Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Market Beacon Antenna - Can I paint?
Old February 24th 04, 04:05 AM
Tom
Default Market Beacon Antenna - Can I paint?
I have been restoring my Maule Aircraft and removed a pretty oxidized and
"boat" type antenna from the belly. It was working perfectly when the
aircraft was dismantled and there is no decal saying "do not paint" as with
some other types of antennas.
Anyone know if this is paintable?
Tom
Old February 24th 04, 08:49 PM
Ron Natalie
"Tom" wrote in message ...
Most paint should have no effect on the marker beacon (which operates at a fairly
low frequency). The "Do Not Paint" warning is primarily for the microwave stuff
like GPS antennas.
Old February 25th 04, 03:28 AM
Tom
Thanks, the Antenna mfgs say the paint is important and each antenna is
designed to compensate for it. But, I'm inclined to agree with you. This
antenna is only there to receive one low frequency and do it when the
antenna is right under the airplane. I'll give it a light coat of urethane
and then be sure to test it out.
"Ron Natalie" wrote in message
and
with
fairly
microwave stuff
like GPS antennas.
Old February 25th 04, 06:29 AM
Bushy
As an old army crystal cracker, I'd be inclined to think that if you stay
clear of conductive paints, like those that are used to repair broken window
heater paint, circuit board repair paint and to a lesser degree those that
contain aluminium or carbon black pigment, you should be fairly OK for most
antennas.
Peter
and
with
a
fairly
microwave stuff
like GPS antennas.
Old September 13th 07, 12:37 AM posted to rec.aviation.restoration
Michelle P
Tom
why not mount it inside the covering. Mine is.
Michelle
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Rotating Beacon vs. Flashing Beacon Mike Rapoport Owning 16 February 6th 04 11:05 PM
F-32 vs F-35 The Raven Military Aviation 60 January 17th 04 08:36 PM
Marker Beacon Antenna - Paging Jim Weir. Bart D. Hull Home Built 1 November 27th 03 10:31 PM
