Using new variometer technology to display real time lift coefficient?
Old February 9th 17, 06:02 PM posted to rec.aviation.soaring
JS
Default Using new variometer technology to display real time lift coefficient?
On Thursday, February 9, 2017 at 9:44:49 AM UTC-8, Richard wrote:
On Thursday, February 9, 2017 at 9:21:16 AM UTC-8, wrote:
Speaking of technology I just watched a seminar by Infineon - they make sensors. In the pressure transducer they make for exercise trackers can have high definition to tell that someone is climbing or descending stairs or help determine what kind of activity they are doing.
They can sense a air pressure difference of 50mm/2 inches!!!
These were energy efficient for use with battery powered systems of course.
Chris
I remember being told that the sensors used in the LXNAV equipment measure 1cm or altitude 100 time per second.
Richard
www.craggyaero.com
When I was testing an Air-Glide S on the bench, discovered it takes very little disturbance of the ISU to get readings.
Old February 9th 17, 08:30 PM posted to rec.aviation.soaring
Bruce Hoult
Sure. I've used a couple of these in little projects. Dead easy to hook up to any Arduino, Raspberry Pi etc.
https://www.sparkfun.com/products/11824
Relative accuracy of 0.02 hPa means about 15 cm at sea level I think.
There are better ones available but this chip sells for 3.73 Euro for one, or 2.25 Euro if you buy 1000 of them http://eu.mouser.com/ProductDetail/B...sortec/BMP180/
The Sparkfun board is more because ... it not just the chip, it's the chip on a board, easy to use for amateurs or for prototyping.
OT 4 airport round robin - time lapsed / real time with ATC COMS -video A Lieberma[_2_] Owning 0 August 30th 09 12:26 AM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video [email protected] Instrument Flight Rules 0 August 30th 09 12:26 AM
Rotor lift coefficient devi Rotorcraft 1 September 25th 05 01:17 AM
about lift and drag coefficient for cessna C-160 Grandss Piloting 9 August 15th 05 06:15 PM
Real-time real world air traffic in flight sims Marty Ross Simulators 6 September 1st 03 04:13 AM
