Taurus glider for sale
Old May 22nd 19, 06:09 AM posted to rec.aviation.soaring
Tango Whisky
Default Taurus glider for sale
Trailer tops are made from polyester resins (like boat hulls) - different animal.
  #62
Old May 22nd 19, 06:56 AM posted to rec.aviation.soaring
Darryl Ramm
Let me try to de-r.a.s. this.
Nobody was discussing heat or UV dammage to a trailer trailer top.
AFAIK Eric is asking why a fiberglass top trailer may be less of a problem with heat inside damaging a glider than an aluminum top trailer.
(Careful now r.a.s. don't guess, Eric may be correct. And no, the roof of an aluminum trailer feel hotter but that is a thermal mass and conductivity effect).
  #63
Old May 22nd 19, 07:36 AM posted to rec.aviation.soaring
Ian[_2_]
On 2019/05/21 19:04, Thomas Greenhill wrote:
If this taurus were indeed exposed to high enough temperatures for long enough to distort or melt the canopy, I would definitely argue that it has significant composites damage.
I think we can accept that most FRP gliders have a "service limit" of
maximum temperature under load of somewhere between 80C and 200C. This
is quite low but more than adequate for purposes, even for flying in the
desert conditions.
But that is not quite the same case as the damaged Taurus. The only
relevant information I could find on Google was one comment was from
this link
https://www.permabond.com/2011/11/10...ant-adhesives/
"Most adhesives can resist higher temperatures than what is listed as
the service temperature for short periods of time providing adhesion to
the substrate is high, and the stress is low."
Is that Taurus safe to fly?
Is there any means of testing the structure to determine if it has
suffered permanent damage?
I can understand why the manufacturer says "NO". The potential of a
liability claim from a future owner is huge, even if the future event
was not related to this damage, potential legal costs would be enough to
make the lawyers veto anything the engineers might say.
But if it was YOUR money invested in the aircraft would YOU fly it?
Ian
PS: I know of a few gliders that were damaged in fires, repaired and
returned to service. The repairs were done by experience professionals
and included post repair heat curing and post repair structural load
testing. These aircraft are still flying today, decades later.
  #64
Old May 22nd 19, 10:06 AM posted to rec.aviation.soaring
Extract from engineering ........ has already shared info on the aircraft's destruction, so what I'd like to do here is to outline the structural concept of the Taurus Motorglider.
Taurus is constructed using the Scheufler (Hexion) L285 epoxy resin system, which is cured at 62 degC (145 F).
I attach the datasheet.
Essentially any long-term exposure to above +80 degC (175 F) or short term exposure to +90 degC (195 F) ambient temperature renders the material compromised in it's strength and is considered non-airworthy.......
Pipistrel Taurus: Club Glider? Phil Chidekel Soaring 3 February 29th 16 04:05 AM
Glider equipment for sale Roger Fowler[_3_] Soaring 0 August 2nd 14 06:05 PM
GLIDER 4 SALE BobD Soaring 0 March 16th 14 08:45 PM
Glider for Sale 5 ugly Soaring 1 December 8th 13 12:57 AM
Taurus Glider Ready for Flight Tests Michael Coates Soaring 5 April 5th 04 04:05 AM
