MD26-28 400Hz inverter - not very reliable
Old February 18th 05, 05:07 PM
Tim Shoppa
Default MD26-28 400Hz inverter - not very reliable
Peter wrote:
I've had two of the above fail in under 3 years.
I would guess that the failures are related to adverse voltages
coming in or an adverse load on the output. The electrical
environment of a small plane can actually be much more abusive
than a modern car, because of the wide varieties of load dumps.
Both units developed an intermittent, vibration-related, fault (no
400Hz output) which is curious since they are potted and not a lot
can
move about.
How is it "vibration-related"? Stops working in some positions or
in vibrating environments? Power semiconductor packaging can fail
intermittently due to things you cannot see, it's (as I understand it)
mostly related to repetitive thermal expansion/contraction.
Tim.
How Reliable Is Your Panel? Chip Bearden Soaring 8 October 7th 04 05:36 PM
