Dual tow rings
Old November 28th 09, 01:06 AM posted to rec.aviation.soaring
brianDG303[_2_]
Default Dual tow rings
On Nov 27, 2:15*pm, "Tim Mara" wrote:
there is only one type of "approved" tow rings set..these are from TOST (I
have them) don't know how it is possible to lose one of these rings..not if
they are the "approved" types...
but they are sold as ring pairs only
even on my website there is a warning regarding tow rings:http://wingsandwheels.com/page30.htmdirectly from TOST
WARNING!
Recently, connecting ring pairs that do not comply with the LN 65091
standard have begun to appear on the German market. All type-approved tow
releases may be used only with a connecting ring pair that complies with the
1985 edition of this standard (Section 2.6 LBA-approved Operating Manual)..
The ring pairs (presumably from Egger) are welded - this is explicitly
prohibited by LN 65091. They are not correctly dimensioned and will not
operate reliably with Tost tow releases. However, these ring pairs are even
being used in flying schools, sometimes with a "certificate of approval"
from the manufacturer.
These non-approved ring pairs damage the leading edges of the tow releases
and can cause the ring to jam in the tow release so that the release cannot
be activated.
It is to be expected that Germany will start seeing damage to tow releases
and problems with their operation similar to that already happening in the
Netherlands.
You should give some thought to the following points:
* a.. If a release cannot be activated, the consequences can be fatal.
* b.. The damage to the tow release necessitates replacing the housing or
the hook. The cost of this repair is far higher than the saving through
buying cheaper rings.
* c.. If a tow release is operated with non-approved components, the
manufacturer's warranty becomes null and void. In addition, in the event of
a failure or accident, an insurance company can legitimately repudiate its
obligation to pay.
* Further information on :http://www.tost.de/evers/edefault.htm
tim
Please visit the Wings & Wheels website atwww.wingsandwheels.com
Tim,
we tow off of Tost rings normally, but for dual tows (2 gliders 1 tow
plane) there is a set of rings that fit together such that they will
disconnect each other if the tow is abandoned.
"brianDG303" wrote in message
In preparing our clubs tow lines for the season it seems we lost track
of 1/2 of a dual tow set, the small ring. I expect we will have to buy
the complete set but I have no idea where to find them- anyone know?
Thanks all
brian
Plastic binder rings [email protected] Piloting 4 January 28th 07 03:38 PM
Rings per inch for spruce? Esstern Home Built 2 May 16th 05 05:10 AM
Shock Chord Rings smjmitchell Home Built 1 September 9th 04 07:41 AM
Libelles & Tost Rings nowhere Soaring 9 July 21st 04 05:08 PM
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
