iGlide loses saved routes
Old November 18th 18, 04:14 PM posted to rec.aviation.soaring
Default iGlide loses saved routes
I’ve need flying with iGlide on an iPad mini 4 for a couple years now. It’s really good, but it has an annoying feature of losing all of the saved routes every couple of months. I usually happens right after I’ve entered a long route. It’s frustrating. I enter a new round with 6 turn points and then I hold my breath. Is it going to lose them all or not? And when it looses the route I’ve just entered it also looses every other route that I’ve entered over the past couple of months. Is there a way to recover the saved routes?
iGlide does not lose custom turn points. It does not lose my flight logs. But it loses saved routes. Has anybody else seen this? Is there a fix?
Old November 18th 18, 05:10 PM posted to rec.aviation.soaring
jfitch
iGlide does not lose custom turn points. It does not lose my flight logs.. But it loses saved routes. Has anybody else seen this? Is there a fix?
I've not seen that, have perhaps 20 routes going back several years, and moved forward across a couple of devices and several iOS versions. You do have to be careful when entering a new one to explicitly save it, their UI isn't super intuitive there.
The routes are kept in a file named Routes.aip which is an xml formatted text file. In iTunes I believe you can save and restore that file. That's how I've moved it from phone to phone. The only data loss I've seen is losing all the data (looks like a fresh install), that's happened twice now in doing an OS update. Last time was several years back. For that reason though, I backup all the data files before I do an OS update. Don't just do the routes, get the config, the navbox_config, and the styles files. While you are at it take a look at them: they allow further customization of the UI, though it is undocumented it is somewhat self documenting.
Saving tasks (routes) in iglide [email protected] Soaring 9 July 28th 17 03:53 PM
US saved from anhilation Brad[_2_] Soaring 5 August 4th 12 09:51 PM
F-14 saved my life Amir - Iranian F-4 pilot Naval Aviation 2 August 5th 07 12:45 PM
Saved By a Horse John Kunkel General Aviation 0 November 11th 05 08:34 PM
Leatherman saved the day Ben Jackson Piloting 5 June 7th 05 03:33 PM
