Going direct IFR at Canada
Old March 24th 07, 08:31 PM posted to rec.aviation.piloting,rec.aviation.ifr
M[_1_]
Default Going direct IFR at Canada
I'm planning a trip later this year that would go from KANJ (Sault Ste
Marie, MI) to KART (Watertown, NY), IFR and mostly through the
Canadian airspace, in a U.S. registered single engine Grumman. Going
IFR is mostly to make the two border crossing easier. I have
previously overflew Canadian airspace IFR with much shorter distance
between Buffalo and Detroit.
The flight planning software suggested the route of SSM . WALAC .
YVV . YMS . YSO . YCF . PERTH . KART. There's quite a bit of dog leg
in the middle. What're the chances for Toronto center letting me go
YVV direct YSO, and YCF direct KART? Would VFR be a better choice?
My only concern about the VFR is for them to somehow lose my flight
plan and I have to convince the U.S. controller that the flight does
not stop in Canada (therefore does not need to clear custom upon
landing at Watertown NY).
Alternatively, I can go from KANJ to KBUF (Buffalo, NY), cross the
Canadian airspace that way. The IFR route would take me right above
Toronto international airport at my cruising altitude (likely 9000).
Would Toronto terminal allow such IFR transit, or would they route me
around it?
Thanks!
Old March 24th 07, 11:31 PM posted to rec.aviation.piloting,rec.aviation.ifr
Andrew Sarangan
A direct routing ANJ to ART takes you well north of the Toronto
airspace. So I am not sure why you are worried about transiting the
airspace. Even your dogleg route you described puts you will north of
the Toronto airspace. If you are GPS equipped, filing direct to
Watertown may be the best choice. There is a high probability that you
will get cleared as filed.
around it?
Thanks!
Going direct IFR at Canada M[_1_] Piloting 1 March 24th 07 11:31 PM
No Direct Flights? Toks Desalu Piloting 25 September 1st 06 09:53 PM
Filing direct with GPS pgbnh Instrument Flight Rules 24 January 11th 06 07:19 PM
"cleared to ... when direct ..." John Harper Instrument Flight Rules 21 February 11th 04 04:00 PM
"Direct when able" Mitchell Gossman Instrument Flight Rules 18 October 21st 03 01:19 AM
