#11
Altimeter setting
On Jan 26, 10:41*pm, Tony wrote:
So once again, why not let us in on the response you have received from the FAA? http://www.faa.gov/about/office_org/...s/agc/pol_adju... Thanks Tony. I like my drama and my federal regulations as widely separated as possible. -T8 |
Altimeter setting
On Jan 26, 8:12*pm, T8 wrote:
On Jan 26, 10:41*pm, Tony wrote: So once again, why not let us in on the response you have received from the FAA? http://www.faa.gov/about/office_org/...s/agc/pol_adju... Thanks Tony. *I like my drama and my federal regulations as widely separated as possible. -T8 After more than 20 years as a forensic expert in my profession, I can firmly state your drama and your federal, state, county, local and any other regulations are hardly ever separated. |
Altimeter setting
There of course, is no prohibition against having two altimeters. One set to QNH (field elevation) the other set to QFE (zero on the ground). This is how American Airlines operated for decades. QFE is also the standard in Russia and China.
Altimeter setting
On Sat, 28 Jan 2012 01:04:14 -0800, Bill Palmer wrote:
There of course, is no prohibition against having two altimeters. One set to QNH (field elevation) the other set to QFE (zero on the ground). This is how American Airlines operated for decades. QFE is also the standard in Russia and China. The Chinese must have some pretty special altimeters if this applies to all their airfields, including those in Tibet: Bangda airport in eastern Tibet is at 14,219 feet AMSL. Bangda has an 18,000 ft (5500m) runway and, I gather, needs it. I've heard that the pilots must be on oxygen for takeoff and landing. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Altimeter setting
On Jan 28, 10:55*am, Martin Gregorie
wrote: On Sat, 28 Jan 2012 01:04:14 -0800, Bill *Palmer wrote: There of course, is *no prohibition against having two altimeters. One set to QNH (field elevation) the other set to QFE (zero on the ground). This is *how American Airlines operated for decades. QFE is also the standard in Russia and China. The Chinese must have some pretty special altimeters if this applies to all their airfields, including those in Tibet: Bangda airport in eastern Tibet is at 14,219 feet AMSL. Bangda has an 18,000 ft (5500m) runway and, I gather, needs it. I've heard that the pilots must be on oxygen for takeoff and landing. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | There's no need for any of this in soaring. XCSoar (what I use) and all other GPS-map gizmos do a very good job of reporting AGL height given a good 3D gps input and will (among other things) report an estimated arrival height over any navpoint. We beat this to death. The "AGL" altimeter guys had not a single compelling argument. They lost. -Evan Ludeman / T8 |
Altimeter setting
On Sat, 28 Jan 2012 08:12:34 -0800, T8 wrote:
On Jan 28, 10:55Â*am, Martin Gregorie wrote: On Sat, 28 Jan 2012 01:04:14 -0800, Bill Â*Palmer wrote: There of course, is Â*no prohibition against having two altimeters. One set to QNH (field elevation) the other set to QFE (zero on the ground). This is Â*how American Airlines operated for decades. QFE is also the standard in Russia and China. The Chinese must have some pretty special altimeters if this applies to all their airfields, including those in Tibet: Bangda airport in eastern Tibet is at 14,219 feet AMSL. Bangda has an 18,000 ft (5500m) runway and, I gather, needs it. I've heard that the pilots must be on oxygen for takeoff and landing. -- martin@ Â* | Martin Gregorie gregorie. | Essex, UK org Â* Â* Â* | There's no need for any of this in soaring. XCSoar (what I use) and all other GPS-map gizmos do a very good job of reporting AGL height given a good 3D gps input and will (among other things) report an estimated arrival height over any navpoint. We beat this to death. The "AGL" altimeter guys had not a single compelling argument. They lost. I'm not supporting or dismissing the use of QFE settings (though its what I was taught), just pointing out the impossibility of setting a standard altimeter to QFE for every airfield in areas that the Chinese say are part of China. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Altimeter setting
On Jan 28, 11:31*am, Martin Gregorie
wrote: On Sat, 28 Jan 2012 08:12:34 -0800, T8 wrote: On Jan 28, 10:55*am, Martin Gregorie wrote: On Sat, 28 Jan 2012 01:04:14 -0800, Bill *Palmer wrote: There of course, is *no prohibition against having two altimeters. One set to QNH (field elevation) the other set to QFE (zero on the ground). This is *how American Airlines operated for decades. QFE is also the standard in Russia and China. The Chinese must have some pretty special altimeters if this applies to all their airfields, including those in Tibet: Bangda airport in eastern Tibet is at 14,219 feet AMSL. Bangda has an 18,000 ft (5500m) runway and, I gather, needs it. I've heard that the pilots must be on oxygen for takeoff and landing. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | There's no need for any of this in soaring. *XCSoar (what I use) and all other GPS-map gizmos do a very good job of reporting AGL height given a good 3D gps input and will (among other things) report an estimated arrival height over any navpoint. *We beat this to death. The "AGL" altimeter guys had not a single compelling argument. They lost. I'm not supporting or dismissing the use of QFE settings (though its what I was taught), just pointing out the impossibility of setting a standard altimeter to QFE for every airfield in areas that the Chinese say are part of China. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Got that. Not intending to pick on you Martin. FWIW, I was taught QFE too. One of only two obvious defects in my otherwise excellent primary instruction. The other was poor checklist discipline (augh, how did that happen? that's another thread). QFE is so wrong in so many ways... it's amazing to me that this keeps popping up. I really don't give a fig about certain well known friends of mine that insist on doing this despite the inevitable communication problems "Xray Lima, say altitude" / "I'd rather not, thanks" (:-)), but if there are still instructors teaching students QFE, they really need to be taken to the woodshed and this needs to be stopped. -Evan Ludeman / T8 |
Altimeter setting
On Jan 26, 4:33*am, Tom wrote:
As a glider pilot, when are you allowed to use a zero altimeter setting? Back in July, I asked the FAA for a legal opinion regarding FAR 91.121. Yesterday, I finally received a response. There is reason for a continued dialog, and I am continuing the discussion with the FAA legal department. This Saturday, immediately prior to the third Glider Safety Webinar,I will provide subscribers to the webinar the exact wording of the FAA response. To join us in this discussion, please sign up for the third webinar on our web site:www.eglider.org Tom Knauff Can't believe you wasted the FAA's time on a question like that and you brought it up here again. |
Altimeter setting
As a glider pilot, when are you allowed to use a zero altimeter setting? Back in July, I asked the FAA for a legal opinion regarding FAR 91.121. Yesterday, I finally received a response. There is reason for a continued dialog, and I am continuing the discussion with the FAA legal department. This Saturday, immediately prior to the third Glider Safety Webinar,I will provide subscribers to the webinar the exact wording of the FAA response. To join us in this discussion, please sign up for the third webinar on our web site:www.eglider.org Tom Knauff If there is confusion it's because of an instructor not teaching properly This letter is in response to your July 19,2011 request for a legal interpretation regarding altimeter settings required in 14 CFR § 91.121. In your letter, you state that there is confusion among local area glider pilots as to whether altimeters must be set to mean sea level (MSL) when not using a cruising altitude, such as when conducting student glider flight training. Additionally, you indicate that glider operators are unsure if the regulation requires altimeters to be set to mean sea level (MSL) or above ground level (AGL) during student training and local flying. The cruising altitude of an aircraft below 18,000 feet MSL shall be maintained by reference to an altimeter that is set to the current reported altimeter setting of a station located along the route of flight and within 100 nautical miles of the aircraft. If there is no such station, the current reported altimeter setting of an appropriate available station shall be used. In an aircraft having no radio, the altimeter shall be set to the elevation of the departure airport or an appropriate altimeter setting available before departure. 14 CFR § 91.121(a)(1). The cruising altitude is the MSL altitude or flight level maintained during en route level flight. For aircraft such as gliders, transient periods oftime at a particular altitude do not relieve pilots from the requirements to operate the aircraft in reference to an altimeter that is set according to the requirements of § 91.121(a). Thus, local area glider pilots must set their altimeters to MSL, not AGL, during glider operations, including student glider training flights. Further FAA guidance on altimeter settings for glider operations can be found in the Glider Flying Handbook, FAA-H-8083-13, Chapter 4 (available online at http://www .faa. gov/library/manuals/ aircraft! glider handbook/media/ faa-h-8083-13. pdf |
Altimeter setting
On Sat, 28 Jan 2012 09:16:27 -0800, T8 wrote:
QFE is so wrong in so many ways... it's amazing to me that this keeps popping up. I really don't give a fig about certain well known friends of mine that insist on doing this despite the inevitable communication problems "Xray Lima, say altitude" / "I'd rather not, thanks" (:-)), but if there are still instructors teaching students QFE, they really need to be taken to the woodshed and this needs to be stopped. Understood. FWIW I carry two altimeters, a standard mechanical one and my SDI C4 vario which is also an altimeter. I normally set the mechanical to QFE and the C4 to 1013mb. This works well since my local airspace designations are split roughly 50:50 between height AGL and flight levels with a slight excess of AGL. We're taught to ignore the altimeter in the circuit in favour of looking out the window because this is all that works for a field landing, just as all UK glider landings are effectively short-field landings for the same reason. Further, very few glider fields share with GA so what the altimeter has to say around the airfield is unimportant: its interesting to see how high the winch launch was and if you're well above winch height if you want to cross the field but that's about it. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Similar Threads | ||||
WestJet B-737 With The Sun Setting | Canuck[_10_] | Aviation Photos | 0 | September 4th 10 05:07 PM |
Altimeter Setting | Rolf | Soaring | 82 | August 11th 10 06:15 PM |
WTB: used 57mm Altimeter OR swap for 80mm Altimeter | joesimmers | Soaring | 0 | November 3rd 09 11:59 AM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
Setting QNH | BTIZ | Piloting | 31 | March 12th 04 04:29 PM |
