Red V on OLC from CA302?
I recently downloaded a flight to the OLC and got a red V for validation does anyone know how to fix this or what the problem is? all this stuff worked last year.
SF |
On Saturday, March 9, 2013 5:20:34 PM UTC-5, SF wrote:
I recently downloaded a flight to the OLC and got a red V for validation does anyone know how to fix this or what the problem is? all this stuff worked last year. SF There was a bit of a hassle about this last year, but with a small amount of additional effort you can make it work. Please follow the instructions provided here http://clearnav.net/main/cn-CAI-OLC.html with best regards from ClearNav Instruments, Evan Ludeman for CNi |
Hi Evan,
That utility is for Cambridge GPS-NAV units, not 302 units. 302 units validate on the OLC web site just fine without any modifications. Paul Remde _________________ "Evan Ludeman" wrote in message ... On Saturday, March 9, 2013 5:20:34 PM UTC-5, SF wrote: I recently downloaded a flight to the OLC and got a red V for validation does anyone know how to fix this or what the problem is? all this stuff worked last year. SF There was a bit of a hassle about this last year, but with a small amount of additional effort you can make it work. Please follow the instructions provided here http://clearnav.net/main/cn-CAI-OLC.html with best regards from ClearNav Instruments, Evan Ludeman for CNi |
On Saturday, March 9, 2013 5:55:57 PM UTC-5, Paul Remde wrote:
Hi Evan, That utility is for Cambridge GPS-NAV units, not 302 units. 302 units validate on the OLC web site just fine without any modifications. Paul Remde _________________ "Evan Ludeman" wrote in message ... On Saturday, March 9, 2013 5:20:34 PM UTC-5, SF wrote: I recently downloaded a flight to the OLC and got a red V for validation does anyone know how to fix this or what the problem is? all this stuff worked last year. SF There was a bit of a hassle about this last year, but with a small amount of additional effort you can make it work. Please follow the instructions provided here http://clearnav.net/main/cn-CAI-OLC.html with best regards from ClearNav Instruments, Evan Ludeman for CNi Yeah, I know, which is why I deleted the post from google groups. T8 |
Hi,
Cambridge 302 flight logs are accepted by the OLC without any need to modify them. The issue could be: - Check the filename of the file you uploaded. It should include the serial number of your 302. If it doesn't then you probably accidentally uploaded a flight log that was generated by the "PDA logger" in your soaring flight software. - When you downloaded the file - did you use the Cambridge 300 utility? If so, did it stated that the file passed all 3 security tests? If you didn't use the Cambridge 300 utility, that is fine - but you may want to check the security of the file using the Cambridge 300 Utility on your PC. - Does the 302 show "good seal" on one of the screens? If not, then the unit needs to be re-sealed at Cambridge or by a dealer like myself. - There is a bug in 302 units that seems to cause rare flight log security issues. I suspect it happens when the memory gets full. You can read more about that an how to clear the memory he http://www.cumulus-soaring.com/newsl...LETTER.BLOCK15 Best Regards, Paul Remde Cumulus Soaring, Inc. __________________________________ "SF" wrote in message ... I recently downloaded a flight to the OLC and got a red V for validation does anyone know how to fix this or what the problem is? all this stuff worked last year. SF |
