Boeing wins MMA comp
Old June 18th 04, 06:27 AM
Neil Gerace
Default Boeing wins MMA comp
It was reported in today's paper that Boeing has been awarded a contract to
develop the USN's Orion replacement. LockMart, the other bidder, lost with
its Orion 21.
The new aircraft, like the RAAF Wedgetail AEW&C platform, will be based on
the Boeing 737-700IGW (or BBJ) airframe.
Old June 19th 04, 12:31 AM
ian maclure
its Orion 21.
Call me old fashioned but were I loitering at low alt in mid-ocean
I'd want more than two engines available.
IBM
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
Old June 19th 04, 01:11 AM
Air Force Jayhawk
The reliability of todays' engines means the penalty of carrying 4
engines is no longer considered necessary.
AFJ
its Orion 21.
IBM
_________________________________________________ ______________________________
Old June 19th 04, 10:25 AM
Neil Gerace
"ian maclure" wrote in message
news
If this were an airliner I'd agree.
Old June 20th 04, 06:05 AM
Ian MacLure
"Neil Gerace" wrote in
news
So, you believe that low and slow, crankin' and bankin'
is a more benign environment than cruise at altitude?
Not to mention the multiples of normal engine cycles
the MMA wil get in compressed time frames?
IBM
Old June 20th 04, 12:09 PM
Neil Gerace
"Ian MacLure" wrote in message
news
That's why they're using the BBJ airframe and not the regular -700 one, I'm
guessing. The BBJ has the fuselage of the -700 but the wings and gear of the
larger -800. Similar to the mods Boeing did to the 747-100 to make the -SR,
for short, frequent cycles.
Old June 21st 04, 05:06 AM
Mike Zaharis
"Neil Gerace" wrote in message news:40d57002$0$28948
They're not using any -700 airframe, BBJ or otherwise. They're using
an Increased Gross Weight version of an -800 airframe, according to
Boeing's website.
You are correct about the -700 based BBJ, with the -800 wings for the
increased weight limit.
Old June 21st 04, 06:02 AM
Neil Gerace
[snip]
one, I'm guessing. The BBJ has the fuselage of the -700 but the wings
and gear of the larger -800. Similar to the mods Boeing did to the
747-100 to make the -SR, for short, frequent cycles.
There is a world of difference between the stress spectrum
inherent in airline usage and the MPA environment.
Its not just the cycles.
The 747-SR also spent most of its life at low altitude and near-maximum
mass.
Old June 21st 04, 06:14 AM
Neil Gerace
"Mike Zaharis" wrote in message
om...
Hm, well I read that in Australian Aviation, and they're usually pretty
clued up.
Old June 21st 04, 08:35 AM
Errol Cavit
[snip]
And still doesn't address the engine reliability issue.
I believe ( and I expect P3 crew community would agree
with me ) that the redundancy provided by 4 engines is a
very desirable if not mandatory feature in an MPA.
Does anyone know the comparative loss rates for the Atlantique vs P3?
Errol Cavit | | "If you have had enough, then I have
had enough. But if you haven't had enough, then I haven't had enough
either." Maori chief Kawiti to Governor George Grey, after the Battle of
Ruapekapeka 1846.
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Boeing Team Wins Multi-Mission Maritime Aircraft Program Harry Andreas Military Aviation 0 June 15th 04 12:02 AM
More good news from Boeing noname Military Aviation 0 December 6th 03 01:50 AM
AOPA and ATC Privatization Chip Jones Instrument Flight Rules 139 November 12th 03 08:26 PM
Boeing shares rose as high as $38.90, up $2.86, in morning trade! Larry Dighera Military Aviation 0 October 29th 03 08:49 PM
