Lumbar support ideas?
Old November 30th 16, 02:13 AM posted to rec.aviation.soaring
Andrzej Kobus
Default Lumbar support ideas?
On Friday, November 18, 2016 at 9:59:52 AM UTC-5, SF wrote:
Noel
This is what I did. I bought a sheep skin pad for my National 425 that goes between my back and the chute. I using adhesive velcro tape, I velcroed' a small lumbar support cushion to the back of the chute container, and velcroed' an inflatable lumbar support bladder to the back of the sheepskin. The lumbar support bladder has a hose that runs up the shoulder strap and ends with a squeeze bulb similar to a blood pressure cuff. Usually the lumbar support cushion is enough, on long flights, a little inflation on the bladder makes life good again.
Example of a inflatable lumbar support
http://www.sportsimportsltd.com/inseluinairc.html
Example of a small lumbar support cushion
https://www.bedbathandbeyond.com/sto...vel/1014256946
Sheepskin for parachute
http://wingsandwheels.com/parachute/...pskin-pad.html
SF
I would be really careful with inflatable support. In case of an accident you might end up with a big problem. The inflatable will not support the spine. Crush foam is a much better solution.
  #32
Old November 30th 16, 08:31 AM posted to rec.aviation.soaring
bumper[_4_]
I use a one inch thick piece of Confor (Memory foam) in green, extra firm. Cut top and bottom edge at 45* and slip it between the sheepskin liner and pack. Very comfortable.
bumper
  #33
Old November 30th 16, 10:52 AM posted to rec.aviation.soaring
BruceGreeff
And it lasts for years...
bumper
Bruce Greeff
T59D #1771
  #34
Old November 30th 16, 04:00 PM posted to rec.aviation.soaring
I am am medical person.
I bought a pump-up blood pressure cuff.
You can take the bladder out but I found the fabric cover to provide some stability to the positioning of the bladder. The beauty is that you can pump it up or bleed it down when you want/need.
No money to fly. Any Ideas? bigcal9 General Aviation 3 January 5th 11 12:58 PM
Bushite soldiers beat to death innocent Children to 'let offsteam' - Support Our Demands For Open Communications - Unraveling the Mystery- you can not find a single soldier on Earth to publicly support GeorgeW Bush without immediately being re Tiger Naval Aviation 0 April 10th 08 01:20 AM
pc ideas? derFlieger Simulators 3 May 5th 05 11:26 PM
GPS Ideas RD Piloting 24 December 12th 03 10:53 AM
flight sim Ideas Steve Simulators 0 July 13th 03 08:56 AM
