Beech Skipper
I posted before about buying an inexpensive aircraft and got good
information from this group - thanks. I've been looking locally, Philadelphia area, for a good aircraft in the $30k range. I found a very nice Skipper for less than my budget ~ 27k. I never considered one before. I flew it earlier today and I have to admit that I enjoyed it. The limitations of the skipper are slow, doesn't have much useful load, doesn't climb real well, and Beech parts are expensive. On the plus side, Beech quality, modestly IFR with a 155, garmin audio panel, garmin VFR 250, intercom, low time, 2000 hours, recent engine, 400 SMOH, very good paint/interior, 6 GPH, excellent visibility and unlike the rental fleet - everything works!! I've been thinking hard about what I really need. Most of my trips are less than 200 miles so the lack of speed and range are not problems. I almost always fly solo so the weight limitations are okay. I have my IFR rating but I intend to use it for VFR flights and to maintain currency for IFR (I can rent more capable planes if I really need to). If I accept all of the limitations, are there any problems with these little ships? I haven't found any crazy ad's or sb's. Are there any odd problems with handling? For my first aircraft, I'd like something that isn't going to drive me nuts with repairs. Thanks Dave |
I did my PPL in three skippers. They are nice and light on the controls
and don't have any really nasty habits (they can even be used for spin training, although it takes a bit of work to make it spin). It does have a T tail, so you might have to get used to not having any pitch authority at low speeds, but if you let the plane fly itself off the runway that should not be a problem. They are solid aircraft, and having the two doors with a low wing is nice. The only maintenance thing I recall seeing as a recurrent problem was the ABS wingtips were perennially cracking. Also, the fuel selector is a simple both/off selector and if the fuel vents are misaligned you can get an uneven fuel burn from the two tanks. As I recall, the climb wasn't all that bad. The Sundowner I flew after I got my PPL had less climb at max gross. Even over gross on a hot day in New England, the skipper did OK in the climb. Full fuel doesn't leave enough remaining useful load for two FAA adults, but the plane performs fine there anyway. In fact, I was over max gross by about 25 lbs for my PPL checkride because the previous person had filled the tanks the night before (I made the DE aware of it and we flew anyway). At 90kts, you won't get anywhere in a big hurry, but it is a great plane for training, relatively local travel and low and slow touring. Dave wrote: I posted before about buying an inexpensive aircraft and got good information from this group - thanks. I've been looking locally, Philadelphia area, for a good aircraft in the $30k range. I found a very nice Skipper for less than my budget ~ 27k. I never considered one before. I flew it earlier today and I have to admit that I enjoyed it. The limitations of the skipper are slow, doesn't have much useful load, doesn't climb real well, and Beech parts are expensive. On the plus side, Beech quality, modestly IFR with a 155, garmin audio panel, garmin VFR 250, intercom, low time, 2000 hours, recent engine, 400 SMOH, very good paint/interior, 6 GPH, excellent visibility and unlike the rental fleet - everything works!! I've been thinking hard about what I really need. Most of my trips are less than 200 miles so the lack of speed and range are not problems. I almost always fly solo so the weight limitations are okay. I have my IFR rating but I intend to use it for VFR flights and to maintain currency for IFR (I can rent more capable planes if I really need to). If I accept all of the limitations, are there any problems with these little ships? I haven't found any crazy ad's or sb's. Are there any odd problems with handling? For my first aircraft, I'd like something that isn't going to drive me nuts with repairs. Thanks Dave -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
I thought about the 140 and have looked at one. That particular
airplane needed too much work. Luckily, the advice of this group talked me out of it. I haven't found any 140's in my area that are worth persuring. Most of the one's I have found are really tired old birds. I don't have time for a fixer-upper. The partnership idea is not for me. Thanks for the advice. Dave |
I like the Skipper, but you need to look into the availability of the
parts. Since there wasn't many made (around 280), the aircraft are worth more at the junkyard than in the air. Not too long ago, I saw one being dismantled at one of the salvage yards. When I asked what sealed its fate, the owner said that there was nothing wrong with it, they just needed the parts for the customers. On 20 Jul 2003 21:25:36 -0700, (Dave) wrote: I thought about the 140 and have looked at one. That particular airplane needed too much work. Luckily, the advice of this group talked me out of it. I haven't found any 140's in my area that are worth persuring. Most of the one's I have found are really tired old birds. I don't have time for a fixer-upper. The partnership idea is not for me. Thanks for the advice. Dave |
On 20 Jul 2003 21:25:36 -0700, Dave wrote:
I thought about the 140 and have looked at one. That particular airplane needed too much work. Luckily, the advice of this group talked me out of it. I haven't found any 140's in my area that are worth persuring. What kind of 140 - the proper sort (Cessna) or the nosedragger sort (Piper)? :-) There's a good type club if you're after the Cessna one which has quite a few 'for sale' ads. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Similar Threads | ||||
Beech Starship? SpaceShipOne? | DunxC | Military Aviation | 7 | June 22nd 04 08:03 PM |
Beech dual yoke w/rams horns/color preference | Dan Karshin | Aviation Marketplace | 1 | March 28th 04 05:04 PM |
Beech Robie Prop | Joe Spencer | Home Built | 1 | February 26th 04 10:49 PM |
OT- beech starships still flying? | patrick mitchel | Home Built | 6 | November 30th 03 03:30 AM |
Price of pre-owned Beech 1900C or Beech 1900D | Alex Koshy | General Aviation | 4 | October 12th 03 03:25 PM |
