effect of changed thrust line.
Old November 19th 08, 07:15 PM posted to rec.aviation.homebuilt
Jim Logajan
Default effect of changed thrust line.
Jim Logajan wrote:
OK - got some more info.
The center of mass is something like 34 inches behind the firewall
and roughly 7 inches above the top engine mount point on the
firewall. so roughly speeking 13 inches above the prop centerline.
What is that the center of mass of, exactly? The empty airframe only
(i.e. no engine)? Or is it the center of mass of a complete airplane
(sans fuel, pilot, passenger, and baggage) with the engine mounted at
the original point?
I'm also curious as to how you determined the location in two
dimensions. I can think of a few ways of determining it, but they all
involve a bunch of effort.
Center of mass for the completed plane when built to specs. Provided
by the designer.
I don't suppose the designer was or is willing to provide general advice
or guidance on mounting your engine? Sure beats asking total strangers on
the net. :-)
If I were in your position these are a few of the things I'd keep in
mind:
* The center of mass (CoM) of an empty airplane and full airplane are in
different locations in three dimensions. In the two dimensions of
interest, depending on how fuel, passengers, and baggage are loaded, it
moves around in those two dimensions such that it is geometrically
impossible to move engine "down" and find a single angle that yields the
original moment arms for all load configurations. The one configuration I
don't think I would use to compute engine mounting angle would be the
empty configuration.
* Moving the engine down relative to the original design specs also moves
the empty airplane CoM down. Assuming the Corvair and O-200 are both the
same weight of about 200 lbs, and assuming the empty weight of the plane
is 815 lbs, then if the engine is moved D inches down, the CoM moves down
D*200/815 inches. If D = 4, CoM moves down about 1 inch.
* I don't know where the CoM of passengers and baggage would be, but they
probably move CoM down (and presumably fuel moves it up). As an example,
if all that usable load is about 600 lbs, then if that load's CoM is L
inches below the empty airplane's CoM, the CoM of the whole airplane
moves down L*600/(815+600). So if, for example, L = 5, then CoM moves
down about 2 inches. So between lowering the engine and throwing in
stuff, the CoM of the airplane in this configuration differs by about 3
inches from that used in the original empty airplane spec. But the load
probably moved the CoM forward or backward too, affecting another
variable in the equations. Fun, huh?
* How much is the horizontal tail in the propwash? That and a different
angle of incidence of the propwash on the fuselage might give me more
down pitch than I calculated by assuming the only factor affected by the
engine move and rotation was the thrust moment arm. I might also risk
losing thrust efficiency because of increasing fuselage interference in
the propwash.
* At some point I'd realize that the CoM is variable enough that for the
small amount I'd be moving the engine, it would probably be best to mount
the engine so that the engine thrust line is aligned with the most
natural fuselage longitudinal. Then make trim adjustments during the test
flights.
  #102
Old November 20th 08, 03:46 AM posted to rec.aviation.homebuilt
On Wed, 19 Nov 2008 13:15:02 -0600, Jim Logajan
the original point?
by the designer.
the net. :-)
mind:
the propwash.
flights.
Thanks Jim.
I just talted to a P.Eng who has a LOT of aeronautic experience and he
said I likely would not notice any change, but he would cut the
recommended 1.5 degrees roughly in half for my install... I don't
think there will be any detrimental effect as far as propwash is
concerned - might even improve very marginally.
  #103
Old November 23rd 08, 10:51 PM posted to rec.aviation.homebuilt
On Sat, 15 Nov 2008 11:46:10 -0500, wrote:
On Fri, 14 Nov 2008 22:53:23 -0600, cavelamb himself
The Corvair would use a bearer style mount, wouldn't it?
Not on this plane. I'll get pics of the mount design on line soon.
I've put mounting tabs on the top and bottom rear so I'm mounting it
like a Conti O200, but using 1" diameter Licoming type homebuilder
mounts.The typical bed mount would interfere with my 180 degree header
system.
How will the mount attach to the engine case?
I don't recall how the aft end of the engine is arranged.
I'll get pictures, but I used a chunk of auminum channel, cut away to
make a "U" shaped bracket that bolts to the top surface of the engine
case, with "ears" to which mounting blocks are fastened, immitating
the top ears of an O200 case. The bottom has an angle boted down each
side, like the typical bed mount but without rubber isolation, with
mount blocks fastened to them as well,.
Very similar to the way it is mounted on my engine test stand,
pictured on my website.
OK guys, the pictures of the mount are up on my website at:
http://www.pegazair.on-the-net.ca/Cl...ared/Mount.htm
Drop by and take a gander. You can get to the rest of the project from
there as well.
  #104
Old November 24th 08, 09:30 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default ClareSquared , was effect of changed thrust line.
there as well.
that is either a bloody big aeroplane or the wife is the cutsiest
little thing.
her washing line is half the height of the rudder!!
......yeah I know. it was taken from the second floor....
nice workmanship. thank god you're not a simmer!
Stealth Pilot
thrust line for engine and not mounting engine on this thrust line tommyann Home Built 8 December 15th 06 03:31 PM
Has something changed [email protected] Soaring 10 May 3rd 05 08:34 PM
High thrust line on canard design? Shin Gou Home Built 4 March 5th 05 03:06 AM
Getting students to line up with the center line BoDEAN Piloting 27 April 21st 04 11:23 AM
I want to tell you something that has changed my life! C J Campbell Owning 11 January 29th 04 11:34 PM
