#51
The inadvisability of charging LiFePO4 batteries below 32F/0C(aka below freezing)
On Saturday, March 24, 2018 at 4:00:07 AM UTC-7, Jim White wrote:
When I wanted to install LiFeP04 batteries in my 27, I asked the factory and Uli Kramer's response was as follows: "in principle we have approved these batteries with TN 2-2008 (attached): “3. Parts not belonging to the Minimum Equipment • Electric equipment and its aerials may neither in themselves nor by their mode of operation or by their effect upon the operating characteristics of the sailplane and its equipment constitute a hazard to safe operation. Every electric equipment has to be checked for reciprocal influence by systematically turning off and on and operating all other instruments. The equipment and its control and monitoring devices must be arranged so as to be easily controllable. Their installation must be such that they are sufficiently ventilated to prevent overheating.“ So a battery is also an electric equipment….. Kind regards Uli" TN 2-2008 applies to all Schleicher gliders. Jim The ASH26e Maintenance Manual, section 2.8 states that EITHER the YUASA (or= similar) or the Sonnenshein Dryfit A212 may be used. Nowhere does it say O= NLY a gel cell battery is permissible. Speaking as an electrical engineer, = I consider the Odyssey PC680 to be "similar" to the YUASA in form and funct= ion. The LiFePO4 definitely is not and should necessitate a 337 STC for cer= tificated gliders like mine, not to say that it can't be done. Tom As neither the engine nor it's battery is required equipment in an ASH26, it appears the TN2-2008 allows the installation of an LFP starter battery, provided it meets the other requirements of TN2-2008 (which it does). |
#52
In the circuit of a strobe (flash) built into or mounted on a camera, at the moment it is triggered, the current from the capacitor (charged to about 300 volts), through a transistor and into the flash tube, is around 100 amps. The wires connecting them are amazingly thin - gauge 18 or even thinner.. That works because the current pulse only lasts about a millisecond.
#53
Say what?
"Work" in an electrical circuit is volts and amps. Double the volts, basically halve the amps. Part of why some home equipment (eg, window AC unit) goes to 220VAC because the normal load is beyond a typical 15A breaker, maybe even beyond later 20A breakers. Cost (buying the unit vs. running a dedicated 220VAC single phase circuit) vs. benefit. Hmmmmm....let me think......inductive loads are a bit different. Resistive loads are fairly linear. Coil or motor loads are on the inductive load end, they vary. They typically have an inrush current. Resistive loads are fairly linear, they are what they are, minor variance based on temp. OK, not arguing a field guy vs. an EE, way beyond the topic of this thread. I will say I am looking for info about the "plating issue" in some battery chemistries, never heard that before, I may learn something new (which is a good thing......). |
#54
On Saturday, March 24, 2018 at 2:10:01 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
Say what? "Work" in an electrical circuit is volts and amps. Double the volts, basically halve the amps. Part of why some home equipment (eg, window AC unit) goes to 220VAC because the normal load is beyond a typical 15A breaker, maybe even beyond later 20A breakers. Cost (buying the unit vs. running a dedicated 220VAC single phase circuit) vs. benefit. Hmmmmm....let me think......inductive loads are a bit different. Resistive loads are fairly linear. Coil or motor loads are on the inductive load end, they vary. They typically have an inrush current. Resistive loads are fairly linear, they are what they are, minor variance based on temp. OK, not arguing a field guy vs. an EE, way beyond the topic of this thread. I will say I am looking for info about the "plating issue" in some battery chemistries, never heard that before, I may learn something new (which is a good thing......). For resistive loads, Ohms law rules: V=IR. Fixed resistance means if volts go up, current goes up. AC and inductive loads get complicated real fast. Transients are even more complicated. For things that draw power to do "work", like a DC starter motor, ignoring transients, then Power = VA, so at a fixed power if volts go up, amps go down. Inrush current on motors is actually limited because they are inductive. But stall current can be quite high as they look like a very small resistor. It must be winter. I'm still looking for that scholarly paper that discusses LiFePo4 charging at low temps. Closest one I've found is a study to see how they work in a satellite, which spends half it's time on the dark side of the earth at very low temp (but doesn't charge much, there being no solar radiation....) |
#55
On 03/21/2018 08:29 AM, Charlie M. (UH & 002 owner/pilot) wrote:
I would argue that. If you stated "fuel", then your argument carries more weight. I think most peeps, when they hear "gas" assume (yes, I know what that may also mean...) you mean gasoline/petrol. When you say "fuel", yes, there can be a mix up. Heck, coal is a fuel, don't think anyone is shoveling coal into an aircraft.....LOL....... Yes, LiFe is a lot different than LiPo or LiOn. LiFe is a lot closer in safety to LA than other Lithium chemistries. What's so funny about shoveling coal into an aircraft? http://www.thevintagenews.com/2016/1...ueled-by-coal/ |
#56
On Sun, 25 Mar 2018 00:30:42 -0600, kinsell wrote:
On 03/21/2018 08:29 AM, Charlie M. (UH & 002 owner/pilot) wrote: I would argue that. If you stated "fuel", then your argument carries more weight. I think most peeps, when they hear "gas" assume (yes, I know what that may also mean...) you mean gasoline/petrol. When you say "fuel", yes, there can be a mix up. Heck, coal is a fuel, don't think anyone is shoveling coal into an aircraft.....LOL....... Yes, LiFe is a lot different than LiPo or LiOn. LiFe is a lot closer in safety to LA than other Lithium chemistries. What's so funny about shoveling coal into an aircraft? http://www.thevintagenews.com/2016/1...aft-fueled-by- coal/ ....and somewhat to my surprise, I found out that anthracite and bituminous coals have about the same energy density (MegaJoules/litre) as diesel, petrol or jet fuel. Less surprisingly high quality coals are 50-75% worse for specific energy (MegaJoules/Kilogram). IOW a 'tank' of coal will have more or less the same energy content as the same sized tank of jet fuel or diesel but will be quite a bit heavier. -- Martin | martin at Gregorie | gregorie dot org |
#57
On Friday, March 23, 2018 at 10:46:22 PM UTC-7, jfitch wrote:
On Friday, March 23, 2018 at 10:21:56 PM UTC-7, 2G wrote: On Friday, March 23, 2018 at 8:48:40 AM UTC-7, jfitch wrote: On Friday, March 23, 2018 at 3:43:18 AM UTC-7, Andrzej Kobus wrote: On Friday, March 23, 2018 at 1:03:01 AM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 7:21:37 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 10:04:02 PM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 3:37:31 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 1:09:13 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 5:00:32 PM UTC-7, Andrzej Kobus wrote: On Wednesday, March 21, 2018 at 7:18:52 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 12:12:31 PM UTC-7, Tango Eight wrote: On Wednesday, March 21, 2018 at 2:15:26 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 10:22:48 AM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote: While I usually don't disagree with you, if you READ what Tango8 posted, he is saying the same thing as you. "Lithium in the name does make it the same", as I read it. Your thoughts?! Yes, I am going from early (late '70's NiCads to more modern LiFe or LiOn/LiPo) rechargeables including LA of various flavors. I have a bunch of cash tied up in chargers for various battery chemistries, mostly in RC use, but also for my main income. Hey, hey find an issue with my read of Tango8's post, I am willing to learn, but I believe you read it wrong. I don't believe it is dangerous to refer to Lithium Ion batteries as Lithium Ion batteries. But in T8s post he said it was, and further said '"LiIon" vs "LiPo" vs "LFP"' which implies that Lithium Ion batteries are a type of Lithium Ion batteries. The semantics matter. Had he quoted my post in context (the complete sentence was "If it has lithium in it, it is a Lithium Ion battery, but beyond that there are big differences in chemistry and mechanical construction.") perhaps he would have not thought what I said dangerous. You cannot charge a LiIon battery differently than an LFP, because an LFP IS a LiIon battery. LiIon includes all the different chemistries but the members of that group differ in their associated charge requirements. It is much better to use language precisely when the result of a misunderstanding can be an explosion and fire. If you specify an LFP charger you should get want you want. If you specify a LiIon charger you have no idea what you are going to get. Jon, you're clearly unfamiliar with the terminology as it is used out in the real world. There are many (millions) multi-mode chargers out there that use the terms as I have used them, "LiIon, LiPo, LFP". Semantics matter? Sure. Safety based on correctly matching charging cycles to chemistry matters more. Here's a link to the instructions for a commercial charger that illustrates what I am talking about. They use the terms LiIo, and LiFe instead of LiIon and LFP. http://www.ircha.org/sites/default/f...ntam%20BC6.pdf I am well aware of the loose and incorrect usage of terms, and it is what I am arguing against as potentially dangerous. As I said in my second post in this thread, "unfortunately there is confusion". What exactly is the voltage and chemistry of a LiIo, or LiIon, or Lithium battery? In the real world, Google "lithium ion battery" will correctly return hits on all types, not just lithium polymer, with recommended charging voltage of between 3.2 and several hundred volts. Even in the last few of posts we have the conflation of several chemistries. The news media is horribly guilty of this, from them we know that lithium batteries cause cars and aircraft to catch fire and burn, and hoverboards to self immolate. I have been told on this very forum that lithium ion batteries should not be used in gliders because they cause Boeing 787s and Chevy Volts and Samsung S7s to burn - never mind that those batteries are quite different than the ones we use. If I have a charger than says "LiIo" or "lithium" charger on it, that tells me little or nothing about what battery I can charge with it. This is my point. "Correctly matching charing cycles to chemistry" can only be done if the specific chemistry or voltages required are stated. "Lithium ion" is the term used for the collection of chemistries using lithium anodes or cathodes. If that is not the correct term, then what is? And why is it "dangerous" to use the correct term? And if speaking in a context where the specific chemistry dangerously matters, shouldn't the specific term be used, rather than the general? John, I am sorry, but aren't you the one who uses unapproved, for starting, LiFePo4 batteries in your ASH-26E for engine starting? I am surprised you seem to lecture others while you do questionable things yourself, just saying. Andrzej, the Schleicher maintenance manual (which specifies SLA batteries for both engine AND avionics) was written in 1995, and is not likely to consider a battery technology invented in 1996. Anyone flying an ASW 27 or 29 should similarly not use an LFP battery for avionics as they are not an approved type. Yet nearly every glider supply outlet sells them for this purpose, and I note that Schleicher ships LFP batteries for both start and avionics in many of their current gliders. I'm not lecturing (or even recommending) people to use or not use anything. I educated myself on what was required and acted accordingly based on facts, not questions. I AM asking that they use precise language, where precise language is important. Schleicher does not say "use a lead battery", rather they say "use a maintenance free lead-dry-gel battery" - because installing a flooded lead acid battery on its side near your butt is a bad idea. Even then they are imprecise - the battery they call out is an AGM, not a gel and these have different charge requirements. The terminology matters. John, the battery you are using was not designed for starting purposes. The CTC LFP128198 is only rated for 100 Amps for 30 sec, not as you stated in another thread at 160 Amps for 30 sec. 160 Amp is the rating of the protection circuit with is not enough in this application (http://sepbatteries.com/media/add_info/LFP128198.pdf). You are simply operating this battery at very thin safety margins. I am surprised that this does not bother you. A more appropriate solution would be EarthX battery specifically build for experimental aircraft as an engine starting battery, http://earthxbatteries.com/product-c...ental-aircraft Yes, it is very expensive but your life is priceless, or a better solution; or better yet the Odyssey PC680 Battery Andrzej, I appreciate your concern for me. I did misstate the spec, it is 100 amps for 30 seconds. (In a conversation with the designer, he said 150 amps for several seconds). Fortunately that is more than adequate to start the engine (I have measured the starting current, typically 80 amps for 3 seconds, and it has been routinely starting my engine for 3 years now). CTC in their marketing literature has stated that the battery is designed for engine start use. But perhaps the biggest problem I have is the characterization that this is a safety issue. It is not a safety issue. In the worst case, the battery will go into overcurrent protection and disconnect. If you are flying a motorglider in any situation where a dead starting battery is a safety issue, you need to review your flying practices. Even the ASH flight manual warns against this in section 4.5.1, "One must always be prepared for the possibility that the power plant will fail to deliver the hoped for propulsion." I love that sentence. Second, you apparently have not looked into the specifications of the SLA battery Schleicher specifies. It is the Yuasa 18-12, the data sheet spec's a maximum discharge of 112 amps. Are they "simply operating this battery at very thin safety margins"? It is much more likely to reach that maximum than the CTC, because the internal resistance is much higher and the starter voltage lower. It is not advertised or spec'd for engine start use. The Odyssey PC680 is a TPT starved electrolyte battery and does not meet Schleicher's specification of a "lead-dry-gel battery". These batteries ARE a safety issue as they have no internal overcurrent protection and will literally melt down in a fault. There is no fault protection in the starting circuit of an ASH26. The earthX battery does not fit in the hole. There are other LFP motorcycle "starter" batteries that will, but most do not have the same true AH capacity. You may use whatever battery you like, but don't worry about me - I'm perfectly safe. John, sorry to disappoint you, Schleicher does not install "lead-dry-gel batteries" in their gliders. They install AGM batteries with maximum discharge current for 5 seconds of 330 Amps. Try that with your battery.. Relying on Chinese mass produced circuits for your safety is not something that I would be willing to do at these current levels. Odyssey PC680 is an AGM battery, which is the same type as the one installed by Schleicher. The Schleicher spec is "lead-dry-gel batteries, quoted directly from the AS maintenance manual, section 2.8. I don't make this stuff up. That is not an AGM battery. They currently ship LiFePo4 batteries in a new glider. I'd like to know what you are going to do with 330 amps for 5 seconds? Arc weld with it? The starter does not draw anywhere near that, even with the propeller locked. The wires are only #6, and before than 6x#14. The rated carrying capacity of #6 is 102 amps. You will fry the wires. You will fry the switch and the solenoid and connectors. The starter will burn to a crisp. I do not wish to try that with any battery in my glider, it is exactly why I prefer the safety of the LFP with a disconnect, as opposed to a PC680 which can short circuit far more than that. I don't want to start a fire, I just want to start my engine. This isn't a "my battery is bigger than your battery" situation. The Yuasa and Panasonic AGM batteries most are using are likely made in China, as are at least half of the electronics in your glider. The main tire and tube are made in Brazil or China, I'm a lot more concerned about that than the battery. We risk our lives everyday on Chinese mass produced circuits - where do you think the circuits in your car's ABS and air bag system come from? John, again not true. Schleicher did not want to install LiFePo4 as a starting battery in my glider. I was told they will not do it for safety reason. The whole point is that you are using your LiFePo4 battery close to its design current output and you are relying on the mass produced Chinese electronics to keep you safe. That might work in a motorcycle but it is not really a good idea in an aircraft. The AGM batteries are also produced in China but they don't rely on a cheap circuit board to function properly. The circuit in my car does not concern me in this discussion. I am not flying my car. Did you check with FAA in regards to installing LiFePo4 battery in your glider? Andrzej, you are just talking nonsense. Schleicher does install LiFePo4 batteries in gliders now (after they have been invented). My LiFePo4 is being used no closer to its design current output than the original equipment Yuasa, and then only for 2 seconds while the starter button is pressed. Read the specs. All electronic circuits are mass produced, and most of them in China. Did you check with the FAA before you put the Odyssey battery in your glider? It is a TPT AGM battery, and not similar to the Yuasa which is a traditional thick plate AGM, their characteristics are significantly different. It is not a gel which Schleicher explicitly requires. Literally thousands of people are using LFP batteries in gliders. I'm not the first. But you need to explain to me why my safety is at risk. *** Exactly what failure mode are you concerned about?*** I'll give you a scenario for yours: the cheap Chinese cable clip used in the engine bay to secure the battery cable falls out, letting the positive battery cable fall against the engine. That short circuits the battery when the starter button is pressed, sinking 1000 amps and setting the entire wiring harness on fire, which passes right under your butt and next to the fuel tank. "Houston, we have a problem...." I may have only "mass produced Chinese circuits" to prevent this from happening in my glider, but at least I have something. Let me remind you that most Apple products are produced in China, and they generally of high quality (maybe higher than they deserve, but that is a design issue, not a manufacturing one). The ASH26e Maintenance Manual, section 2.8 states that EITHER the YUASA (or similar) or the Sonnenshein Dryfit A212 may be used. Nowhere does it say ONLY a gel cell battery is permissible. Speaking as an electrical engineer, I consider the Odyssey PC680 to be "similar" to the YUASA in form and function. The LiFePO4 definitely is not and should necessitate a 337 STC for certificated gliders like mine, not to say that it can't be done. Tom Tom, I can't post pictures but please read the sentence in the maintenance manual just above Types of Batteries. I quote it here directly and in its entirety: "Only mainentence-free lead-dry-gel batteries must be used as a power supply." The manual could hardly consider LiFePo4 batteries as they were invented after the manual was written. Speaking as an electrical engineer, I consider the Odyssey PC680 to be significantly different than the Yuasa (short circuit current is twice as large for one, far greater than the capacity of any component in the circuit). But I'd have no problem using one even so. The battery I use is similar in form and function to the Yuasa, closer is specs than the PC680. Jon, I saw that, and what I quoted from the manual was directly below it. The Yuasa battery is definitely not a gel-cell, yet it is listed as an acceptable battery for the 26e, so I conclude that Schleicher is not literally requiring a gel-cell. You and I may have different interpretations of the word "similar," but any AGM battery of the same form factor is similar as far as I am concerned. Any lithium chemistry (or any non-lead-acid chemistry), however, is clearly not similar. Tom |
#58
On Sunday, March 25, 2018 at 5:59:15 PM UTC-7, 2G wrote:
On Friday, March 23, 2018 at 10:46:22 PM UTC-7, jfitch wrote: On Friday, March 23, 2018 at 10:21:56 PM UTC-7, 2G wrote: On Friday, March 23, 2018 at 8:48:40 AM UTC-7, jfitch wrote: On Friday, March 23, 2018 at 3:43:18 AM UTC-7, Andrzej Kobus wrote: On Friday, March 23, 2018 at 1:03:01 AM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 7:21:37 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 10:04:02 PM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 3:37:31 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 1:09:13 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 5:00:32 PM UTC-7, Andrzej Kobus wrote: On Wednesday, March 21, 2018 at 7:18:52 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 12:12:31 PM UTC-7, Tango Eight wrote: On Wednesday, March 21, 2018 at 2:15:26 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 10:22:48 AM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote: While I usually don't disagree with you, if you READ what Tango8 posted, he is saying the same thing as you. "Lithium in the name does make it the same", as I read it. Your thoughts?! Yes, I am going from early (late '70's NiCads to more modern LiFe or LiOn/LiPo) rechargeables including LA of various flavors. I have a bunch of cash tied up in chargers for various battery chemistries, mostly in RC use, but also for my main income. Hey, hey find an issue with my read of Tango8's post, I am willing to learn, but I believe you read it wrong. I don't believe it is dangerous to refer to Lithium Ion batteries as Lithium Ion batteries. But in T8s post he said it was, and further said '"LiIon" vs "LiPo" vs "LFP"' which implies that Lithium Ion batteries are a type of Lithium Ion batteries. The semantics matter. Had he quoted my post in context (the complete sentence was "If it has lithium in it, it is a Lithium Ion battery, but beyond that there are big differences in chemistry and mechanical construction.") perhaps he would have not thought what I said dangerous. You cannot charge a LiIon battery differently than an LFP, because an LFP IS a LiIon battery. LiIon includes all the different chemistries but the members of that group differ in their associated charge requirements. It is much better to use language precisely when the result of a misunderstanding can be an explosion and fire. If you specify an LFP charger you should get want you want. If you specify a LiIon charger you have no idea what you are going to get. Jon, you're clearly unfamiliar with the terminology as it is used out in the real world. There are many (millions) multi-mode chargers out there that use the terms as I have used them, "LiIon, LiPo, LFP". Semantics matter? Sure. Safety based on correctly matching charging cycles to chemistry matters more. Here's a link to the instructions for a commercial charger that illustrates what I am talking about. They use the terms LiIo, and LiFe instead of LiIon and LFP. http://www.ircha.org/sites/default/f...ntam%20BC6.pdf I am well aware of the loose and incorrect usage of terms, and it is what I am arguing against as potentially dangerous. As I said in my second post in this thread, "unfortunately there is confusion". What exactly is the voltage and chemistry of a LiIo, or LiIon, or Lithium battery? In the real world, Google "lithium ion battery" will correctly return hits on all types, not just lithium polymer, with recommended charging voltage of between 3.2 and several hundred volts. Even in the last few of posts we have the conflation of several chemistries. The news media is horribly guilty of this, from them we know that lithium batteries cause cars and aircraft to catch fire and burn, and hoverboards to self immolate. I have been told on this very forum that lithium ion batteries should not be used in gliders because they cause Boeing 787s and Chevy Volts and Samsung S7s to burn - never mind that those batteries are quite different than the ones we use. If I have a charger than says "LiIo" or "lithium" charger on it, that tells me little or nothing about what battery I can charge with it. This is my point. "Correctly matching charing cycles to chemistry" can only be done if the specific chemistry or voltages required are stated. "Lithium ion" is the term used for the collection of chemistries using lithium anodes or cathodes. If that is not the correct term, then what is? And why is it "dangerous" to use the correct term? And if speaking in a context where the specific chemistry dangerously matters, shouldn't the specific term be used, rather than the general? John, I am sorry, but aren't you the one who uses unapproved, for starting, LiFePo4 batteries in your ASH-26E for engine starting? I am surprised you seem to lecture others while you do questionable things yourself, just saying. Andrzej, the Schleicher maintenance manual (which specifies SLA batteries for both engine AND avionics) was written in 1995, and is not likely to consider a battery technology invented in 1996. Anyone flying an ASW 27 or 29 should similarly not use an LFP battery for avionics as they are not an approved type. Yet nearly every glider supply outlet sells them for this purpose, and I note that Schleicher ships LFP batteries for both start and avionics in many of their current gliders. I'm not lecturing (or even recommending) people to use or not use anything. I educated myself on what was required and acted accordingly based on facts, not questions. I AM asking that they use precise language, where precise language is important. Schleicher does not say "use a lead battery", rather they say "use a maintenance free lead-dry-gel battery" - because installing a flooded lead acid battery on its side near your butt is a bad idea. Even then they are imprecise - the battery they call out is an AGM, not a gel and these have different charge requirements. The terminology matters. John, the battery you are using was not designed for starting purposes. The CTC LFP128198 is only rated for 100 Amps for 30 sec, not as you stated in another thread at 160 Amps for 30 sec. 160 Amp is the rating of the protection circuit with is not enough in this application (http://sepbatteries.com/media/add_info/LFP128198.pdf). You are simply operating this battery at very thin safety margins. I am surprised that this does not bother you. A more appropriate solution would be EarthX battery specifically build for experimental aircraft as an engine starting battery, http://earthxbatteries.com/product-c...ental-aircraft Yes, it is very expensive but your life is priceless, or a better solution; or better yet the Odyssey PC680 Battery Andrzej, I appreciate your concern for me. I did misstate the spec, it is 100 amps for 30 seconds. (In a conversation with the designer, he said 150 amps for several seconds). Fortunately that is more than adequate to start the engine (I have measured the starting current, typically 80 amps for 3 seconds, and it has been routinely starting my engine for 3 years now). CTC in their marketing literature has stated that the battery is designed for engine start use. But perhaps the biggest problem I have is the characterization that this is a safety issue. It is not a safety issue. In the worst case, the battery will go into overcurrent protection and disconnect. If you are flying a motorglider in any situation where a dead starting battery is a safety issue, you need to review your flying practices. Even the ASH flight manual warns against this in section 4.5.1, "One must always be prepared for the possibility that the power plant will fail to deliver the hoped for propulsion." I love that sentence. Second, you apparently have not looked into the specifications of the SLA battery Schleicher specifies. It is the Yuasa 18-12, the data sheet spec's a maximum discharge of 112 amps. Are they "simply operating this battery at very thin safety margins"? It is much more likely to reach that maximum than the CTC, because the internal resistance is much higher and the starter voltage lower. It is not advertised or spec'd for engine start use. The Odyssey PC680 is a TPT starved electrolyte battery and does not meet Schleicher's specification of a "lead-dry-gel battery". These batteries ARE a safety issue as they have no internal overcurrent protection and will literally melt down in a fault. There is no fault protection in the starting circuit of an ASH26. The earthX battery does not fit in the hole. There are other LFP motorcycle "starter" batteries that will, but most do not have the same true AH capacity. You may use whatever battery you like, but don't worry about me - I'm perfectly safe. John, sorry to disappoint you, Schleicher does not install "lead-dry-gel batteries" in their gliders. They install AGM batteries with maximum discharge current for 5 seconds of 330 Amps. Try that with your battery. Relying on Chinese mass produced circuits for your safety is not something that I would be willing to do at these current levels. Odyssey PC680 is an AGM battery, which is the same type as the one installed by Schleicher. The Schleicher spec is "lead-dry-gel batteries, quoted directly from the AS maintenance manual, section 2.8. I don't make this stuff up. That is not an AGM battery. They currently ship LiFePo4 batteries in a new glider. I'd like to know what you are going to do with 330 amps for 5 seconds? Arc weld with it? The starter does not draw anywhere near that, even with the propeller locked. The wires are only #6, and before than 6x#14. The rated carrying capacity of #6 is 102 amps. You will fry the wires. You will fry the switch and the solenoid and connectors. The starter will burn to a crisp. I do not wish to try that with any battery in my glider, it is exactly why I prefer the safety of the LFP with a disconnect, as opposed to a PC680 which can short circuit far more than that. I don't want to start a fire, I just want to start my engine. This isn't a "my battery is bigger than your battery" situation. The Yuasa and Panasonic AGM batteries most are using are likely made in China, as are at least half of the electronics in your glider. The main tire and tube are made in Brazil or China, I'm a lot more concerned about that than the battery. We risk our lives everyday on Chinese mass produced circuits - where do you think the circuits in your car's ABS and air bag system come from? John, again not true. Schleicher did not want to install LiFePo4 as a starting battery in my glider. I was told they will not do it for safety reason. The whole point is that you are using your LiFePo4 battery close to its design current output and you are relying on the mass produced Chinese electronics to keep you safe. That might work in a motorcycle but it is not really a good idea in an aircraft. The AGM batteries are also produced in China but they don't rely on a cheap circuit board to function properly.. The circuit in my car does not concern me in this discussion. I am not flying my car. Did you check with FAA in regards to installing LiFePo4 battery in your glider? Andrzej, you are just talking nonsense. Schleicher does install LiFePo4 batteries in gliders now (after they have been invented). My LiFePo4 is being used no closer to its design current output than the original equipment Yuasa, and then only for 2 seconds while the starter button is pressed.. Read the specs. All electronic circuits are mass produced, and most of them in China. Did you check with the FAA before you put the Odyssey battery in your glider? It is a TPT AGM battery, and not similar to the Yuasa which is a traditional thick plate AGM, their characteristics are significantly different. It is not a gel which Schleicher explicitly requires. Literally thousands of people are using LFP batteries in gliders. I'm not the first. But you need to explain to me why my safety is at risk. *** Exactly what failure mode are you concerned about?*** I'll give you a scenario for yours: the cheap Chinese cable clip used in the engine bay to secure the battery cable falls out, letting the positive battery cable fall against the engine. That short circuits the battery when the starter button is pressed, sinking 1000 amps and setting the entire wiring harness on fire, which passes right under your butt and next to the fuel tank. "Houston, we have a problem...." I may have only "mass produced Chinese circuits" to prevent this from happening in my glider, but at least I have something. Let me remind you that most Apple products are produced in China, and they generally of high quality (maybe higher than they deserve, but that is a design issue, not a manufacturing one). The ASH26e Maintenance Manual, section 2.8 states that EITHER the YUASA (or similar) or the Sonnenshein Dryfit A212 may be used. Nowhere does it say ONLY a gel cell battery is permissible. Speaking as an electrical engineer, I consider the Odyssey PC680 to be "similar" to the YUASA in form and function. The LiFePO4 definitely is not and should necessitate a 337 STC for certificated gliders like mine, not to say that it can't be done. Tom Tom, I can't post pictures but please read the sentence in the maintenance manual just above Types of Batteries. I quote it here directly and in its entirety: "Only mainentence-free lead-dry-gel batteries must be used as a power supply." The manual could hardly consider LiFePo4 batteries as they were invented after the manual was written. Speaking as an electrical engineer, I consider the Odyssey PC680 to be significantly different than the Yuasa (short circuit current is twice as large for one, far greater than the capacity of any component in the circuit). But I'd have no problem using one even so. The battery I use is similar in form and function to the Yuasa, closer is specs than the PC680. Jon, I saw that, and what I quoted from the manual was directly below it. The Yuasa battery is definitely not a gel-cell, yet it is listed as an acceptable battery for the 26e, so I conclude that Schleicher is not literally requiring a gel-cell. You and I may have different interpretations of the word "similar," but any AGM battery of the same form factor is similar as far as I am concerned. Any lithium chemistry (or any non-lead-acid chemistry), however, is clearly not similar. Tom Tom, I hear what you are saying, but I don't see that clearly. A battery that has the same AH capacity, runs at the same nominal voltages, has the same physical dimensions, produces the same load current, and runs all the same equipment seems pretty similar to me. Form, fit, and function. The specification most different is the weight. Of course "similar" can be interpreted many ways and I'm happy to have anyone run whatever battery they like. But if someone volunteers - unasked and off topic - that the battery I chose to like is dangerous, an explanation of why they think so, beyond "it might catch fire", is a fair question. The SLA might catch fire (they can and do). My engine might catch fire, my ailerons might catch fire, my hair or my pants might catch fire - better leave them on the ground too. Heck, the Ilec engine controller is required equipment on the ASH26, and it's full of "Chinese mass produced circuits", could catch fire and explode.... |
#59
On Sunday, March 25, 2018 at 10:50:53 PM UTC-7, jfitch wrote:
On Sunday, March 25, 2018 at 5:59:15 PM UTC-7, 2G wrote: On Friday, March 23, 2018 at 10:46:22 PM UTC-7, jfitch wrote: On Friday, March 23, 2018 at 10:21:56 PM UTC-7, 2G wrote: On Friday, March 23, 2018 at 8:48:40 AM UTC-7, jfitch wrote: On Friday, March 23, 2018 at 3:43:18 AM UTC-7, Andrzej Kobus wrote: On Friday, March 23, 2018 at 1:03:01 AM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 7:21:37 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 10:04:02 PM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 3:37:31 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 1:09:13 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 5:00:32 PM UTC-7, Andrzej Kobus wrote: On Wednesday, March 21, 2018 at 7:18:52 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 12:12:31 PM UTC-7, Tango Eight wrote: On Wednesday, March 21, 2018 at 2:15:26 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 10:22:48 AM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote: While I usually don't disagree with you, if you READ what Tango8 posted, he is saying the same thing as you. "Lithium in the name does make it the same", as I read it. Your thoughts?! Yes, I am going from early (late '70's NiCads to more modern LiFe or LiOn/LiPo) rechargeables including LA of various flavors. I have a bunch of cash tied up in chargers for various battery chemistries, mostly in RC use, but also for my main income. Hey, hey find an issue with my read of Tango8's post, I am willing to learn, but I believe you read it wrong. I don't believe it is dangerous to refer to Lithium Ion batteries as Lithium Ion batteries. But in T8s post he said it was, and further said '"LiIon" vs "LiPo" vs "LFP"' which implies that Lithium Ion batteries are a type of Lithium Ion batteries. The semantics matter. Had he quoted my post in context (the complete sentence was "If it has lithium in it, it is a Lithium Ion battery, but beyond that there are big differences in chemistry and mechanical construction.") perhaps he would have not thought what I said dangerous. You cannot charge a LiIon battery differently than an LFP, because an LFP IS a LiIon battery. LiIon includes all the different chemistries but the members of that group differ in their associated charge requirements. It is much better to use language precisely when the result of a misunderstanding can be an explosion and fire. If you specify an LFP charger you should get want you want. If you specify a LiIon charger you have no idea what you are going to get. Jon, you're clearly unfamiliar with the terminology as it is used out in the real world. There are many (millions) multi-mode chargers out there that use the terms as I have used them, "LiIon, LiPo, LFP". Semantics matter? Sure. Safety based on correctly matching charging cycles to chemistry matters more. Here's a link to the instructions for a commercial charger that illustrates what I am talking about. They use the terms LiIo, and LiFe instead of LiIon and LFP. http://www.ircha.org/sites/default/f...ntam%20BC6.pdf I am well aware of the loose and incorrect usage of terms, and it is what I am arguing against as potentially dangerous. As I said in my second post in this thread, "unfortunately there is confusion".. What exactly is the voltage and chemistry of a LiIo, or LiIon, or Lithium battery? In the real world, Google "lithium ion battery" will correctly return hits on all types, not just lithium polymer, with recommended charging voltage of between 3.2 and several hundred volts. Even in the last few of posts we have the conflation of several chemistries. The news media is horribly guilty of this, from them we know that lithium batteries cause cars and aircraft to catch fire and burn, and hoverboards to self immolate. I have been told on this very forum that lithium ion batteries should not be used in gliders because they cause Boeing 787s and Chevy Volts and Samsung S7s to burn - never mind that those batteries are quite different than the ones we use. If I have a charger than says "LiIo" or "lithium" charger on it, that tells me little or nothing about what battery I can charge with it. This is my point. "Correctly matching charing cycles to chemistry" can only be done if the specific chemistry or voltages required are stated. "Lithium ion" is the term used for the collection of chemistries using lithium anodes or cathodes. If that is not the correct term, then what is? And why is it "dangerous" to use the correct term? And if speaking in a context where the specific chemistry dangerously matters, shouldn't the specific term be used, rather than the general? John, I am sorry, but aren't you the one who uses unapproved, for starting, LiFePo4 batteries in your ASH-26E for engine starting? I am surprised you seem to lecture others while you do questionable things yourself, just saying. Andrzej, the Schleicher maintenance manual (which specifies SLA batteries for both engine AND avionics) was written in 1995, and is not likely to consider a battery technology invented in 1996. Anyone flying an ASW 27 or 29 should similarly not use an LFP battery for avionics as they are not an approved type. Yet nearly every glider supply outlet sells them for this purpose, and I note that Schleicher ships LFP batteries for both start and avionics in many of their current gliders. I'm not lecturing (or even recommending) people to use or not use anything. I educated myself on what was required and acted accordingly based on facts, not questions. I AM asking that they use precise language, where precise language is important. Schleicher does not say "use a lead battery", rather they say "use a maintenance free lead-dry-gel battery" - because installing a flooded lead acid battery on its side near your butt is a bad idea. Even then they are imprecise - the battery they call out is an AGM, not a gel and these have different charge requirements. The terminology matters. John, the battery you are using was not designed for starting purposes. The CTC LFP128198 is only rated for 100 Amps for 30 sec, not as you stated in another thread at 160 Amps for 30 sec. 160 Amp is the rating of the protection circuit with is not enough in this application (http://sepbatteries.com/media/add_info/LFP128198.pdf). You are simply operating this battery at very thin safety margins. I am surprised that this does not bother you. A more appropriate solution would be EarthX battery specifically build for experimental aircraft as an engine starting battery, http://earthxbatteries.com/product-c...ental-aircraft Yes, it is very expensive but your life is priceless, or a better solution; or better yet the Odyssey PC680 Battery Andrzej, I appreciate your concern for me. I did misstate the spec, it is 100 amps for 30 seconds. (In a conversation with the designer, he said 150 amps for several seconds). Fortunately that is more than adequate to start the engine (I have measured the starting current, typically 80 amps for 3 seconds, and it has been routinely starting my engine for 3 years now). CTC in their marketing literature has stated that the battery is designed for engine start use. But perhaps the biggest problem I have is the characterization that this is a safety issue. It is not a safety issue.. In the worst case, the battery will go into overcurrent protection and disconnect. If you are flying a motorglider in any situation where a dead starting battery is a safety issue, you need to review your flying practices. Even the ASH flight manual warns against this in section 4.5.1, "One must always be prepared for the possibility that the power plant will fail to deliver the hoped for propulsion." I love that sentence. Second, you apparently have not looked into the specifications of the SLA battery Schleicher specifies. It is the Yuasa 18-12, the data sheet spec's a maximum discharge of 112 amps. Are they "simply operating this battery at very thin safety margins"? It is much more likely to reach that maximum than the CTC, because the internal resistance is much higher and the starter voltage lower. It is not advertised or spec'd for engine start use. The Odyssey PC680 is a TPT starved electrolyte battery and does not meet Schleicher's specification of a "lead-dry-gel battery". These batteries ARE a safety issue as they have no internal overcurrent protection and will literally melt down in a fault. There is no fault protection in the starting circuit of an ASH26. The earthX battery does not fit in the hole. There are other LFP motorcycle "starter" batteries that will, but most do not have the same true AH capacity. You may use whatever battery you like, but don't worry about me - I'm perfectly safe. John, sorry to disappoint you, Schleicher does not install "lead-dry-gel batteries" in their gliders. They install AGM batteries with maximum discharge current for 5 seconds of 330 Amps. Try that with your battery. Relying on Chinese mass produced circuits for your safety is not something that I would be willing to do at these current levels. Odyssey PC680 is an AGM battery, which is the same type as the one installed by Schleicher. |
#60
On Monday, March 26, 2018 at 8:05:10 PM UTC-7, 2G wrote:
On Sunday, March 25, 2018 at 10:50:53 PM UTC-7, jfitch wrote: On Sunday, March 25, 2018 at 5:59:15 PM UTC-7, 2G wrote: On Friday, March 23, 2018 at 10:46:22 PM UTC-7, jfitch wrote: On Friday, March 23, 2018 at 10:21:56 PM UTC-7, 2G wrote: On Friday, March 23, 2018 at 8:48:40 AM UTC-7, jfitch wrote: On Friday, March 23, 2018 at 3:43:18 AM UTC-7, Andrzej Kobus wrote: On Friday, March 23, 2018 at 1:03:01 AM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 7:21:37 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 10:04:02 PM UTC-4, jfitch wrote: On Thursday, March 22, 2018 at 3:37:31 PM UTC-7, Andrzej Kobus wrote: On Thursday, March 22, 2018 at 1:09:13 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 5:00:32 PM UTC-7, Andrzej Kobus wrote: On Wednesday, March 21, 2018 at 7:18:52 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 12:12:31 PM UTC-7, Tango Eight wrote: On Wednesday, March 21, 2018 at 2:15:26 PM UTC-4, jfitch wrote: On Wednesday, March 21, 2018 at 10:22:48 AM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote: While I usually don't disagree with you, if you READ what Tango8 posted, he is saying the same thing as you. "Lithium in the name does make it the same", as I read it. Your thoughts?! Yes, I am going from early (late '70's NiCads to more modern LiFe or LiOn/LiPo) rechargeables including LA of various flavors. I have a bunch of cash tied up in chargers for various battery chemistries, mostly in RC use, but also for my main income. Hey, hey find an issue with my read of Tango8's post, I am willing to learn, but I believe you read it wrong. I don't believe it is dangerous to refer to Lithium Ion batteries as Lithium Ion batteries. But in T8s post he said it was, and further said '"LiIon" vs "LiPo" vs "LFP"' which implies that Lithium Ion batteries are a type of Lithium Ion batteries. The semantics matter.. Had he quoted my post in context (the complete sentence was "If it has lithium in it, it is a Lithium Ion battery, but beyond that there are big differences in chemistry and mechanical construction.") perhaps he would have not thought what I said dangerous. You cannot charge a LiIon battery differently than an LFP, because an LFP IS a LiIon battery. LiIon includes all the different chemistries but the members of that group differ in their associated charge requirements. It is much better to use language precisely when the result of a misunderstanding can be an explosion and fire. If you specify an LFP charger you should get want you want. If you specify a LiIon charger you have no idea what you are going to get. Jon, you're clearly unfamiliar with the terminology as it is used out in the real world. There are many (millions) multi-mode chargers out there that use the terms as I have used them, "LiIon, LiPo, LFP". Semantics matter? Sure. Safety based on correctly matching charging cycles to chemistry matters more. Here's a link to the instructions for a commercial charger that illustrates what I am talking about. They use the terms LiIo, and LiFe instead of LiIon and LFP. http://www.ircha.org/sites/default/f...ntam%20BC6.pdf I am well aware of the loose and incorrect usage of terms, and it is what I am arguing against as potentially dangerous. As I said in my second post in this thread, "unfortunately there is confusion". What exactly is the voltage and chemistry of a LiIo, or LiIon, or Lithium battery? In the real world, Google "lithium ion battery" will correctly return hits on all types, not just lithium polymer, with recommended charging voltage of between 3.2 and several hundred volts. Even in the last few of posts we have the conflation of several chemistries. The news media is horribly guilty of this, from them we know that lithium batteries cause cars and aircraft to catch fire and burn, and hoverboards to self immolate. I have been told on this very forum that lithium ion batteries should not be used in gliders because they cause Boeing 787s and Chevy Volts and Samsung S7s to burn - never mind that those batteries are quite different than the ones we use. If I have a charger than says "LiIo" or "lithium" charger on it, that tells me little or nothing about what battery I can charge with it. This is my point. "Correctly matching charing cycles to chemistry" can only be done if the specific chemistry or voltages required are stated. "Lithium ion" is the term used for the collection of chemistries using lithium anodes or cathodes. If that is not the correct term, then what is? And why is it "dangerous" to use the correct term? And if speaking in a context where the specific chemistry dangerously matters, shouldn't the specific term be used, rather than the general? John, I am sorry, but aren't you the one who uses unapproved, for starting, LiFePo4 batteries in your ASH-26E for engine starting? I am surprised you seem to lecture others while you do questionable things yourself, just saying. Andrzej, the Schleicher maintenance manual (which specifies SLA batteries for both engine AND avionics) was written in 1995, and is not likely to consider a battery technology invented in 1996. Anyone flying an ASW 27 or 29 should similarly not use an LFP battery for avionics as they are not an approved type. Yet nearly every glider supply outlet sells them for this purpose, and I note that Schleicher ships LFP batteries for both start and avionics in many of their current gliders. I'm not lecturing (or even recommending) people to use or not use anything. I educated myself on what was required and acted accordingly based on facts, not questions. I AM asking that they use precise language, where precise language is important. Schleicher does not say "use a lead battery", rather they say "use a maintenance free lead-dry-gel battery" - because installing a flooded lead acid battery on its side near your butt is a bad idea. Even then they are imprecise - the battery they call out is an AGM, not a gel and these have different charge requirements. The terminology matters. John, the battery you are using was not designed for starting purposes. The CTC LFP128198 is only rated for 100 Amps for 30 sec, not as you stated in another thread at 160 Amps for 30 sec. 160 Amp is the rating of the protection circuit with is not enough in this application (http://sepbatteries.com/media/add_info/LFP128198.pdf). You are simply operating this battery at very thin safety margins. I am surprised that this does not bother you. A more appropriate solution would be EarthX battery specifically build for experimental aircraft as an engine starting battery, http://earthxbatteries.com/product-c...ental-aircraft Yes, it is very expensive but your life is priceless, or a better solution; or better yet the Odyssey PC680 Battery Andrzej, I appreciate your concern for me. I did misstate the spec, it is 100 amps for 30 seconds. (In a conversation with the designer, he said 150 amps for several seconds). Fortunately that is more than adequate to start the engine (I have measured the starting current, typically 80 amps for 3 seconds, and it has been routinely starting my engine for 3 years now). CTC in their marketing literature has stated that the battery is designed for engine start use. But perhaps the biggest problem I have is the characterization that this is a safety issue. It is not a safety issue. In the worst case, the battery will go into overcurrent protection and disconnect. If you are flying a motorglider in any situation where a dead starting battery is a safety issue, you need to review your flying practices.. Even the ASH flight manual warns against this in section 4.5.1, "One must always be prepared for the possibility that the power plant will fail to deliver the hoped for propulsion." I love that sentence. Second, you apparently have not looked into the specifications of the SLA battery Schleicher specifies. It is the Yuasa 18-12, the data sheet spec's a maximum discharge of 112 amps. Are they "simply operating this battery at very thin safety margins"? It is much more likely to reach that maximum than the CTC, because the internal resistance is much higher and the starter voltage lower. It is not advertised or spec'd for engine start use. The Odyssey PC680 is a TPT starved electrolyte battery and does not meet Schleicher's specification of a "lead-dry-gel battery". These batteries ARE a safety issue as they have no internal overcurrent protection and will literally melt down in a fault. There is no fault protection in the starting circuit of an ASH26. The earthX battery does not fit in the hole. There are other LFP motorcycle "starter" batteries that will, but most do not have the same true AH capacity. You may use whatever battery you like, but don't worry about me - I'm perfectly safe. John, sorry to disappoint you, Schleicher does not install "lead-dry-gel batteries" in their gliders. They install AGM batteries with maximum discharge current for 5 seconds of 330 Amps. Try that with your battery. Relying on Chinese mass produced circuits for your safety is not something that I would be willing to do at these current levels. Odyssey PC680 is an AGM battery, which is the same type as the one installed by Schleicher. The Schleicher spec is "lead-dry-gel batteries, quoted directly from the AS maintenance manual, section 2.8. I don't make this stuff up. That is not an AGM battery. They currently ship LiFePo4 batteries in a new glider. I'd like to know what you are going to do with 330 amps for 5 seconds? Arc weld with it? The starter does not draw anywhere near that, even with the propeller locked. The wires are only #6, and before than 6x#14. The rated carrying capacity of #6 is 102 amps. You will fry the wires. You will fry the switch and the solenoid and connectors. The starter will burn to a crisp. I do not wish to try that with any battery in my glider, it is exactly why I prefer the safety of the LFP with a disconnect, as opposed to a PC680 which can short circuit far more than that. I don't want to start a fire, I just want to start my engine. This isn't a "my battery is bigger than your battery" situation. The Yuasa and Panasonic AGM batteries most are using are likely made in China, as are at least half of the electronics in your glider. The main tire and tube are made in Brazil or China, I'm a lot more concerned about that than the battery. We risk our lives everyday on Chinese mass produced circuits - where do you think the circuits in your car's ABS and air bag system come from? John, again not true. Schleicher did not want to install LiFePo4 as a starting battery in my glider. I was told they will not do it for safety reason. The whole point is that you are using your LiFePo4 battery close to its design current output and you are relying on the mass produced Chinese electronics to keep you safe. That might work in a motorcycle but it is not really a good idea in an aircraft. The AGM batteries are also produced in China but they don't rely on a cheap circuit board to function properly. The circuit in my car does not concern me in this discussion. I am not flying my car. Did you check with FAA in regards to installing LiFePo4 battery in your glider? Andrzej, you are just talking nonsense. Schleicher does install LiFePo4 batteries in gliders now (after they have been invented). My LiFePo4 is being used no closer to its design current output than the original equipment Yuasa, and then only for 2 seconds while the starter button is pressed. Read the specs. All electronic circuits are mass produced, and most of them in China. Did you check with the FAA before you put the Odyssey battery in your glider? It is a TPT AGM battery, and not similar to the Yuasa which is a traditional thick plate AGM, their characteristics are significantly different. It is not a gel which Schleicher explicitly requires. Literally thousands of people are using LFP batteries in gliders. I'm not the first. But you need to explain to me why my safety is at risk. *** Exactly what failure mode are you concerned about?*** I'll give you a scenario for yours: the cheap Chinese cable clip used in the engine bay to secure the battery cable falls out, letting the positive battery cable fall against the engine. That short circuits the battery when the starter button is pressed, sinking 1000 amps and setting the entire wiring harness on fire, which passes right under your butt and next to the fuel tank. "Houston, we have a problem...." I may have only "mass produced Chinese circuits" to prevent this from happening in my glider, but at least I have something. Let me remind you that most Apple products are produced in China, and they generally of high quality (maybe higher than they deserve, but that is a design issue, not a manufacturing one). The ASH26e Maintenance Manual, section 2.8 states that EITHER the YUASA (or similar) or the Sonnenshein Dryfit A212 may be used. Nowhere does it say ONLY a gel cell battery is permissible. Speaking as an electrical engineer, I consider the Odyssey PC680 to be "similar" to the YUASA in form and function. The LiFePO4 definitely is not and should necessitate a 337 STC for certificated gliders like mine, not to say that it can't be done. Tom Tom, I can't post pictures but please read the sentence in the maintenance manual just above Types of Batteries. I quote it here directly and in its entirety: "Only mainentence-free lead-dry-gel batteries must be used as a power supply." The manual could hardly consider LiFePo4 batteries as they were invented after the manual was written. Speaking as an electrical engineer, I consider the Odyssey PC680 to be significantly different than the Yuasa (short circuit current is twice as large for one, far greater than the capacity of any component in the circuit). But I'd have no problem using one even so. The battery I use is similar in form and function to the Yuasa, closer is specs than the PC680. Jon, I saw that, and what I quoted from the manual was directly below it. The Yuasa battery is definitely not a gel-cell, yet it is listed as an acceptable battery for the 26e, so I conclude that Schleicher is not literally requiring a gel-cell. You and I may have different interpretations of the word "similar," but any AGM battery of the same form factor is similar as far as I am concerned. Any lithium chemistry (or any non-lead-acid chemistry), however, is clearly not similar. Tom Tom, I hear what you are saying, but I don't see that clearly. A battery that has the same AH capacity, runs at the same nominal voltages, has the same physical dimensions, produces the same load current, and runs all the same equipment seems pretty similar to me. Form, fit, and function. The specification most different is the weight. Of course "similar" can be interpreted many ways and I'm happy to have anyone run whatever battery they like.. But if someone volunteers - unasked and off topic - that the battery I chose to like is dangerous, an explanation of why they think so, beyond "it might catch fire", is a fair question. The SLA might catch fire (they can and do). My engine might catch fire, my ailerons might catch fire, my hair or my pants might catch fire - better leave them on the ground too. Heck, the Ilec engine controller is required equipment on the ASH26, and it's full of "Chinese mass produced circuits", could catch fire and explode.... Jon, I don't think Schleicher has a specification on what kind of hair the pilot can have. We were talking about compatible BATTERIES. You claimed that ONLY gel-cells were permitted by Schleicher. When I pointed out that Yuasa AGM batteries are ALSO permitted per the Maintenance Manual, you went off the deep end and starting talking about ailerons and hair! Let's get out of the Twilight Zone and return to reality. Tom The Twilight zone is where this thread is (or should be). My point about the Schleicher maintenance manual is that it is inconsistent.. It says 'only gel batteries' AND calls out an AGM battery as permitted. Both cannot be true at once. Schleicher does not say "also". My point about things catching fire is directed at a different respondent. If we are worried about the unlikely possibility of unexplained spontaneous combustion, there may be many targets of that worry. Let's leave it at that. |
Similar Threads | ||||
LifePO4 batteries for motorgliders - are we there yet? | Chris | Soaring | 13 | January 9th 16 03:43 PM |
LiFePO4 Batteries on sale. | [email protected] | Soaring | 20 | December 9th 15 05:34 PM |
K2 vs. StarkPower LiFePo4 batteries | Fox Two[_2_] | Soaring | 36 | April 16th 15 05:14 PM |
LiFePO4 Batteries | vontresc | Soaring | 56 | June 27th 14 07:25 PM |
LiFePO4 batteries | JS | Soaring | 26 | October 15th 12 02:51 PM |
