DUATS and SIDs
I'd like to use DUATS to plan and file routes that include SIDs, but I find
it often doesn't know about them. For instance, when I try to list the SIDs for KBED, it says there are none; when I try to list the SIDs for KBTV, it lists only BTV4.BTV (and it doesn't seem to accept manually specified SIDs that it doesn't list). Am I making some mistake, or does DUATS have incomplete data? --Gary |
Gary Drescher wrote:
I'd like to use DUATS to plan and file routes that include SIDs, but I find it often doesn't know about them. For instance, when I try to list the SIDs for KBED, it says there are none; when I try to list the SIDs for KBTV, it lists only BTV4.BTV (and it doesn't seem to accept manually specified SIDs that it doesn't list). Am I making some mistake, or does DUATS have incomplete data? airnav.com doesn't list any SIDs for BED, and shows only BTV4 for BTV. They must be using the same data. What data source indicates other SIDs exist? Dave |
In a previous article, Dave Butler said:
Gary Drescher wrote: it often doesn't know about them. For instance, when I try to list the SIDs for KBED, it says there are none; when I try to list the SIDs for KBTV, it airnav.com doesn't list any SIDs for BED, and shows only BTV4 for BTV. They must be using the same data. What data source indicates other SIDs exist? If you try to download the approach plates at aeroplanner.com, it shows HASCSOM SIX as a SID at BED, but it's a vector SID. They also only have BTV4 for BTV. -- Paul Tomblin http://xcski.com/blogs/pt/ If you had the chance of making the amount of pain your lusers had to suffer dependent on the number of windows on their screens, you would seize the opportunity, wouldn't you? -- Abigail |
"Dave Butler" wrote in message
news:1123619675.114334@sj-nntpcache-3... Gary Drescher wrote: I'd like to use DUATS to plan and file routes that include SIDs, but I find it often doesn't know about them. For instance, when I try to list the SIDs for KBED, it says there are none; when I try to list the SIDs for KBTV, it lists only BTV4.BTV (and it doesn't seem to accept manually specified SIDs that it doesn't list). Am I making some mistake, or does DUATS have incomplete data? airnav.com doesn't list any SIDs for BED, and shows only BTV4 for BTV. They must be using the same data. What data source indicates other SIDs exist? KBED has the Hanscom Six departure. (http://www.naco.faa.gov/d-tpp/0508/00626HANSCOM.PDF) KBTV has only the Burlington Four departure, but there are many transitions, such as BTV4.CAM. But DUATS only recognizes BTV4.BTV. (http://www.naco.faa.gov/d-tpp/0508/00070BURLINGTON.PDF) --Gary |
You will only be able to input non-vector DPs when filing. If you have an
IFR GPS that can automatically load DPs (like the Garmins), then you will notice that you can not load vector DPs because of the same reason. Marco Leon "Gary Drescher" wrote in message ... I'd like to use DUATS to plan and file routes that include SIDs, but I find it often doesn't know about them. For instance, when I try to list the SIDs for KBED, it says there are none; when I try to list the SIDs for KBTV, it lists only BTV4.BTV (and it doesn't seem to accept manually specified SIDs that it doesn't list). Am I making some mistake, or does DUATS have incomplete data? --Gary Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
"Marco Leon" mmleon(at)yahoo.com wrote in message
... You will only be able to input non-vector DPs when filing. If you have an IFR GPS that can automatically load DPs (like the Garmins), then you will notice that you can not load vector DPs because of the same reason. That makes sense. I was confused because DUATS does accept BTV4.BTV, but not the other BTV4 transitions. But I emailed DUATS and they said it was an error that they accept BTV4.BTV. --Gary Marco Leon "Gary Drescher" wrote in message ... I'd like to use DUATS to plan and file routes that include SIDs, but I find it often doesn't know about them. For instance, when I try to list the SIDs for KBED, it says there are none; when I try to list the SIDs for KBTV, it lists only BTV4.BTV (and it doesn't seem to accept manually specified SIDs that it doesn't list). Am I making some mistake, or does DUATS have incomplete data? --Gary Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
