I have purchased a DG303 ACRO here in UT. First thanks to all for the
feedback on this plane. I am trying to ensure I cover all bases regarding registration with the goverment agencies. Any input from UT, and other states, pilots would be appreciated. 1) I have the Bill of Sales form, 8051, from the FAA and will submit that. 2) State sales tax. I understand the filing of the bill of sales will trigger sales tac from UT. It is not clear when this will occur and what 'sales value' will be used since the FAA bill of sales has no $$ amount. What should I expect? 3) I understand the state of UT requires a yearly registration that includes a fee for a sticker. Any ideas on where I can find the guidelines for the fees? The state web site references an aviation blue book but it costs money to access the data. 4) Trailer registration. I have not registered the trailer as I understand that any trailer rated for less than 2000 lbs do not require registration. Is this correct? If I take the trailer out of state will there be a problem? 5) I have heard that the state of TX has no sales tax on airplanes and I curious if anyone who registered their plane in TX without being a resident of that state. 6) Does TX require a yearly registration? Thanks in advance |
Don't forget your experimental category letter with your FSDO.
Ron:
I'm sure you'll enjoy the ship and there are some pretty good soaring conditions in Utah as you probably know. I had an LS-4 based at Cedar Valley a few years ago, so these are my comments: 1) I have the Bill of Sales form, 8051, from the FAA and will submit that. 2) State sales tax. I understand the filing of the bill of sales will trigger sales tac from UT. It is not clear when this will occur and what 'sales value' will be used since the FAA bill of sales has no $$ amount. What should I expect? Most states don't charge sales tax on private sales. I had a glider in Utah ten years ago and was never dinged for sales tax. If they don't come after you, don't ask! 3) I understand the state of UT requires a yearly registration that includes a fee for a sticker. Any ideas on where I can find the guidelines for the fees? The state web site references an aviation blue book but it costs money to access the data. I don't remember how my value was assessed, but don't expect they'll have your glider's value in any database - they may ask you for a declaration of value. Make this the cheapest hull value that sounds reasonable. (your trailer could be worth up to $10,000, instruments $5,000 and parachute $1,000 - that's $16,000 off the purchase price). 4) Trailer registration. I have not registered the trailer as I understand that any trailer rated for less than 2000 lbs do not require registration. Is this correct? If I take the trailer out of state will there be a problem? This was the case when I was there. This is not a problem as long as you have proof of ownership. I brought a glider trailer into Arizona recently from another state that didn't have registration and they just issued one here. 5) I have heard that the state of TX has no sales tax on airplanes and I curious if anyone who registered their plane in TX without being a resident of that state. 6) Does TX require a yearly registration? I believe that several states do not require the registration of private aircraft. However, I don't see the value of registering it in a place you won't be keeping it and I wouldn't fib to authorities about its location if asked. My advice is to answer all questions from the state as honestly as you can, but volunteer nothing! Mike |
I recently bought a glider from a UT based owner.
2. http://forms.faa.gov/forms/ac8050-2.pdf Right under Aircraft Bill of Sale it states "FOR AND IN CONSIDERATION OF $ THE UNDERSIGNED OWNER(S) OF THE FULL LEGAL AND BENEFICIAL TITLE OF THE AIRCRAFT DESCRIBED AS...... However, copies of this form do not apply here in Colorado, so I would suggest you and the seller create a separate bill of sale stating the terms, conditions, etc of sale, both sign and have it notarized or not. I don't know about annualized stickers for the glider. Nothing like that on mine. Some states/counties have excise, personal property, or luxury taxes assessed annually. The trailer should have a title. Create a separate bill of sale and amount. If the seller can't produce a title, you'll have to get the trailer registered in Utah. The seller of the glider I bought had to have it inspected in UT and a UT tag, title, and plates issued with annual tags. However, its gross is over 2000lbs. It's similar here in Colorado if there's no ID plate. CSP inspection or homebuilt declaration and a serialized tag. FWIW, in Colorado, sales tax (or use tax if import) is based on where the glider is kept. Our gliderport is rural so only the state portion of the tax basis applies. Were it based within an incoporated area, city taxes would also apply. Frank Whiteley |
Thanks Daryl, I have the letter to go.
Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 08:06 AM |
HpH 304CZ as first sailplane | fcnorton | Soaring | 29 | March 31st 06 01:47 AM |
Duster Plans For Sale - BJ-1b fullsize sailplane plans | WoodHawk | Soaring | 0 | April 25th 05 04:37 AM |
Ultralight sailplane aerotow liability | Caracole | Soaring | 18 | April 1st 04 09:17 PM |
Any sailplane pilots? | Larry Dighera | Soaring | 99 | January 7th 04 03:46 AM |
