Boeing 757 turn rate?
Old June 4th 04, 05:57 PM
Garyurbach
Default Boeing 757 turn rate?
Can anybody here tall me what the standard rate of turn is in a 757? Is it the
same as small palnes, i.ei, is it universal at 360 degrees in 2 minutes?
I've got someone telling me the Boeing 757 that hit the Pentagon did some
impossible turn before flying into the building, and it sounds like a turnign
decent to me.
Any help would be appreciated.
Old June 7th 04, 05:48 PM
Darrell
Standard rate turns are seldom used in modern aircraft with flight directors
and autopilots with turn/bank angle control. You set your flight guidance
for the bank angle you choose, normally 30 degrees unless you are below
maneuvering speed (takeoff & final approach). You get the rate of turn that
your true airspeed will produce at that bank angle. About the only time you
would use a standard (or half-standard) rate of turn would be when you
needed to do a timed turn due to heading failure.
B-58 Hustler History: http://members.cox.net/dschmidt1/
"Garyurbach" wrote in message
turnign
decent to me.
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Boeing 757 turn rate? Garyurbach Aerobatics 6 June 14th 04 04:43 PM
Maximum Sustained Turn Rate? Emilio Military Aviation 5 May 11th 04 03:12 AM
AOPA and ATC Privatization Chip Jones Instrument Flight Rules 139 November 12th 03 08:26 PM
