PowerFlarm range tool
Old August 27th 18, 09:58 PM posted to rec.aviation.soaring
Default PowerFlarm range tool
Hello everyone. I just upgraded my PowerFlarm firmware from 6.42 to version 6.60 this past weekend. After flying I uploaded my .igc file to the PowerFlarm Range Tool to see if anything had changed for the better or worse. Interestingly, the 6.60 generated log file shows zero FLARM data points of any kind in the tool. I can look at the .igc in a text editor and see numerous LFLA records in the file. I know the FLARM was working because I was seeing traffic alerts all day long on my FLARM displays. For grins, I ran a log file generated under FW 6.42 and the Range tool showed many data points. Looking through the log files I see that the 6.42 log file has several encrypted LFLA entries (like LFLA20042502nJMrwj?wwwqyZgn]m#j]HSOIPya) that don't exist in the 6.60 generated log file.
Any ideas?
Robert
Old August 27th 18, 10:35 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Any ideas?
Robert
I just ran two files generated after I updated to 6.60; both worked with pretty well identical results to 6.42 using the FLARM Range Analyzer Tool.
You might try a factory reset, then install new firmware and flarmcfg.txt. You will lose stored igc files.
# Complete factory reset. Use in a one-line flarmcfg.txt file
$PFLAR,99
Dan
PowerFlarm range tool Mark628CA Soaring 2 November 17th 15 05:24 AM
PowerFlarm: 2.7 Vertical Range [email protected] Soaring 8 April 9th 13 11:27 PM
PowerFlarm Range Analysis Richard[_9_] Soaring 0 March 25th 13 04:43 PM
PowerFlarm BRICK range issues - are we alone???? Mark Soaring 79 October 17th 12 12:17 PM
PowerFLarm expected range [email protected] Soaring 6 August 30th 12 03:43 PM
