X Plane Brakes
I have the latest version of X Plane. Why won't the brakes stop the
plane? Flying the default Cessna, I can set down as slowly and early as possible and still roll right off the end of the runway. Tried both "regular strength" and "max strength" brake application. |
X Plane Brakes
On Oct 10, 1:31*pm, Pat Dotson wrote:
I have the latest version of X Plane. *Why won't the brakes stop the plane? *Flying the default Cessna, I can set down as slowly and early as possible and still roll right off the end of the runway. *Tried both "regular strength" and "max strength" brake application. what key or axis to you have the command bound to ? if, for example, you bound it to the "B" key on your keypad you might want to check if it is remaining active after you press, or it might be a momentary engagement which would explain why you keep going. |
X Plane Brakes
Pat Dotson wrote:
I have the latest version of X Plane. Why won't the brakes stop the plane? Flying the default Cessna, I can set down as slowly and early as possible and still roll right off the end of the runway. Tried both "regular strength" and "max strength" brake application. Sorry Pat can't help U but would You know where the microsoft flight newsgroup went to Thanks |
Similar Threads | ||||
Hot brakes | Denny | Piloting | 2 | November 20th 08 04:19 PM |
Brakes? | WingFlaps | Piloting | 69 | March 4th 08 06:27 AM |
Carbon brakes | [email protected] | Piloting | 3 | August 19th 06 07:01 AM |
Cobratrailer&brakes | Greg Arnold | Soaring | 5 | October 6th 03 03:14 PM |
rotor brakes | Bill Chernoff | Rotorcraft | 5 | September 5th 03 11:14 PM |
