#11
Roger Druce wrote:
While on the matter of line sharing, the following is relevant to sharing the Total Energy line between a number of flow variometers, mechanical (Winter, PZL, etc.) and / or electrical (Cambridge CAV II etc.) Each of the variometers fed by the one TE source have flow through the instrument to their own flask. All flasks running off one TE source must be the same physically and thermodynamically. If you mix flasks with different characteristics then you will get cross flow between the instruments. You can try this test on the bench provided you do it carefully. Get two identical pneumatic varios (with hopefully little inherent instrument error) and two diferent flasks, say one vacuum flask with heat sink material inserted and the other a same type vacuum flask without heat sink material inside. Apply a signal via a Tee junction to the two variometers. Note the variometer readings of the two variometers at different flow rates, ie calibrate one vario relative to the other. They won't read the same! Then swap the flasks between the variometers and repeat the calibration. The relative calibration will swap over between the varios showing that the flasks are influencing things strongly due to their different characteristics. Install identical flasks and the varios will resume responding together. So use identical flasks to avoid cross flow when using a common TE source. If you have to worry about the flasks cross-flowing, you have another problem: your TE source isn't good enough to supply the flow the two flasks need, and both your varios will operate more slowly than they would alone. The TE system must be able to supply the TE pressure to the vario tee, regardless of the flow the varios require. If it does this, then the flasks can't affect the pressure at the tee, and it won't matter what size each is. This might require a probe with a larger hole(s) in it, shorter or larger diameter tubing from the TE probe to the tee for the varios, or varios that use smaller flasks (i.e., require less flow). -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
On Thu, 10 Mar 2005 19:33:57 -0800, Eric Greenwell wrote:
Roger Druce wrote: While on the matter of line sharing, the following is relevant to sharing the Total Energy line between a number of flow variometers, mechanical (Winter, PZL, etc.) and / or electrical (Cambridge CAV II etc.) Each of the variometers fed by the one TE source have flow through the instrument to their own flask. All flasks running off one TE source must be the same physically and thermodynamically. If you mix flasks with different characteristics then you will get cross flow between the instruments. You can try this test on the bench provided you do it carefully. Get two identical pneumatic varios (with hopefully little inherent instrument error) and two diferent flasks, say one vacuum flask with heat sink material inserted and the other a same type vacuum flask without heat sink material inside. Apply a signal via a Tee junction to the two variometers. Note the variometer readings of the two variometers at different flow rates, ie calibrate one vario relative to the other. They won't read the same! Then swap the flasks between the variometers and repeat the calibration. The relative calibration will swap over between the varios showing that the flasks are influencing things strongly due to their different characteristics. Install identical flasks and the varios will resume responding together. So use identical flasks to avoid cross flow when using a common TE source. If you have to worry about the flasks cross-flowing, you have another problem: your TE source isn't good enough to supply the flow the two flasks need, and both your varios will operate more slowly than they would alone. The TE system must be able to supply the TE pressure to the vario tee, regardless of the flow the varios require. If it does this, then the flasks can't affect the pressure at the tee, and it won't matter what size each is. This might require a probe with a larger hole(s) in it, shorter or larger diameter tubing from the TE probe to the tee for the varios, or varios that use smaller flasks (i.e., require less flow). If the varios all require the same sized flask, why not connect the varios in series to a single flask ? The small additional volume seen by the early instruments in the chain, due to the volume of the later varios will be a source of error, but shouldn't be a large error unless a small flask is used. Cheers, John G. |
There are two problems with electronic pitot/static TE. The magnitude of the compensation signal and its phase. The first is commonly adjustable on the instrument, the second isn't. Your pressure port and the combined flow resistance and capacity of the tubing form a low pass filter. If the pitot and static system filter time constants are greatly different you can get large transient indications on the vario during pull ups or push overs. So if you have a system that works adding another instrument and connecting it to the static system will usually cause a problem. Leaks will also cause problems, as would partially blocking the static port with wax.(flow resistance increases.) For optimum performance of electronic TE the pitot and static should be on the same side of the TE(nose or tail) and the pitot should be twice as far from the TE as the static is. (Former World champion Stig Oye told me of this and a couple of minutes thought convinced me) A combined pitot/static probe on the fin does not fulfill this condition and still results in "g" change effects the same as a TE probe but is more sensitive to pitch and sideslip than the common two hole Irving pattern probe. If you aren't having apparent problems with electronic TE you are lucky or you've got your vario on a very slow response speed where the unwanted transients are heavily damped. If you are having problems you want to get a good handle on the physics of what is going on in order to fix the problem. Mike Borgelt -- mborgelt ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
mborgelt wrote:
For optimum performance of electronic TE the pitot and static should be on the same side of the TE(nose or tail) and the pitot should be twice as far from the TE as the static is. (Former World champion Stig Oye told me of this and a couple of minutes thought convinced me) Mike, could you elaborate on this? It the vario is using electronic TE, it's not using a TE probe, so I'm confused about the "pitot and static should be on the same side of the TE(nose or tail)". What is TE referring to in your statement? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Similar Threads | ||||
Why are TE probes so long? | Duane Eisenbeiss | Soaring | 36 | May 9th 04 06:58 AM |
Fine example of Tarver Engineering release for service | running with scissors | Military Aviation | 79 | March 3rd 04 01:48 PM |
Fine example of Tarver Engineering release for service | running with scissors | Instrument Flight Rules | 64 | March 3rd 04 05:01 AM |
Chuck Yeager-pitot tube | Ron | Military Aviation | 44 | October 9th 03 03:13 AM |
Pitot and static couplings for a TTU-205 | B2431 | Home Built | 0 | August 15th 03 07:25 AM |
