#11
5' 10", 155 lbs, including my brain (subtract 3 oz. when I leave that
behind!) Instructor at 190 lbs. |
Before someone bends trhe rudder trim tab - they should make sure the
coupling links to the nose wheel steering are set correctly first. My 172M links were set up incorrectly by what I otherwise consider a reputable shop. The Cessna service manual states specifically not to adjust these links just to make things fly straight. It may even have come from the factory screwed up. |
The Cessna mechanic needs to pay attention to the service
manual when troubleshooting badly rigged rudders. The rudder trim tab has limited authority, and the pilot shouldn't have to hold large amounts of pedal even if the tabs is off some. There are three possible defects in this system: 1. A broken right rudder bar return spring. The left spring will pull the left pedals forward and the pilot has to constantly hold right rudder to fight it. These springs break rather often. 2. Someone may have fooled with the cable adjustments at the rudder to center it. Those adjustments never need changing unless the pedals aren't lined up when the rudder is centered. The rudder centering is controlled by the nosewheel centering cam at the nosegear torque links, and adjustments are made by changing the length of the nosegear steering spring rods. 3 Everything might be OK but someone has bent the rudder trim tab the wrong way altogether. To get right trim, the tab has to bend left. The service manual rigging procedures are a bit complex, and a lot of mechanics just ignore them and end up misadjusting stuff. We've often found all the control systems way out of whack, sometimes dangerously so. Dan |
-------------------------------------------------------------------------------- FREE Spam Protection For Your E-Mail! Click Here. SpamExtract Blocks Spam. "Brian Colwell" wrote in message news:Hysce.1160488$Xk.425252@pd7tw3no... "GEG" wrote in message ... Hi Folks, I'm a low-time (10 hour) student pilot. I took my first flights in my school's 152 about 2 years ago, then had an 18-month wait for various reasons. When I first flew the plane, I don't remember the right rudder being such an issue (I flew 3 times 2 years ago). Now, the right rudder needs a lot of attention, almost all the time. Even in straight and level at cruise, some right rudder needs to be in. So, before a know-nothing student says something to the instructor, I wanted to give a shout to you guys and see what your thoughts might be. I understand the 152 has more need for right rudder than other planes. Have others had this experience? What should I look for? What should I say - if anything? I know it's not "no rudder needed", maybe I'm just not a very good pilot yet. Thanks, Gary Not sure why you wouldn't talk to your instructor ...thats what he is there I flew C150's and C172's in the early 1970's. none of them had rudder trim. Is he confusing it with another A/C type. I remember the PA28's had rudder trim. for !! Regards, BMC |
Qansett wrote:
I flew C150's and C172's in the early 1970's. none of them had rudder trim. Most of the 150s and all of the 172s I've flown had a rudder trim tab. When set properly, the planes would cruise without needing rudder input. My C-150 did not have such a tab. It was necessary to keep a bit of right rudder pressure all the time. I got in the habit of flying with one foot, except for landing. I had to break that habit in a hurry when I bought my Maule. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
"George Patterson" wrote in message news:vQqte.9587$EH1.153@trndny03... Qansett wrote: I flew C150's and C172's in the early 1970's. none of them had rudder trim. Most of the 150s and all of the 172s I've flown had a rudder trim tab. When set properly, the planes would cruise without needing rudder input. My C-150 did not have such a tab. It was necessary to keep a bit of right rudder pressure all the time. I got in the habit of flying with one foot, except for landing. I had to break that habit in a hurry when I bought my Maule. George Patterson I fly a C152 and with a passenger it requires no rudder, with just myself on board it requires slight right rudder all the time. |
George Patterson wrote:
Qansett wrote: I flew C150's and C172's in the early 1970's. none of them had rudder trim. Most of the 150s and all of the 172s I've flown had a rudder trim tab. All the 152's have 'em as do the later 172's. The early 172's (even after they went to the swept tail) don't. |
Similar Threads | ||||
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
Cessna 152 Rudder trim adjustment? | GEG | General Aviation | 17 | June 20th 05 02:55 PM |
Information on A310 that lost it's rudder enroute to Canada from Cuba | Corky Scott | Piloting | 3 | March 27th 05 03:49 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
