FAA PPL night flight requirement - does it have to be DUAL?
This might be nitpicky, but nothing in the AIM is a
"requirement". Technically the AIM is not the law, the FAR is. Nonetheless, the AIM is incredibly important - I know. It seems subtle, doesn't it? |
On Wed, 13 Oct 2004 13:11:00 +0100, Peter
wrote: Reading FAR/AIM 2004 it isn't entirely clear to me because different sections refer to day and night cross country, and I don't think the description of a day cross country applies to the night flight; the distances are 150nm and 100nm respectively. I have night flights with an instructor which exceed 100 miles in total distance, and I have a solo night flight which exceeds 100nm which was done between two airports whose direct line spacing is 119nm. I suspect that the information on the basis of which I did the last flight was bogus and I don't meet the FAA PPL requirement. Can anyone suggest the FAR/AIM 2004 sections which could clarify this? You want the FAR, 61.109(a), paragraphs 2 and 2(i) - "Except as provided in 61.110 of this part, 3 hours of night flight training in a single-engine airplane that includes (i) One cross country flight of over 100 nautical miles total distance; and (ii) 10 takeoffs and 10 landings to a full stop (with each landing involving a flight in the traffic pattern) at an airport." You meet the night cross country requirement with either flight listed above. There's no requirement for a solo night cross country of any distance in the regs. If you've done 10 night takeoffs and landings you meet the requirements for that part of the reg. The long solo cross-country (150nm) is 61.109(a)(5)(ii) - 150nm, 3 stops, one segment of which needs to be between 2 airports 50NM apart. If you happened to do this at night, great - the reg doesn't say it has to be done during the day, but the solo flight mentioned above doesn't count unless it was over 150NM (the 119NM apart meets the 50NM distance, but not the total flight distance and 3 landings). Luck, P |
"Peter" wrote in message news Reading FAR/AIM 2004 it isn't entirely clear to me because different sections refer to day and night cross country, and I don't think the description of a day cross country applies to the night flight; the distances are 150nm and 100nm respectively. I have night flights with an instructor which exceed 100 miles in total distance, and I have a solo night flight which exceeds 100nm which was done between two airports whose direct line spacing is 119nm. I suspect that the information on the basis of which I did the last flight was bogus and I don't meet the FAA PPL requirement. Can anyone suggest the FAR/AIM 2004 sections which could clarify this? The solo night flight counts only if your instructor has conducted the required training for student solo night flight required by FAR 61.87(o) and specifically endorsed your logbook for student solo night flight; otherwise the flight was illegal and cannot be used for meeting any aeronautical experience requirements. FAR 61.109(a)(2)(i) says that your night training must include a night cross country of 100 miles total distance. Since this is training, not solo, your instructor must go with you. You must also have a solo cross country flight of 150 miles total distance, with three full stop landings and one segment between stops at least 50 miles long, per FAR 61.109(a)(5)(ii). This flight could be conducted at night if your instructor has signed you off for solo night flight, but few instructors will allow that and most students do the flight during the day. |
distance, with three full stop landings and one segment between stops at least 50 miles long, per FAR 61.109(a)(5)(ii). This flight could be conducted at night if your instructor has signed you off for solo night flight, but few instructors will allow that and most students do the flight during the day The XC landings need to be full stop? Oops... |
"Bob Martin" wrote in message
... You must also have a solo cross country flight of 150 miles total distance, with three full stop landings and one segment between stops at least 50 miles long, per FAR 61.109(a)(5)(ii). This flight could be conducted at night if your instructor has signed you off for solo night flight, but few instructors will allow that and most students do the flight during the day The XC landings need to be full stop? Oops... I almost got that wrong too during my primary training. I made one stop for fuel, but at the second airport I'd planned to do a touch and go (as I'd done on my training XCs and my two practice solo XCs). I hadn't reviewed the appropriate regulation, and my instructor didn't catch the problem either during the pre-flight briefing. Luckily, for some reason, the tower was only able to accommodate full-stop landings at the time. --Gary |
fuel, but at the second airport I'd planned to do a touch and go (as I'd done on my training XCs and my two practice solo XCs). I hadn't reviewed the appropriate regulation, and my instructor didn't catch the problem either during the pre-flight briefing. Luckily, for some reason, the tower was only able to accommodate full-stop landings at the time. Well, mine was two and a half years ago... don't think it really matters anymore. And come to think of it, I never made a full-stop at a towered field either... so I don't know how to talk to ground (and haven't flown out of/landed at a towered field since the long XC in my training). |
Bob Martin wrote in message ...
Well, mine was two and a half years ago... don't think it really matters anymore. And come to think of it, I never made a full-stop at a towered field either... so I don't know how to talk to ground (and haven't flown out of/landed at a towered field since the long XC in my training). I can see how you could get by with a T & G on the cross-country, depending on how you logged it. In fact, full stop landings on the long XC have not always been required. When I did mine in '88, I did a T&G at one airport. Back then, the reg only required that you "land" at the other airports. I can't remember when it changed. I am surprised that you made it past the DE without 3 full-stop landings at a towered field. It's a clear requirement and they usually check those off on a checklist while going through your logbook. John Galban=====N4BQ (PA28-180) |
Similar Threads | ||||
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
