OLC Problems
Old November 19th 06, 11:19 PM posted to rec.aviation.soaring
Mal
Default OLC Problems
Is anyone else having problems logging in to the OLC
Mal
www.mals.net
Old November 19th 06, 11:43 PM posted to rec.aviation.soaring
Tim Taylor
I get on about 50% of the time. Does anyone know how to contact the
admins for the OLC, I have a flight with a zero score that I don't know
how to fix.
Tim
Mal
www.mals.net
Old November 20th 06, 01:04 AM posted to rec.aviation.soaring
Greg Arnold
how to fix.
Don't bother to contact the OLC admins in Europe -- I have 4 flights
with zero scores, and they don't know how to fix any of them. Doug
Haluza in the USA is doing a good job, but he doesn't have the access to
the website necessary to fix the problems.
Recently, the website seems to be down every evening in the USA --
almost like the people in Europe turn off the server when they go to
bed. Maybe they are trying to conserve electricity.
Tim
Mal
www.mals.net
Old November 20th 06, 03:28 AM posted to rec.aviation.soaring
Doug Haluza
how to fix.
There is a problem with the OLC production server crashing, and they
have not been able to reproduce the problem on the development server,
so this will be a difficult problem to fix. In the mean time, it has to
be manualy rebooted when it crashes. The OLC team does get an SMS
message whenever this happens, so there is no need to notify them; but
someone has to be near a computer to fix it. Naturally if it happens
late at night, it does not get fixed until the next morning (German
time).
There are also problems in the scoring algorithm causing some flights
to get zero score. As the problems are fixed, the flights will be
re-scored, as some have been already, so please be patient. Keep
claiming your flights, since they can't be fixed if they are not
submitted by the Tuesday 24:00 local deadline.
Old November 20th 06, 07:35 PM posted to rec.aviation.soaring
Ramy
There are also serious time zone and calendar issues as a result of
javascript errors, which requires multiple steps to get around. But
apparently it is more important to the OLC team to provide a google
earth link than fix their bugs. Can't even use olc to review other's
flights anymore...
It's about time that someone with spare time and talent will develope a
US alternative to olc, without all the hassles and politics.
Ramy
Doug Haluza wrote:
how to fix.
time).
Old November 20th 06, 09:24 PM posted to rec.aviation.soaring
hans
Default OLC Future
flights anymore...
Ramy
At least one nation has done it already, others have never joined the
OLC movement.
But is the world gliding community sufficiently powerful that we can
allow it to split it into many small communities?
Old November 19th 06, 11:48 PM posted to rec.aviation.soaring
user
Endless.
"Mal" wrote in message
Mal
www.mals.net
Old November 20th 06, 01:50 AM posted to rec.aviation.soaring
5Z
Did a couple of extended glides today with a Garmin onboard, so wanted
to test the new SeeYou upload. It connected, flashed a progress bar
for a few seconds, then hung with the timer spinning. Let one go for
over 10 minutes. Now, a couple hours later, my browser is just
spinning on a blank screen in an attempt to connect.
The flights are only worth a few points, but so far the exercise is
failing...
-Tom
Old November 20th 06, 02:42 AM posted to rec.aviation.soaring
I am glad to know that I am not the only having problems logging
onto OLC. Hopefully by the start of our soaring season, they will
have all of the bugs worked out.
Randy
N304RS
Mal
www.mals.net
Old November 20th 06, 03:57 AM posted to rec.aviation.soaring
P. Corbett
I can usually log on using www3.onlinecontest.org but they keep saying
that there are no flights to report. It is hard to believe that there is
no one on the planet flying a glider, especially down under.
Can anyone pass-on the link they are using to view flights with the new
system?
Paul
ZZ
GPS Reception Problems with 396 Dan Piloting 16 August 5th 06 04:01 AM
Mooney Engine Problems in Flight Paul Smedshammer Piloting 45 December 18th 04 09:40 AM
Chaplains urge couples to attend retreat to solve problems, By Kent Harris, Stars and Stripes Otis Willie Military Aviation 0 May 31st 04 03:46 AM
F22 Problems Paul F Austin Military Aviation 9 February 5th 04 02:27 AM
