Use of 121.5 ELTs to be illegal in U.S. in about 60 days.
Old June 22nd 10, 12:39 PM posted to rec.aviation.piloting
Brian Whatcott
Default Use of 121.5 ELTs to be illegal in U.S. in about 60 days.
Jim Logajan wrote:
/snip/
the plans for development of the outlying regions of the Galaxy require the
building of a hyperspatial express route through your star system. And
regrettably, your planet is one of those scheduled for demolition. The
process will take slightly less than two of your Earth minutes. Thank you."
/snip/
Above all: Don't panic.
Brian W
Old June 22nd 10, 12:49 PM posted to rec.aviation.piloting
Brian Whatcott
Jim Logajan wrote:
Lastly, the FCC document is interesting in that the rationale uses appeals
to authority based on internal dialogs with other government agencies.
Amusing to read about the effects on small users. It sees they had
difficulty defining who a little user is. I wonder just who that could be?
Brian W
Old June 22nd 10, 11:37 PM posted to rec.aviation.piloting
Jim Logajan
Stealth Pilot wrote:
I dont know why you object so strongly. the new 406 machines are
encoded so that the rescue people can look up who's elt has gone off.
The issue isn't with regard to technical aspects of 406.0/.1 vs 121.5, but
that the grace period between the required-by date and announcement date is
so short. It seems probable there simply wouldn't be enough 406 ELTs on
hand in the U.S. to cover the short term demand, among other problems.
Old June 23rd 10, 12:30 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Tue, 22 Jun 2010 17:37:50 -0500, Jim Logajan
well Jim it happened just recently in Australia as well and the
manufacturers seemed to ramp up production of some beautiful units in
time for the demand.
I bought a superb GME brand MTS410 GPS version.
It cost more than my years flying but if needed in the middle of the
nullabor in summer heat it will pay for itself in an instant.
sometimes you guys just think too much.
Stealth (still no transponder) Pilot
Old July 3rd 10, 04:37 AM posted to rec.aviation.piloting
Roger[_6_]
On Mon, 21 Jun 2010 17:55:16 -0500, brian whatcott
Jim Logajan wrote:
Within 60 days of being published in the Federal Registry, use of 121.5
MHz ELTs will be forbidden by a re-write and re-title of
47 CFR section 87.195:
http://hraunfoss.fcc.gov/edocs_publi...C-10-103A1.pdf
"The manufacture, importation, sale or use of 121.5 MHz ELTs is prohibited."
The original text of 47 CFR section 87.195 may be read he
http://frwebgate.access.gpo.gov/cgi-...998&TYP E=PDF
Two issues:
1) There are ELTs that support both 121.5 and 406 MHz, yet the
one-sentence regulation doesn't acknowledge their existence, so it can
be interpreted to mean their use too is prohibited.
2) There are going to be a lot of seriously annoyed and ****ed owners of
"older" equipment.
The basis for banning the sale of ordinary 121.5 ELTs (one exception) is
that there is no sattelite facility to listen on this frequency and
(apparently) the uch better success rate of locating 406.0 406.1 ELTs.
Hey, If the FAA doesn't care if I have a 121.5 ELT, neither do I.
Roger
It seems evident that any ELT which can offer an emission which is
listened for (on 406.0/ 406.1) will be encouraged.
Brian W
Old July 3rd 10, 09:23 PM posted to rec.aviation.piloting
Peter Dohm
"Roger" wrote in message
prohibited."
Two issues:
"older" equipment.
Roger
Good point, Roger,
A similar discussion came up some time ago, at a live seminar rather than on
usenet, and the result was that the FAA had better uses for their time and
manpower than to enforce FCC rules. That was then and...
Deja vu is never exact and the use of cell phones (both then and now) would
generally work for the mutual convenience of both pilots and controllers
while alarms from parked aircraft and ELT use by back packers and cliff
climbers appear to have caused a lot of serious problems for various
agencies including FAA; so this could well be different--especially when
false alarms are involved.
Just my $0.02
Peter
Brian W
Anybody installing tri-band (406MHz) ELTs? Michelle P Instrument Flight Rules 0 July 4th 05 09:10 PM
Anybody installing tri-band (406MHz) ELTs? Michelle P General Aviation 0 July 4th 05 09:10 PM
406 ELTs: link featuring many models [email protected] Soaring 0 February 20th 05 09:36 PM
how illegal am I? Cub Driver Piloting 75 November 12th 04 07:51 PM
40,000 U$ Soldiers are Illegal Aliens, Drafted for Illegal War Gordon Military Aviation 6 September 7th 03 03:28 AM
