#21
They (Extra) recommended changing the battery every two years since they
seem to know the history of the typical battery life (cranking the IO-540), and the fact that it is much easier to change the battery (an RG35XC) during an annual rather than waiting for it to die. (It involves taking all of the panels off of the plane as well as the front seat, so is much easier to do during an annual). In my much smaller Decathlon the battery seemed to last around three years before needing a change, so this sounds about right to me. |
"RST Engineering" writes:
but the stuff of choice is plain old Arm&Hammer baking soda at about a 10% concentration in water. When it stops bubbling with each fresh application, you is done. Nod... On cars, I leave some baking soda in place, for future leaks. The only good news is aircraft are largely aluminum and at least the mild acid in batteries has little effect on same. Alkali, however.... (Soaking in a tank of 180+F lye is often used to degrease/depaint/derust {steel} engine blocks. Just be VERY sure that the aluminum pistons etc. are not attached...or you'll see why...) -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
4 years on my last Concorde. And it didn't die - just started getting
a little sluggish when winter hit in December. |
My C310K has a 28 volt system, and uses two Gill G-25 batteries in
series. Seems to be less expensive to use a pair of commonly available 12 volt instead of a single 24 volt battery. I replaced them in 2002, the same time I replaced the very old voltage regulators/load balancer with newer solid state regulators. I also had both generators overhauled at Aerotech of Louisville and replaced the drive belts. I went back through the logbooks and found that batteries had lasted an average of 6 years (almost like clockwork), and my batteries at that time were 6 years old. Brian N3827X |
RST Engineering wrote:
Are you talking about the Pep Boys Aircraft Supply Depot? {;-) Jim Not to be confused with the Orchard Supply Hardware aircraft supply and/or tool department...at least according to the RV6 builder in the family :-) -- Jack Allison PP-ASEL-IA Student Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
On 7/6/05 13:59, "Maule Driver" wrote:
What are other people's experience with battery life? Going on six and a half years on a Concorde RG 25 in a Husky. However, I'm flying about 150 + hours/year. - Don History does not long entrust the care of freedom to the weak or the timid. - Dwight D. Eisenhower |
Jay Honeck wrote:
Can a sealed battery like my new one leak? I had one of the Concord RG series in my Maule. No leaks or corrosion (the stuff you had to clean up) in ten years. I *did* find that the RG batteries don't seem to last as long as a regular lead/acid battery. They also are more likely to get permanently damaged if you let them sit with less than a full charge. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
#28
Maule Driver wrote:
What are other people's experience with battery life? The Concorde RGs in my Maule lasted about like yours. I got 6 years from the Gill in my Cessna. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
#29
I just removed my old Gill G-35 from my Archer and I'm waiting for a
Concorde RG35-AXC from Spruce. This non-sealed unit lasted a few months past 8 years while being flown about 2 hours per week. According to some spec's I was looking at (on the Concorde web page?) the sealed batteries do not require a battery box and can be mounted in any position, so I guess they are not expected to crack and vent. The failure mode for the old battery was a shorted cell spewing electrolyte against the inside of the battery box lid. Since it ate away the paint it would be easy to pick up on a routine inspection of the battery. Regards, Mike. "nrp" wrote in message oups.com... What are other people's experience with battery life? C172M - I've always gotten at least 8 years from the last three batteries. Just never let the plates get exposed to air, never let it get discharged & keep the top clean. I do not put any trickle charger on it unless everything is down for many weeks. I also have never had to use the ground service plug - except when the FAA Certified Repair Station left the master on after an annual....... |
Similar Threads | ||||
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 09:12 PM |
