Aspen ODP question
Old October 25th 07, 10:28 AM posted to rec.aviation.ifr
Sam Spade
Default Aspen ODP question
Jim Macklin wrote:
The sharp people at the FAA write, the lawyers edit.
No FAA lawyer edited AC 120-91.
The FAA will allow pilots to kill themselves in Part 91
operations, they tighten up under 121,135 commercial ops.
No, pilots usually kill themselves under Part 91.
Me, I want to have lots of room under the belly. The 300
King Air climbs well on one engine, particularly when the
weight is less than 14,000 lbs. TOW.
The 300 is certified under Part 25 isn't it?
But a 90 series King Air or even a 200, is under powered at
high and hot airports.
Part 23 airplanes, all bets are off.
It is my policy to be able to se and avoid, or fly IFR with
margins even beyond the word in the law.
Good for you. But, most of the real guidance is not a matter of law.
"Bee" wrote in message
| Jim Macklin wrote:
| Yes, I know that no FAA lawyer dies when a aircraft has
a
| CFIT during an IDP after an engine failure.
| Any competent pilot will consider such "details" and
adjust
| gross weight, weather or other parameters because pilots
| [and passengers] die, not FAA lawyer.
| If you are implying that some FAA lawyer wrote that
language, you have
| it wrong. That advisory circular was written by some
pretty sharp FAA
| ops folks who are trying to inform a misinformed aviation
community.
Old October 25th 07, 04:52 PM posted to rec.aviation.ifr
Jim Macklin
No, the 300 is a special part 23
"Sam Spade" wrote in message
ops.
300
at
with
matter of law.
has
| a
| adjust
pilots
| language, you have
| pretty sharp FAA
aviation
| community.
Old October 25th 07, 05:09 PM posted to rec.aviation.ifr
karl gruber[_1_]
I think the 300/350 is part 23 commuter, or something like that.
The FAA will allow pilots to kill themselves in Part 91 operations, they
Me, I want to have lots of room under the belly. The 300 King Air climbs
well on one engine, particularly when the weight is less than 14,000 lbs.
TOW.
But a 90 series King Air or even a 200, is under powered at high and hot
airports.
It is my policy to be able to se and avoid, or fly IFR with margins even
| Jim Macklin wrote:
| Yes, I know that no FAA lawyer dies when a aircraft has a
| Any competent pilot will consider such "details" and adjust
| If you are implying that some FAA lawyer wrote that language, you have
| it wrong. That advisory circular was written by some pretty sharp FAA
| ops folks who are trying to inform a misinformed aviation community.
Old October 25th 07, 06:11 PM posted to rec.aviation.ifr
Jim Macklin
The 300 was certified under SFAR 41, the 350 was certified
in the new commuter category.
"karl gruber" wrote in message
that.
operations, they
300 King Air climbs
| TOW.
| airports.
with margins even
matter of law.
has a
and adjust
pilots
language, you have
pretty sharp FAA
aviation community.
Old October 29th 07, 05:42 PM posted to rec.aviation.ifr
Bill
In case you all think this only applies to impossible locations like
Aspen, check out Northampton, MA, 7B2.
Read the obstacle departure procedure. Look at the obstacles
on the approach place and imagine how much margin you would
have if you departed there and followed the procedure. You
need more that 1000 feet only a few runway lengths ahead.
It's a pretty scairy ridge out there, and it's at sea level!
Bill Hale
Night VFR approach into Aspen Greasy Rider[_3_] Aviation Photos 0 May 25th 07 01:29 PM
Landing Fees at Aspen, CO gman Piloting 1 September 28th 06 10:40 PM
Help understanding Aspen VOR/DME approach SimGuy Instrument Flight Rules 34 August 8th 06 08:02 PM
Aircraft Buzzes Aspen Restaurant Dad Piloting 12 January 21st 06 01:20 PM
Aspen at night Ron Garret Instrument Flight Rules 47 January 6th 06 07:27 PM
