Unmanned Military Aircraft to Operate Under Advisory NOTAM Not TFRs
Is this new policy really a good idea as a model for all UAV operations conducted in the NAS? http://www.aopa.org/flightplanning/a...0unmanned.html The FAA’s decision to issue an advisory notam, rather than flight restrictions, for unmanned military aircraft operations near Cherry Point, N.C., should be a model for managing traffic near unmanned aerial flights, AOPA says. ... And what does this really mean? Aircraft that do not have an altitude encoding transponder are strongly urged to avoid Alert Area A-530 unless they are in contact with Cherry Point Approach Control. Is ATC able to track the UAV traffic and alert pilots to conflicting traffic hazards? Implicit in the lack of ATC contact necessary for Mode C transponder equipped flights is the possibility that the UAV can "see" beacon signals and avoid them. |
Unmanned Military Aircraft to Operate Under Advisory NOTAM NotTFRs
On Feb 4, 8:41 am, Larry Dighera wrote:
Is this new policy really a good idea as a model for all UAV operations conducted in the NAS? http://www.aopa.org/flightplanning/a...0unmanned.html The FAA's decision to issue an advisory notam, rather than flight restrictions, for unmanned military aircraft operations near Cherry Point, N.C., should be a model for managing traffic near unmanned aerial flights, AOPA says. ... And what does this really mean? Aircraft that do not have an altitude encoding transponder are strongly urged to avoid Alert Area A-530 unless they are in contact with Cherry Point Approach Control. Is ATC able to track the UAV traffic and alert pilots to conflicting traffic hazards? Implicit in the lack of ATC contact necessary for Mode C transponder equipped flights is the possibility that the UAV can "see" beacon signals and avoid them. All military UAV operations are IFR so, yes ATC can track them. We have Global Hawk aircraft out here and the TFR is hot for the entire time the plane is up flying (days) but the plane only passes through non-class A airspace for a total of about 20 minutes of that time. The TFR is only in case of engine failure. On the possitive side, this is a TFR that ATC will almost always grant you through, on the neg side, its a TFR. Interesting to note... 1) The Global Hawk as a transponder just like any other IFR aircraft 2) ATC communications are transmited via a Sat link to the aircraft and then rebroadcast to ATC on a standard COM radio. 3) There is a bay for a TCAS system on the Global Hawk but nothing is installed. There are not automated systems to avoid traffic in the Global Hawk. 4) The pilot is looking at a little computer screen and does not have a 360 view (or anything close to it). See-and-avoid was not built into the Global Hawk. -Robert |
On Mon, 4 Feb 2008 10:15:38 -0800 (PST), "Robert M. Gary"
wrote in : On Feb 4, 8:41 am, Larry Dighera wrote: Is this new policy really a good idea as a model for all UAV operations conducted in the NAS? http://www.aopa.org/flightplanning/a...0unmanned.html The FAA's decision to issue an advisory notam, rather than flight restrictions, for unmanned military aircraft operations near Cherry Point, N.C., should be a model for managing traffic near unmanned aerial flights, AOPA says. ... And what does this really mean? Aircraft that do not have an altitude encoding transponder are strongly urged to avoid Alert Area A-530 unless they are in contact with Cherry Point Approach Control. Is ATC able to track the UAV traffic and alert pilots to conflicting traffic hazards? Implicit in the lack of ATC contact necessary for Mode C transponder equipped flights is the possibility that the UAV can "see" beacon signals and avoid them. All military UAV operations are IFR so, yes ATC can track them. We have Global Hawk aircraft out here and the TFR is hot for the entire time the plane is up flying (days) but the plane only passes through non-class A airspace for a total of about 20 minutes of that time. The TFR is only in case of engine failure. On the possitive side, this is a TFR that ATC will almost always grant you through, on the neg side, its a TFR. Well, if this new policy of issuing advisory NOTAMs catches on, that TFR may go away. Interesting to note... 1) The Global Hawk as a transponder just like any other IFR aircraft 2) ATC communications are transmited via a Sat link to the aircraft and then rebroadcast to ATC on a standard COM radio. 3) There is a bay for a TCAS system on the Global Hawk but nothing is installed. There are not automated systems to avoid traffic in the Global Hawk. That's unfortunate. But then, I suppose prudence is not a hallmark of the military. 4) The pilot is looking at a little computer screen and does not have a 360 view (or anything close to it). See-and-avoid was not built into the Global Hawk. -Robert But it sounds like TCAS could easily be implemented to add a level of redundancy and independence of ATC for traffic alerts. Thanks for the information. |
Similar Threads | ||||
US military used half a million hours of unmanned aircraft | Tina | Piloting | 3 | January 3rd 08 07:09 AM |
COMMERCIAL UNMANNED AIRCRAFT SYSTEMS INTEGRATION PLAN | Larry Dighera | Piloting | 8 | July 3rd 07 12:21 AM |
MEDICAL CERTIFICATION FOR UNMANNED AIRCRAFT PILOTS | george | Piloting | 20 | April 29th 07 01:28 PM |
MEDICAL CERTIFICATION FOR UNMANNED AIRCRAFT PILOTS | Mike[_7_] | Naval Aviation | 1 | March 30th 07 04:23 AM |
Green Hills Software Powers Next Generation of Military Unmanned . | Otis Willie | Military Aviation | 0 | July 20th 04 12:34 AM |
