Derrick Steed wrote:
The later PIKs suffered primarily from an improper profile due to mold problems, not the usual shrinkage from a correct profile. It was so severe, Dick had to increase the chord to get the profile thickness percentage right. It's possible they had less shrinkage once out of the mold, due to the high temperature curing. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA I recall that Dick Johnson found the profile near the leading edge to be too blunt It was more than just a too blunt leading edge: the airfoil was significantly thicker at it's maximum than it was supposed be , requiring a larger chord to bring the thickness percentage to the correct value. I believe the problem was due to molds that slowly warped over time, perhaps because of the higher than normal curing temperatures required of the resin used on the glider. and some friend of his (at JPL, I think) also checked the published airfoil figures and found them to be slightly off and corrected them, he re-profiled a 'B to this and tested it at higher Reynolds numbers (add water, inside rather than outside the wing) - he reported maximum 45:1 and average 43:1. The repairer who works on my glider always cures the repairs he does at elevated temperature as recommended by the resin manufacturer - I believe PIK did just the same. The PIK used a resin that cured at a substantially higher temperature than almost all other gliders; in fact, they could be painted colors other than white. There was an entirely yellow one in California/Nevada many years ago that I flew with several times. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Similar Threads | ||||
Spar workshop CD and DVD available | mat Redsell | Soaring | 0 | May 6th 04 03:52 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
DuoDiscus Wing | Duane Eisenbeiss | Soaring | 27 | October 31st 03 02:34 AM |
Marske spar workshop | Marske Flying Wings | Restoration | 0 | October 14th 03 04:54 PM |
Marske spar workshop | Marske Flying Wings | Soaring | 0 | October 14th 03 04:52 PM |
