Help !! Ventus CM- engine stuck
After stowing the engine on a self-launch I heard a high pitched
whine. I turned off the circuit breakers.. The problem is now I can not extend the engine. The circuit breaker will pop if it is reset. Any ideas on how to extend a stuck engine? ( other than cutting a hole in the side of the fuselage) |
On Feb 15, 7:14*pm, hoss wrote:
After stowing the engine on a self-launch I heard a high pitched whine. I turned off the circuit breakers.. The problem is now I can not extend the engine. The circuit breaker will pop if it is reset. Any ideas on how to extend a stuck engine? ( other than cutting a hole in the side of the fuselage) unbolt the jack screw? Brad |
On Feb 15, 9:10*pm, Brad wrote:
On Feb 15, 7:14*pm, hoss wrote: After stowing the engine on a self-launch I heard a high pitched whine. I turned off the circuit breakers.. The problem is now I can not extend the engine. The circuit breaker will pop if it is reset. Any ideas on how to extend a stuck engine? ( other than cutting a hole in the side of the fuselage) unbolt the jack screw? Brad If it comes down to cutting, I'd rather have to repair an engine bay door than get into the fuselage structure. Craig |
On Feb 16, 12:43*am, Craig wrote:
On Feb 15, 9:10*pm, Brad wrote: On Feb 15, 7:14*pm, hoss wrote: After stowing the engine on a self-launch I heard a high pitched whine. I turned off the circuit breakers.. The problem is now I can not extend the engine. The circuit breaker will pop if it is reset. Any ideas on how to extend a stuck engine? ( other than cutting a hole in the side of the fuselage) unbolt the jack screw? Brad If it comes down to cutting, I'd rather have to repair an engine bay door than get into the fuselage structure. Craig You can manually pull open the engine bay doors and then unbolt them. I just wasn't sure if unbolting the jackscrew actuator was the only option. Ken |
Similar Threads | ||||
Stuck ident | Bob Noel[_6_] | Owning | 4 | September 14th 09 03:41 AM |
Stuck Canopy | David Hartung | Aviation Photos | 2 | June 21st 07 05:08 AM |
Stuck Collective | Linc | Rotorcraft | 4 | November 27th 06 06:07 PM |
Ever stuck your neck out too far? And got away with it? | pacplyer | Piloting | 31 | January 2nd 04 06:21 AM |
Ever stuck your neck out too far? And got away with it? | pacplyer | Home Built | 26 | January 2nd 04 04:04 AM |
