O200 engine
Old August 16th 07, 08:22 AM posted to rec.aviation.homebuilt
Philippe Vessaire
Default O200 engine
Hello,
I search where is, in the engine, the PN 633309-8 (bearing needle).
I don't found yet in the IPC...
Where may I buy a full overhaul kit, this kit must be send overseas in
Europe.
Thanks
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
Old August 16th 07, 03:44 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default O200 engine
On Thu, 16 Aug 2007 09:22:54 +0200, Philippe Vessaire
Hello,
Europe.
Thanks
have you munged that part number?
633609-8 is a 'bearing, needle' which the overhaul manual puts as item
-21B on the drawing for that section.
if you flip back a page to figure 3 you'll find it on the item that
inserts on the lower left case half on the drawing.
I've never pulled it apart so I'm not sure what it is.
Stealth Pilot
Old August 16th 07, 04:16 PM posted to rec.aviation.homebuilt
Montblack
Default O200 engine
("Philippe Vessaire")
I'm stealing THIS! Ò¿Ó¬
Paul-Mont :-)
Old August 16th 07, 04:21 PM posted to rec.aviation.homebuilt
Philippe Vessaire
Default O200 engine
you may, it's copyleft
Old August 16th 07, 04:32 PM posted to rec.aviation.homebuilt
Philippe Vessaire
Default O200 engine
I think you are right.... but only an item number, no drawing.... It's
why I don't see.
thanks again.
Old August 16th 07, 06:00 PM posted to rec.aviation.homebuilt
Montblack
Default O200 engine
("Philippe Vessaire" wrote)
Well all right then.
Paul-Mont Ò¿Ó¬
Old August 17th 07, 01:08 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default O200 engine
On Thu, 16 Aug 2007 17:32:41 +0200, Philippe Vessaire
why I don't see.
thanks again.
what you need is a copy of the
Continental Aircraft Engines
Series C-75,85,90 & O-200
Service Parts Catalogue
this has exploded views of the group assemblies and a breakdown of the
parts that go into each assembly.
I just discovered that my read of the exploded view missed something.
the needle bearing in question is part of the starter clutch assembly.
if you cant find a copy I could scan it and sent a copy by email.
it is 58 pages.
Stealth Pilot
Old August 17th 07, 08:53 PM posted to rec.aviation.homebuilt
Philippe Vessaire
Default O200 engine
I own that, but the needles are not design and I did't found the the
PN in the list.
Thanks
Engine-out procedures and eccentric forces on engine pylons Mxsmanic Piloting 18 May 26th 07 01:03 AM
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg [email protected] Aviation Photos 1 April 11th 07 04:48 PM
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg [email protected] Aviation Photos 0 April 9th 07 01:38 PM
O200 nose Philippe Home Built 0 July 22nd 05 08:09 PM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
