LS 8A Aileron Removal
Old January 25th 19, 11:45 PM posted to rec.aviation.soaring
svelusive
Default LS 8A Aileron Removal
According to the LS 8 Manual to remove the ailerons you loosen the 10mm nut on the fixed bearing #3. I can't see any way to get a wrench, socket into the nut. Is there a special tool required?
Old January 26th 19, 03:06 AM posted to rec.aviation.soaring
Easy answer is to take a 10mm open-end wrench, then grind it down until it will slip in there. Probably only get 1/8th turn per stroke!
JJ
Old January 26th 19, 03:46 PM posted to rec.aviation.soaring
JJ
Yes you will need to do what JJ said. Took me 6 trips to the grinder to get the wrench ground down enough and even then it was only about 1/8th turn per stroke.
Also had to do the same to a socket to get the rudder nut off.
Tony
Old January 26th 19, 04:49 PM posted to rec.aviation.soaring
svelusive
Thanks guys!
It sure is great having this resource. Saves a lot of time, energy and stress.
Gel coat removal - is this okay?!? Kevin Christner Soaring 13 July 10th 15 03:44 PM
Rust removal? noel.wade Soaring 22 March 2nd 09 06:22 AM
Adhesive removal [email protected] Soaring 8 May 2nd 06 02:37 PM
PA28 140 starter removal George Hamilton Owning 2 October 31st 04 05:07 PM
Radio Removal MRQB Owning 14 March 24th 04 11:30 PM
