Full flap ILS
Roy,
But, there are some that are as short as 5000, If that is a short runway to you and you're talking about the average single-engine piston (including Bo's and the like), I'm afraid I'll have to say you need serious training. As for circling approaches, I wouldn't want to do those with the added drag of full flaps, either. -- Thomas Borchert (EDDH) |
Full flap ILS
On 15 Oct 2006 09:27:48 -0700, "
wrote: I flew safety for a friend in his Bonanza A36 w/ IO-550 yesterday. He hand flew a perfect ILS, but it was with full flap and gears down at around 22 in power. In my E35 Bonanza with E225 engine and low flap and gear speeds, I almost always fly ILS with flap up, gears down at around 17 in power. We both fly ILS at around 105 to 115 knots. During lunch, we discussed the pros and cons of full flap ILS. My friend's arguments were that with full flap, when breaking out at minimum for landing, all you have to do is to pull back on the power and land ("get dirty early"). And with higher power setting, less stress is on the engine when going full power for miss and quicker power application (especially when one gets into turbo, turboprop or jet). My landings are all full flap, but I only run about 15 degrees of flap on the ILS. The reason being that if I had to go full power with full flaps that Debonair is a hand full to keep the nose down until you retrim. There is no change in trim with flaps application but there is with speed and power. 40 degrees of flap in the landing configuration and full power will put the nose so far up you'll stall if you don't get it down. Hence my reason for only partial flaps on the ILS. I do have the gear down. The reason for the gear is when flying by the numbers at GS intercept ALL I have to do is put the gear down and I'll be following the GS very close with no other adjustments. Yes, coming in at 105 to 110 knots when the normal landing speed is about 70 knots makes the 30 to 40 knot transition a busy time. My argument against full flap ILS is that that less initial climb performance would be available during miss approach. I feel the time required to retract full flap to approach flap then to no flap would significantly reduce your climb gradient. Going full power with full The Deb goes up like a rocket the first 500 feet with full flaps. flap requires a large change in pitch, but climb rate is not better at full flap because the added drag. In addition, between landing after breaking out at minimum and executing a miss approach, I prefer less workload during the miss. Full power, hold the nose down while the flaps are coming up and retrimming at the same time. It takes about 5 seconds but it is busy! :-)) What are your opinions? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Full flap ILS
BPPP recommendations on instrument approach is not more
than appr flaps for approach phase. Reasons: 1. More speed is good; avoid slipping behind power curve in turbulence; usually you are being nagged to keep speed up anyway 2. Full flaps & full power on go around tend to pitch airplane into dangerously high attitude to cope with if in clouds 3. It is very easy to go full flaps and stabilize at landing speed when landing is assured; can easily be done in 1/2 mile. 4. Burns less gas. In airplanes w/o flap preselect, we suggest you do it clean because there is no real advantage to extending the flaps; that way you will get the same exact answer each time: 0 degrees. Changing the flaps part way down creates an unnecessary trim event. Keep it simple. Bill Hale BPPP instructor K0QA Roger (K8RI) wrote: On 15 Oct 2006 09:27:48 -0700, " wrote: I flew safety for a friend in his Bonanza A36 w/ IO-550 yesterday. He hand flew a perfect ILS, but it was with full flap and gears down at around 22 in power. In my E35 Bonanza with E225 engine and low flap and gear speeds, I almost always fly ILS with flap up, gears down at around 17 in power. We both fly ILS at around 105 to 115 knots. During lunch, we discussed the pros and cons of full flap ILS. My friend's arguments were that with full flap, when breaking out at minimum for landing, all you have to do is to pull back on the power and land ("get dirty early"). And with higher power setting, less stress is on the engine when going full power for miss and quicker power application (especially when one gets into turbo, turboprop or jet). My landings are all full flap, but I only run about 15 degrees of flap on the ILS. The reason being that if I had to go full power with full flaps that Debonair is a hand full to keep the nose down until you retrim. There is no change in trim with flaps application but there is with speed and power. 40 degrees of flap in the landing configuration and full power will put the nose so far up you'll stall if you don't get it down. Hence my reason for only partial flaps on the ILS. I do have the gear down. The reason for the gear is when flying by the numbers at GS intercept ALL I have to do is put the gear down and I'll be following the GS very close with no other adjustments. Yes, coming in at 105 to 110 knots when the normal landing speed is about 70 knots makes the 30 to 40 knot transition a busy time. My argument against full flap ILS is that that less initial climb performance would be available during miss approach. I feel the time required to retract full flap to approach flap then to no flap would significantly reduce your climb gradient. Going full power with full The Deb goes up like a rocket the first 500 feet with full flaps. flap requires a large change in pitch, but climb rate is not better at full flap because the added drag. In addition, between landing after breaking out at minimum and executing a miss approach, I prefer less workload during the miss. Full power, hold the nose down while the flaps are coming up and retrimming at the same time. It takes about 5 seconds but it is busy! :-)) What are your opinions? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Full flap ILS
In a previous article, "Bill" said:
BPPP recommendations on instrument approach is not more than appr flaps for approach phase. Reasons: 1. More speed is good; avoid slipping behind power curve in turbulence; usually you are being nagged to keep speed up anyway 2. Full flaps & full power on go around tend to pitch airplane into dangerously high attitude to cope with if in clouds 3. It is very easy to go full flaps and stabilize at landing speed when landing is assured; can easily be done in 1/2 mile. 4. Burns less gas. My instructor had a couple more reasons, based on the fact that with an Archer or Dakota a full flap ILS means 90-100 knots: 5. In this part of the world, you'll often pick up some ice on the approach - no flaps means less ice on the tail plane. 6. At a big airport, ATC will want you to fly ILSes as fast as possible. Get used to flying them at 120 knots. Plus you'll spend less time in the ice. -- Paul Tomblin http://blog.xcski.com/ "He passed away during an important civic function held in his honor when the platform upon which he was standing collapsed." "I thought he was hanged?" "That's what I said, isn't it?" |
Full flap ILS
ptomblin wrote: My instructor had a couple more reasons [...] Here's another one. The autopilot in my birdie says that fully coupled ILS is only allowed without flaps. - FChE |
Full flap ILS
On 17 Oct 2006 06:15:09 -0700, "Bill" wrote:
BPPP recommendations on instrument approach is not more than appr flaps for approach phase. Reasons: 1. More speed is good; avoid slipping behind power curve in turbulence; usually you are being nagged to keep speed up anyway Yup 2. Full flaps & full power on go around tend to pitch airplane into dangerously high attitude to cope with if in clouds In the clouds? Hell it's dangerous on a bright sunshiny day:-)) That thing will want to stand on end. 3. It is very easy to go full flaps and stabilize at landing speed when landing is assured; can easily be done in 1/2 mile. Easily. (If the pilot knows his airplane) 4. Burns less gas. Cheapest part of flying even when prices were at their highest. In airplanes w/o flap preselect, we suggest you do it clean because there is no real advantage to extending the flaps; that way you will get the same exact answer each time: 0 degrees. 1001, 1002, 1003...has worked for me for the past 13 or 14 years. Changing the flaps part way down creates an unnecessary trim event. Keep it simple. Ahhh...Changing flaps in my Deb does not change trim at all. Bill Hale BPPP instructor K0QA My Deb does not change trim at all from no flaps to full flaps. It changes trim drastically with speed or a large increase in power. So if the application of flaps slows me then, yes I'd have to retrim. On mine the trim is that big wheel under the panel, out of sight. A quarter inch movement on the circumference of that wheel will either lift you right out of the seats, or push you down into them. It took a while to get used to that. :-)) I believe after the first 30 or 40 units they changed the trim to something more easily manageable. OTOH you don't have to waste time getting the nose down on a go-around :-)) As I'm normally reading MPH it's 120 stabilized prior to the localizer intercept. trimmed for level hands off at GS intercept. Hold the nose level with gear extension at GS intercept. Add or reduce power by 1" MP for each 100 fpm change needed. It rides the ILS as if it were on rails. Full flaps when the runway is made. I don't remember the instructor's name I had down at Port Columbus, but I'd sure like to thank him for drilling in the "failed engine procedures". Mine quit on take off and I didn't even have to think about what to do. It was a nice, uneventful landing far shorter than I'd have expected. The diaphragm in the spider on top of the engine blew. Instant silence. That fuel shut off valve really works. So does the manual one as that thing was spraying a 1/4 inch stream of gas on those hot cylinders. That three blade prop will wind mill down to about 30 -35 MPH. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Similar Threads | ||||
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Negative flaps for better low speed aileron control? | [email protected] | Soaring | 41 | August 25th 05 06:01 AM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Flap Hinge Moment Calc | Bo | Home Built | 0 | February 2nd 05 06:01 AM |
