tie down plates
Old August 14th 07, 03:03 AM posted to rec.aviation.owning
Dave[_5_]
Default tie down plates
Google produced this info which may be useful:
http://www.jimssupply.com/anchors.htm
Old August 15th 07, 01:57 AM posted to rec.aviation.owning
Blueskies
"David Lesher" wrote in message ...
We now plan to put down pressure-treated 2*4's 12' long; drilled at
~30 degree angles to the vertical. We'll use ~30' lengths of
rebar with a welded nut & a fender washer or two, and hammer them into
the clay. Then we'll lag-screw the structure legs to the 2x4's.
30'...or 30"
Old August 15th 07, 02:59 AM posted to rec.aviation.owning
David Lesher
"Blueskies" writes:
30'...or 30"
Yea, 30 inch long rebars, spread along two twelve foot long 2x4's...
Unless it rains a LOT in the meantime, it will be hard enough to get
those in...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Govt Plates Mike Granby Instrument Flight Rules 103 November 27th 06 07:12 AM
Backup plates on PDA Stan Prevost Instrument Flight Rules 29 December 10th 04 02:42 AM
Plates for PDA? Kelly Bakst Instrument Flight Rules 29 September 3rd 04 05:21 AM
data plates Del Rawlins Home Built 2 August 21st 04 10:34 PM
