#21
S7 (formerly V7) software bugs?
update: june 24 2015
After correcting the trashed Polar and glider weights after a software upgrade, I flew a 6 hour flight today out of Bishop. The V7 (S7) performed without a hitch. I was able to change MC, and bugs without ill effects. The vario never changed volumes. It never pegged. It did not display the weird change in pitch in cruse. Yay! However, it would be very helpfull to know which parameters are preserved and which are rest to "default'" when one does an upgrade. Also, Preservation of parameters is (i think...) dependent on which of the two V7 file you update first. Do it backwards and nothing is preserved (a royal pain, as there are soon many settings to configure.) I wil be flying all week, and will update if issues arrise Matt H, |
HOT TIP - print off a hard copy of the manual and write all your settings
in it. Saves much memory searching for settings that you did XXX time ago! Pete At 05:43 25 June 2015, Matt Herron Jr. wrote: update: june 24 2015 After correcting the trashed Polar and glider weights after a software upgr= ade, I flew a 6 hour flight today out of Bishop. The V7 (S7) performed wit= hout a hitch. I was able to change MC, and bugs without ill effects. The = vario never changed volumes. It never pegged. It did not display the weir= d change in pitch in cruse. =20 Yay! However, it would be very helpfull to know which parameters are preserved a= nd which are rest to "default'" when one does an upgrade. Also, Preservati= on of parameters is (i think...) dependent on which of the two V7 file you = update first. Do it backwards and nothing is preserved (a royal pain, as t= here are soon many settings to configure.) I wil be flying all week, and will update if issues arrise Matt H, |
quick photos of each screen works well to.
Another day of flying without any S7 incidents. I was able to adjust Mc, Bugs, and ballast without incident. I think the Polar and associated settings was the culprit. Matt On Thursday, June 25, 2015 at 12:15:07 AM UTC-7, Pete Startup wrote: HOT TIP - print off a hard copy of the manual and write all your settings in it. Saves much memory searching for settings that you did XXX time ago! Pete At 05:43 25 June 2015, Matt Herron Jr. wrote: update: june 24 2015 After correcting the trashed Polar and glider weights after a software upgr= ade, I flew a 6 hour flight today out of Bishop. The V7 (S7) performed wit= hout a hitch. I was able to change MC, and bugs without ill effects. The = vario never changed volumes. It never pegged. It did not display the weir= d change in pitch in cruse. =20 Yay! However, it would be very helpfull to know which parameters are preserved a= nd which are rest to "default'" when one does an upgrade. Also, Preservati= on of parameters is (i think...) dependent on which of the two V7 file you = update first. Do it backwards and nothing is preserved (a royal pain, as t= here are soon many settings to configure.) I wil be flying all week, and will update if issues arrise Matt H, |
Similar Threads | ||||
... if only they can keep the bugs off | Eric Greenwell[_4_] | Soaring | 1 | August 30th 13 03:12 AM |
Colored altimeter bugs | Mxsmanic | Piloting | 8 | June 13th 10 07:21 PM |
Bugs on the windshield | Viperdoc[_4_] | Piloting | 41 | June 4th 07 11:44 PM |
This one super-bugs me... | José Herculano | Naval Aviation | 14 | July 22nd 04 04:00 PM |
What Bugs You The Most? | Charles Talleyrand | Owning | 14 | August 21st 03 05:36 AM |
