PMA Questions
Old December 7th 05, 08:23 PM posted to rec.aviation.owning,rec.aviation.piloting
Default PMA Questions
But is there such a thing as an STC for a minor modification?
No, by definiton.
An STC is issued as approved data for a MAJOR modification to the type
design.
A minor modification does not require approved data, it only requires
acceptable data.
However, what constitutes a major vs. a minor alteration is open to
interpretation, and to the extent official guidance exists (not often)
it has been known to change over time. For example, once upon a time
any RNAV installation was considered to be major. It required either
an STC or a field approval. If you look at the installation manual for
a KNS-80 VOR-DME RNAV, you will see included an STC for its
installation into a PA-30. The guidance on this has changed. These
days, the installation of a KNS-80 is generally treated as a minor
modification, but when it was new the FAA wanted to maintain control.
IFR GPS installation is going through the same process. Originally, an
STC or field approval was required, but the FAA has issued guidance
that certain simple IFR GPS installations (ones where there is no GPSS,
for example) may be treated as minor.
So there are STC's out there for the installation of a given piece of
equipment into a difference aircraft that are being cited as acceptable
data for a modification that used to be considered major but is now
well enough understood that it is considered minor.
If you're looking for hard and fast answers in this area, realize that
they are not to be found. What is major or minor varies from FSDO to
FSDO, and from year to year in a given FSDO. What will be considered
approved data also varies. I've had a 337 for a Stormscope
installation IAW an FAA APPROVED installation manual (comepte with
revision history) accepted one year, and an almost identical one
rejected a couple of years later. Policy had changed. You will NOT
get clear and unambiguous guidance on this from the FSDO. If you
insist on it, you will be told that everything is major and no field
approvals are available, so either get an STC or hire a DER. Or you
can live with a grey area.
Michael
Old December 8th 05, 01:15 AM posted to rec.aviation.owning,rec.aviation.piloting
RST Engineering wrote:
"Why, that was there when I bought the airplane..."
Jay's strobes were in the plane when he bought it. Fat lot of good that did him.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old December 8th 05, 03:51 AM posted to rec.aviation.owning,rec.aviation.piloting
"George Patterson"
did him.
Was that a case of not being able to get past the mechanic? I don't recall
the details.
Montblack
  #24
Old December 8th 05, 04:50 AM posted to rec.aviation.owning,rec.aviation.piloting
recall the details.
Well, Jay will correct me, I'm sure, but the gist of it was that the FSDO told
him that the strobes that had been on the plane for a couple decades weren't
STCd and had to come off. Cost him a few grand.
George Patterson
  #25
Old December 11th 05, 11:24 PM posted to rec.aviation.owning,rec.aviation.piloting
To be fair to him, what he meant was that if you had a product that was
PMA/STCed for a given airframe (for example the B&C standby alternator
referened at [1] below) then the installation of this product did not
require a 337, even thought it was being installed using an STC. He
says that the PMA approval removes the need for additional paperwork.
My view is that you still need the 337 if it's a major alteration,
which this would be, and that the PMA-ness of the parts is merely
something that allows the manufacturer to put them on the market,
[1] http://www.bandcspecialty.com/PA32desc.html
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
