#41
New gun
Please, lets see your calculations on this problem.
Morgans wrote: "Frank Ch. Eigler" wrote in message Some people confuse descent with acceleration. A mere constant-rate descent (apprx. zero net force) does nothing to change the analysis. You lack the ability to change real life application into a physics problem. If you have your engines set to hold constant speed in level flight, then push over into descent, what happens to your speed? Case closed. Now you can use some of that acceleration into pushing against the guns. Everyone seems to forget that the guns on an A-10 are only used in 2 to 4 second bursts, most of the time, with the pilot constantly climbing and diving and turning. To do otherwise while in a combat situation would invite being shot down. Nobody in these conditions are going to be jerking the throttle all over the place, or worrying about brief speed excursions- from the maneuvers, or shooting the guns. |
