.. as previously stated... you get a RAIM warning. All you need to know is "is the signal performing to a legal/safe standard" or not. "Good enough for the FAA" is what counts when you are considering the purpose of a GPS guided instrument approach. Adding the percentage parameters you envision is just the sort of thing to add workload to a single pilot IFR approach to minimums. One more thing to monitor.. Instead, I think the Feds got it right.. either its GOOD or its BAD. Period. Dave |
"Will" wrote:
It may just be personal preference, but I see a lot of value in user interfaces that make the data quality a primary display attribute at all times. That way I not only know I have a GPS signal, but I can quickly assess the quality of the signal. I see value in making this more than just a binary state ("good enough for the FAA" GPS signal quality / "not good enough for the FAA" GPS signal quality). Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. I disagree. We already have information overload. A binary "go/no-go" is exactly what you want. If I told you that the SNR from satellite 17 was down 6dB, what would you do with that information? RAIM factors in signal strength as well as satellite geometry. To get a good fix, you need to be getting a good signal from 4 satellites positioned appropriately in both azimuth and elevation. Figuring out if the signal strength and geometry is "good enough" is not the kind of problem people can do in their heads. |
Roy Smith wrote:
"Will" wrote: It may just be personal preference, but I see a lot of value in user interfaces that make the data quality a primary display attribute at all times. That way I not only know I have a GPS signal, but I can quickly assess the quality of the signal. I see value in making this more than just a binary state ("good enough for the FAA" GPS signal quality / "not good enough for the FAA" GPS signal quality). Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. I disagree. We already have information overload. A binary "go/no-go" is exactly what you want. If I told you that the SNR from satellite 17 was down 6dB, what would you do with that information? RAIM factors in signal strength as well as satellite geometry. To get a good fix, you need to be getting a good signal from 4 satellites positioned appropriately in both azimuth and elevation. Figuring out if the signal strength and geometry is "good enough" is not the kind of problem people can do in their heads. I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator |
John Theune wrote:
.. I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. Page 4 of the nav section. |
On 04/25/06 05:03, John Theune wrote:
Roy Smith wrote: "Will" wrote: It may just be personal preference, but I see a lot of value in user interfaces that make the data quality a primary display attribute at all times. That way I not only know I have a GPS signal, but I can quickly assess the quality of the signal. I see value in making this more than just a binary state ("good enough for the FAA" GPS signal quality / "not good enough for the FAA" GPS signal quality). Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. I disagree. We already have information overload. A binary "go/no-go" is exactly what you want. If I told you that the SNR from satellite 17 was down 6dB, what would you do with that information? RAIM factors in signal strength as well as satellite geometry. To get a good fix, you need to be getting a good signal from 4 satellites positioned appropriately in both azimuth and elevation. Figuring out if the signal strength and geometry is "good enough" is not the kind of problem people can do in their heads. I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator The OP was asking why this can't be displayed on the main page... You snipped it from your response. Here it is: Is there any way to have the Garmin 430/530 put its current display accuracy on the primary display as an ongoing statistic, based on the number of satellites in view? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
"John Theune" wrote in message news:Udo3g.5009$bU6.3635@trnddc06... I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator You are right all GPS software usually implements a satellite signal page. It's not in any way shape or form what I asked for. I want the GPS to take all of the inputs for number of satellites and signal strength and derive from that just two integers: 1) Number of feet/meters of horizontal accuracy, within some confidence interval (e.g., 99.95%) 2) Number of feet/meters of vertical accuracy, within some confidence interval (e.g., 99.95%) Those two numbers could become optional numbers for the primary display. No one is forcing anyone to use them. If you want to simply trust the instrument to give you a go-nogo decision, it's your life and if you feel that is safe it's a free world (as long as you follow FAA rules ) so be my guest. For my personal taste, I understand that a GPS display is always an illusion subject to different levels of inaccuracy. I am sensitive to the difference between a display that is showing me accuracy to 10 ft, 100 ft, or 1000 ft. In the original posted example the GPS was off target by more than 5000 ft. Nothing on the original display gave me any clue that this was the case. The two numbers I am asking for would communicate quite succinctly that no one should rely on the display for anything other than the most gross kind of positioning. While I would love to see the feature I am looking for in any FAA-compliant instrument like a Garmin 530, I think the feature becomes most critical in non-FAA compliant GPS devices/software. The authors of such packages cannot control the quality of the satellite antenna, or mounting, and substandard GPS reception is probably a routine thing for PDA based GPS devices/software. So finding a succinct way to communicate the accuracy of the current signal in numbers that mean something to any user becomes quite important. Making people look at satellite maps and signal strength seems like a pure engineering exercise, and it doesn't collapse the input data into a useful form. -- Will |
Similar Threads | ||||
Garmin backing away from additional GDL-69 features for 430/530 products? | Andrew Gideon | Owning | 2 | September 9th 05 11:36 PM |
Inexpensive Garmin 430/530 question | vlado | Owning | 2 | May 19th 05 03:21 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 09:04 PM |
