T-88 epoxy
Old December 4th 06, 10:36 PM posted to rec.aviation.homebuilt
Lou
Default T-88 epoxy
Ok, so you build a wooden airplane, and it actually flies. You park it
for the winter and the temp
gets down below zero, alot....
Does this hurt the T-88 epoxy glue? Would the constant below zero temp
to close to 100
each six months do any damage or weekness?
Lou
Old December 4th 06, 11:15 PM posted to rec.aviation.homebuilt
Default T-88 epoxy
Dear Lou,
The basic answer is 'no.' But only when a host of assumptions are
valid, such as promising to never dip your zero-degree-cold wooden
airplane into boiling water and so forth.
That isn't a joke, by the way. Marvelous as epoxies are they don't
even come close to resorcinol when it comes to durability. The FPL has
a number of papers on this subject. (Using FPL-16A as part of the seed
will help narrow down the search.)
But on the whole, once the bond has formed and the structure sealed,
low temperatures are not a problem.
-R.S.Hoover
Certificated a/c, inexpensive epoxy primer, autobody? Michael Horowitz Home Built 8 October 23rd 06 06:36 PM
Preserving Epoxy (Epoxicles ???) steveukman Home Built 13 September 1st 06 09:22 PM
Epoxy Bonding to Aluminum and Magnesium Ryan Young Home Built 25 September 16th 04 02:45 AM
Question about epoxy resin chemistry.. Chris Home Built 26 April 15th 04 12:55 AM
