MOCA and STAR
Ok, I am trying to brush off some of the rust and getting some
recurrent training. The task was to plan a flight, KLOU-KLEX-KJVY. (Louisville,KY). So, I looked up the STAR Clegg2 ( http://204.108.4.16/d-tpp/0702/00697CLEGG.PDF), and the charts. Clegg2 *seems* to make the KLOU-KLEX simple- just hit IIU, out on 080 to Clegg. But when I look at the IFR Enroute, that happens to be the V512 airway as well, which has a 10,000 MEA and a 2700 MOCA ( WHY the 10K, I can;t figure out). So, I looked up the AIM on MOCA, and it tells me this is used for "decending for approach". So, will I get a clearance KLOU IIU.CLEGG2 KLEX @ 3000? |
MOCA and STAR
"Larry R" wrote in message oups.com... Ok, I am trying to brush off some of the rust and getting some recurrent training. The task was to plan a flight, KLOU-KLEX-KJVY. (Louisville,KY). So, I looked up the STAR Clegg2 ( http://204.108.4.16/d-tpp/0702/00697CLEGG.PDF), and the charts. Clegg2 *seems* to make the KLOU-KLEX simple- just hit IIU, out on 080 to Clegg. But when I look at the IFR Enroute, that happens to be the V512 airway as well, which has a 10,000 MEA and a 2700 MOCA ( WHY the 10K, I can;t figure out). So, I looked up the AIM on MOCA, and it tells me this is used for "decending for approach". So, will I get a clearance KLOU IIU.CLEGG2 KLEX @ 3000? The Clegg Two Arrival does not go over IIU VORTAC. The IIU 080 radial is not a procedure track, the radial is used only to define CLEGG intersection. |
MOCA and STAR
Aha! Upon closer inspectioin you are right ! So with that, I'll just
do direct Clegg ! Thanks! |
MOCA and STAR
On Apr 19, 8:38 am, Larry R wrote:
Ok, I am trying to brush off some of the rust and getting some recurrent training. The task was to plan a flight, KLOU-KLEX-KJVY. (Louisville,KY). So, I looked up the STAR Clegg2 (http://204.108.4.16/d-tpp/0702/00697CLEGG.PDF), and the charts. Clegg2 *seems* to make the KLOU-KLEX simple- just hit IIU, out on 080 to Clegg. But when I look at the IFR Enroute, that happens to be the V512 airway as well, which has a 10,000 MEA and a 2700 MOCA ( WHY the 10K, I can;t figure out). So, I looked up the AIM on MOCA, and it tells me this is used for "decending for approach". So, will I get a clearance KLOU IIU.CLEGG2 KLEX @ 3000? STARs often have very high MEA's (and speeds) which are meant for turbojets descending from higher altitudes. However, it is a good question why the enroute MEA is 10k for V512. It may have something to do with the fact that the FFT VOR is a T class. I can't imagine there is anything taller than 3000' around there. |
Similar Threads | ||||
Getting the MOCA | Dan | Instrument Flight Rules | 59 | July 3rd 06 01:43 AM |
A Run in with a Star | William L.Snow, PE | Piloting | 60 | May 11th 06 04:45 PM |
MOCA and MEA over water??? | Roy Smith | Instrument Flight Rules | 16 | May 16th 05 08:13 PM |
Starduster SA-900 V-Star | bsquared | Home Built | 0 | September 1st 04 03:21 AM |
On-Star* | JJ Sinclair | Soaring | 12 | November 21st 03 12:34 AM |
